TJ transfer case swap - JeepForum.com
post #1 of 11 Old 08-01-2010, 02:34 PM Thread Starter
jaimelynn1969
Hey all,
New TJ owner and have a question. Does the NP 231 for a 99 have any other T cases that will bolt right on? I read the dana 300 works. My husband is getting my truck on Monday so I want to buy the upgrade before he goes and rebuilds my stock transfer case.
And thanks for the help!!
jaimelynn1969 is offline
post #2 of 11 Old 08-01-2010, 02:40 PM
TeeJay00
Originally Posted by jaimelynn1969 View Post
Hey all,
Why would you need/want to change it???
TeeJay00 is offline
post #3 of 11 Old 08-01-2010, 02:44 PM Thread Starter
jaimelynn1969
It has a solid like clunk in any gear and when he drained the fluid there are speckles as he describes them. So he was going to rebuild it. But if I can get something bigger and better I would like to do it now then later.
post #4 of 11 Old 08-01-2010, 03:43 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
post #5 of 11 Old 08-01-2010, 03:45 PM
TeeJay00
Good idea... why not... Go for it
TeeJay00 is offline
post #6 of 11 Old 08-01-2010, 05:05 PM Thread Starter
jaimelynn1969
He's going to hate me...
post #7 of 11 Old 08-01-2010, 05:42 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
As he should. There's simply no reason to do anything other than find a good used 231 for less than 500 bucks and swap it in and the 500 mark is very very generous. I see them quite often for 2-250.
Save your money and buy a SYE and quality DC driveshaft for the lift and bigger tires we all know is coming.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 11 Old 08-01-2010, 05:43 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Silly females, always wanting something bigger and better.
I am Savvy
mrblaine is offline
post #9 of 11 Old 08-01-2010, 07:00 PM Thread Starter
jaimelynn1969
So no real advantage other then it is new. Got it. He told me there is a chain in there. I think he said something like a gear is missing a tooth.
post #10 of 11 Old 08-01-2010, 08:23 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Of course there are advantages to some case swaps. What areas do you find your rig currently lacking in when you take it wheeling?
Upgrade for reasons that make the money spent a decent value. If it's just the t-case, a simple swap of a good cheap case from another rig is easy, fast, and very effective.
Don't forget on the internet, folks without two pennies to rub together derive great delight in spending other's money for them.
I am Savvy
mrblaine is offline
post #11 of 11 Old 08-10-2010, 09:48 PM Thread Starter
jaimelynn1969
Well after a lot of tinkering and tear down my TJ is rolling again. In the past week we tore down the rear end to find it was not set up correctly. ABSOLUTELY NO SHIMMING! caused the ring gear to fail. Then he checked the front and found the pinion unshimmed. After it was rolling again the driveline in the front had a bad centering joint. So all the ujoints got replaced. Then after checking the T-case found it was a failing bearing. So the clunk was in the rear end along with a bunch of other stuff. He has replaced everything and installed a Detriot locker in the rear and an Aussie locker in the front. I don't know but it sounds cool. Also put in an overhead console and a new stereo system. I think he will be doing body work next. Hopefully I can get some pictures up soon.
Thanks for the help guys.
transfer case , swap , np231 , dana 300
Should I swap my transfer case? TJRoberto TJ Wrangler Technical Forum 5 07-24-2010 11:02 AM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Transfer Case Swap Help please JfirEfightErP TJ Wrangler Technical Forum 9 07-16-2009 03:31 PM
NP-231 transfer case swap BBCAT TJ Wrangler Technical Forum 4 12-09-2008 10:41 AM
transfer case swap ? saharajeepman YJ Wrangler Technical Forum 1 06-25-2007 07:16 PM
