#16 | |
I used to tow a small boat (about 1800 lbs trailer weight) with a 4 cylinder TJ. It wasn't the best tow vehicle, but it did the job. Even the 4 cylinder got it moving, but you could feel the trailer throwing the TJ around under hard braking. My older pickup truck towed the boat much better. As long as you're under the 2000 pound limit, you should be OK, but I'd use the pickup truck if it were me.
#17 |
Any of you guys put boats on your roof racks?
I don't mean kayaks. But Zodiacs or other outboard powered boats? |
#18 |
How about throwing in 8" higher vehicle?
#19 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#20 | |
Semper Fi |
#21 | |
#22 |
My pickup broke down last year right before the start of lobster mini-season, with no time to fix, I bought a $100 hitch for my TJ and towed my 21' center console with a 200 hp motor and a full tank of gas in the boat (68 gallons), 6 scuba tanks, coolers, ice, etc.., and two buddies. The TJ handled like a champ. Granted, I was doing 45-50 mph on the right lane and I NEVER popped it into 5th. Towing it out of the water was easy as hell in 4-hi. Good luck, and a 14' aluminum is nothing for your jeep.
#23 | |
Blue Jeep Club Member #197 '02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift. '94 ZJ - May it rest in pieces. |
#24 |
Like most have already said...you can down 2k lbs. Towing with a SWB vehicle, no matter how much horsepower you have is a bad idea, the trailer will want to try to pass you. If you've ever seen a boat try passing the tow vehicle, its not a calming sight. I've been in a 1 ton LWB van towing a 5,000lbs boat as it tried to go sideways at 60mph, not fun.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#25 |
Trailer Brakes
Okay, so the 2000 pound limit is dictated by the swb, and as I understand the problem, the swb makes it difficult to control the trailer if the trailer starts to steer itself. Now, I also know that when I tow a horse trailer with my truck, I can use the trailer's brakes to correct oversteering from the trailer. If you added brakes to the trailer, could a TJ conceivably, safely, tow more than 2000 pounds?
#26 |
No worries.
1500lbs here, 23 foot boat. (and this is a Warn bumper - it's a heck of a lot beefier built and mounted than any aftermarket hitch.) |
#27 | |
Farm Wheeler
You will hear people talk about towing a 1/2 ton PU on a car hauler from Seattle to Miami and had no problems. Maybe they did but do you really want to set yourself up for failure? The TJ is not designed to be a primary tow vehicle. Using it for light loads such as an ATV, motorcycle, jet ski, ... is fine but for towing heavy loads do it right. Buy, rent, or borrow an appropiate tow vehicle and leave "stupid" for the other guy and hope that you don't run into him on the road. |
#28 | |
Here you go... and again, I know you are running larger than stock tires but still, the stock brakes aren't great and when towing they create even more worry. http://www.jeepforum.com/forum/f9/1-5-weeks-bigger-better-brakes-installed-review-up-297960/?highlight=vanco Oh and don't PM me a warning, I'm not personally attacking you about anything... just pointing out what I believe to be a fact. ![]() |
#29 | |
#30 |
On some aftermarket bumpers e.g. Warn the receiver pocket is too shallow to accept a drawbar shank. This may be intentional to keep one from installing a hitch.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
