#31 | |
Thank you guys for the help. I installed a 3500 lb receiver style hitch on the TJ today. One reason was that it is 2 inch and the same stuff that fits my pickup will fit it. I don't intend to tow anywhere near that amount. My aluminum boat, motor and trailer will not weigh much and should not put much of a load on the systems - thanks for the experienced advice and heads up.
[B]2004 Jeep Liberty 3.7L 4WD[/B] |
#32 |
well i towed my samurai with my tj and i plan on trying it again. this time a bit further and higher speed i will let u know how it does..first time it was fine.
2003 TJ - 4.0 - 5 speed - Fabtech front bumper - ORfab rear bumper - SYE - RE 3.5 lift - EGR flares - Ridgid toolbox - 33x12.5 Mickey Thompsons 1988 Samurai - 1.6 - 5 speed - 6" lift - lockrites front and back - 8000 lb. winch - 31x10.5 pro comps - 6.5/1 transfer case - onboard air - dual batteries - etc. etc. |
#33 | |
Using this logic, can you explain why an XJ is rated for 5,000 lbs. but an LJ is only rated for 3,500 lbs?
2012 Jeep Grand Cherokee Limited Mineral Gray / Black 5.7L Hemi ORA2 |
#34 | |
#35 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
