TJ Tech BOOT CAMP: A must-read for new TJ owners/forum members
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series |
#91 | ||
#92 |
No way you fit all that in the jeep. I want to see a picute with all that in it.
#93 |
He may if he has a tow rig and a trailer...then he MIGHT be able to fit all of that.
#94 |
That's quite the list!
#95 | |
-Generator (On the list for when I construct my planned CJ/YJ Project & take it to the the trail on a tow rig & trailer) -Air Compressor (Same reason as generator [above]) -Air tools (no compressor, no tools [once I have OBA I will bring these]) -Air Hoses (See above) -Repair Manual (I don't own this in a paper copy so I don't bring it) -Wiring Diagram (See above) -Spare rear axleshafts (I didn't own these till last week but they will be brought from now on and take up minimal space) -Flares (Don't own) -Hi-Lift (Don't own yet [another Jeeper on the ride does] but when buy it will be mounted on rollbar) -Shovel (Too lazy to pack the coal shovel that would fit perfectly in the tub) -Ax (Don't own) -Gas Can (Don't own) -Winch Accessories (No winch, no accessories) -Most of the medical list (Don't own but i NEED TO BUY. EVERYONE should! They would all fit in a small backpack.) -Camping Gear (Don't camp much when I off-road) Otherwise, I carry the remainder of my list with me. For anyone wondering if they can fit it, here's a picture of everything on my previous list, not mentioned the above, packed in my jeep on my last trail ride. Hopefully you can see that it's below the tub line (best picture I have).
Villanova Wildcat! 2005 Wrangler Sport, 4.0L, 6spd 2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15 HP D30: Aussie Locker, D44: Eaton Elocker Last edited by FarFire70; 11-11-2009 at 11:03 PM.. |
#96 |
Here's a few more pictures I was able to find of what I bring.
After the ride, a close-up of the rear: Up-packed (most of the gear) and yes, it fit (look above): The rest of the gear (tarp, strap, tow bar) (that jack doesn't come, it's for garage use only):
Villanova Wildcat! 2005 Wrangler Sport, 4.0L, 6spd 2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15 HP D30: Aussie Locker, D44: Eaton Elocker |
#97 |
Another addition for you-
http://www.jeepforum.com/forum/f9/so-you-want-tummy-tuck-942018/
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#98 |
Lots of new topics/updates.
04 TJ Willys Edition 41MB-04TJ #4913 The WILLYS Edition Owners Group Your post count does not represent your knowledge, it represents your use of free time. |
#99 | |
#100 |
World Class Painter
http://www.jeep4x4center.com/jeep-service-manuals/index.htm
I don't know if this can be put in or not, but good link to have. |
#101 |
Just a common problem on the TJ's:
The famous intermitant instrument cluster. TJ Jeep Problem with Instrument Guages.
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#102 |
stuff to add to the info resources.
I'd like to know the advantage of a straight long arm lift kit to that of a radius arm lift kit.
Does one allow more articulation than another? Hope I'm not being redundant |
#103 |
#104 |
^^^ Fixed. Thanks!
#105 |
Gone Fishin'
Is there a write up about maintenance on an RH32 automatic tranny? If so, maybe it should be added?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
