post #1 of Old 02-10-2016, 10:04 AM Thread Starter
20jeepster10
TJ Tire Wear....
OK So before I bought new tires I installed my Mopar Rock Crawler Front Bumper, A Harbor Freight 12K winch then I replaced all of the tie rods and went to a well rated shop to get an alignment, They lined it all up and now 5000 miles later I am starting to get some "feathering" on my front tires. the Jeep is still running straight and smooth on the road but I am concerned that my front springs and shocks are now sagging and causing wear from the weight added to the front. (noticeably lower in the front now approx. 1"), is this possible?
any suggestions, i do plan to lift it this coming summer but until then...
2004 TJ Rubicon Stock size tires
192000 miles
Thanks
Dennis
20jeepster10 is offline
post #2 of Old 02-10-2016, 10:11 AM
SHoppe715
Is the feathering to the inside or outside of the tread blocks? That'll tell you if it's a toe in/out problem. With that many miles I'd suspect maybe ball joints? Do you know how many miles on those? The alignment shop should've caught that if they were going bad, but you never know. They might not have lifted the front off the ground to check them.
SHoppe715 is offline
post #3 of Old 02-10-2016, 03:28 PM
TheBoogieman
Disturbed!
TheBoogieman's Avatar
Sagging doesn't affect the alignment.
TheBoogieman is offline
post #4 of Old 02-10-2016, 06:00 PM
biffgnar
biffgnar's Avatar
Net lift height doesn't change toe with inverted Y steering?
Dakar Style Rally Raid in North America: www.sonorarally.com
biffgnar is offline
post #5 of Old 02-10-2016, 06:47 PM
wingless
wingless's Avatar
1994 ZJ
Why not just get some measurement tools, find a level surface and check the alignment yourself.
The tools I use are the Wayne Mitchell Engineering Camber / Caster Gauge and the Manco Wheel Alignment Gauge.
There is one level spot in my driveway and I mark the 20 and straight ahead on the ground, then measure, then adjust as-required.
It is not as easy as tossing someone the keys, but I know exactly how the wheels are set when I'm done.
wingless is offline
post #6 of Old 02-11-2016, 12:39 AM
TheBoogieman
Disturbed!
I've never had to re-align my front toe after adding a winch,heavy bumper or riding fat girls around town. Only had to after adding more lift.
post #7 of Old 02-11-2016, 01:11 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Added weight to the front of the TJ requires toe alignment to compensate for the suspension with the inverted "Y" steering setup...
Knuckelhead is offline
post #8 of Old 02-11-2016, 05:15 AM
TheBoogieman
Disturbed!
Good to know.
post #9 of Old 02-11-2016, 09:44 AM Thread Starter
20jeepster10
thanks for the responses,
the tires are feathering on a angle towards the inside, the drivers side is worse than passenger.
I used a good shop that does a lot of plow trucks etc... they say the ball joints were good and within the spec. i believe its the sagging because i only have about 1"
of travel before hitting the bumpstops, which happens all the time here in michigan with the really bad roads. so i am going to have to replace at least the springs and shocks soon. and i will get a realignment again .
post #10 of Old 02-11-2016, 01:03 PM
TheBoogieman
Disturbed!
Is your RC 4" lift with adjustable control arms or fixed arms? The toe is the only thing that can be adjusted with fixed arms and it takes 10 minutes to DIY.
http://www.4x4xplor.com/alignment.html
You may not post new threads
You may not post replies
