TJ Transmission cooler - JeepForum.com
post #1 of 20 Old 05-03-2004, 11:07 AM Thread Starter
JFiorentino
JFiorentino's Avatar
Hello, has anyone out there added an aftermarket transmission cooler to their TJ? I have the 4.0L with automatic transmission, and was hoping to find some instructions, or pictures for this modification.
If you have done this modification, are you happy with it? I've noticed that as our weather gets warmer, that my feet are starting to cook. The transmission is making my floorboards very hot. You can really feel the heat rising from the floor.
Digger
JFiorentino is offline
post #2 of 20 Old 03-17-2005, 06:27 PM
jasonX
I just wanted to re-ask the above question. There isnt much info on here for aftermarket transmission coolers for TJ's (and not a write up on www.4x4xplor.com).
The reason I'm asking is because I will be going to 33's this summer, and I tow my waverunner all over the place on the weekends. I destroyed the transmission in my F-150 with stock gears and 35's and dont want the same thing to happen again.
Thanks
Sold the
for a '70 Nova SS, but I still like hanging around this site!
jasonX is offline
post #3 of 20 Old 03-17-2005, 07:16 PM
Fritz R.
I am running a B&M stacked plate cooler on my TJ. I attached it to the v support in front of the radiator so it would get good airflow. Seems to work great. Kept the tranny nice and cool last summer. The other thing I would recommend is a tranny temp guage so you know what kind of temperatures you are running at.
Fritz R. is offline
post #4 of 20 Old 03-17-2005, 07:31 PM
Stu Olson
Stu Olson's Avatar
http://www.stu-offroad.com/aw4/cooler.htm provides some comments on putting a tranny cooler into a TJ.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #5 of 20 Old 03-19-2005, 03:45 PM
old soldier
I am a rock crawler with my 2003 Rubicon (30, 658 miles) and VERY concerned about the transmission oil getting very hot a 600-900 RPM's crawling. I just installed a B&M Automatic Transmission Oil Cooler #70264. I can't tell you the difference yet because I have already been out Jeepin this month (without the cooler) and won't go again for about 2 weeks. The transmission oil still goes thru the radiator but also now has it's on radiator. That's got to b e an improvement. I also haul a heavy cargo trailer with my Swampers and camping gear and that puts a burden on the auto tranny.
The #70264 is a complete kit. It went with B&M because of their reputation for quality products.
Locked and Loaded, Nuff said. Anything else is an ego trip.
old soldier is offline
post #6 of 20 Old 03-19-2005, 04:13 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
I don't know much about transmissions...any sense in running these on a manual tranny? I would assume it gets pretty hot too.
lj
ಠ_ಠ
LoneJeeper is offline
post #7 of 20 Old 03-19-2005, 04:26 PM
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
How about Rusty's tranny cooler? That any good?
MattTheMudder is offline
post #8 of 20 Old 03-19-2005, 04:46 PM
Stu Olson
Stu Olson's Avatar
One could make a general statement that for the most part says antyhing could benefit from having the heat removed....diffs, tranny, t-case, etc.
That being said, the auto tranny generates more heat than does a manual tranny because of the torque converter and the manner in which the transmission functions. There also is no pump in the manual tranny by which to circulate the fluid so even if you wanted to put a cooler on it, it would not be very easy.
There is one other thing that you could add a cooler to and that is your power steering system. It DOES get hot, hot enough to boil the PS fluid in some cases. Keeping it cooler will prolong the life of your pump and your steering box. It is a $30 project and well worth the money and 2 hours of time it takes to do it. Details on how to do it are on my web site.
Stu Olson
ARB Locked & Loaded
post #9 of 20 Old 03-19-2005, 06:05 PM
StealthTJ
As Stu mentioned, a lot of people seem to neglect their power steering unit.
I've added an after market power steering cooling, and a tranny cooler in front of the radiator (I don't use the radiator to cool the tranny), and I've added a tranny cooler up under the bed of the Jeep, behind the rear axle, drivers side. This is a B&M cooler with a built in, thermostatically controlled fan.
The combo. of the two tranny coolers has worked very, very well for me for the past several years, out here in about as hot of conditions as one is going to find.
Virtually all of the off-road driving that I do is pretty heavy rock crawling.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #10 of 20 Old 03-19-2005, 06:59 PM
98TJSport
i would also like to install a tranny cooler, for people that go in the mud installing it under the jeep would be pointless (i know ur a rockcrawler). with that said, would infront of the radiator be the best place to mount it?
==KF7HBV==
2004 TJ X
98TJSport is offline
post #11 of 20 Old 03-19-2005, 07:14 PM
LoneJeeper
LoneJeeper's Avatar
2013 MJ Comanche
thanks Stu, full of good info, as always
ಠ_ಠ
post #12 of 20 Old 03-19-2005, 08:31 PM
WRFD17
WRFD17's Avatar
What kind of price range and install time/difficulty is this project ??
Blue '04 TJ Columbia Edition
N R A JEEP Club # 1
Blue Jeep Club Member #57
Firefighting Jeep Club #4
M.W.J.T.
WRFD17 is offline
post #13 of 20 Old 03-19-2005, 08:39 PM
jeepramnauth
2010 JK Wrangler
can u liquid cool a TJ, like porsches?
jeepramnauth is offline
post #14 of 20 Old 03-19-2005, 08:42 PM
StealthTJ
TJ's are liquid cooled....
What do you think that green fluid circulating though the engine block is
Fred
Misc - Tera 2wd lo.
post #15 of 20 Old 03-19-2005, 08:45 PM
jeepramnauth
2010 JK Wrangler
oh....hehe, i feel stupid!
Transmission Cooler Toltecatl TJ Wrangler Technical Forum 26 03-05-2010 10:32 AM
Which Transmission Cooler? cvd TJ Wrangler Technical Forum 15 12-10-2008 06:17 PM
Transmission oil cooler swampbuddy TJ Wrangler Technical Forum 0 01-17-2008 09:23 AM
TJ transmission cooler am3rican TJ Wrangler Technical Forum 11 07-11-2007 07:54 PM
Transmission cooler turfman* TJ Wrangler Technical Forum 4 01-01-2005 06:58 PM
