TJ Tech BOOT CAMP: A must-read for new TJ owners/forum members
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series |
#76 | |
Dairy Farmer
This thread is awesome, why isn't it a sticky?
#77 |
I know that this is common sense to most... But it would be awesome to have a link about what everything is... For example what a sway bar is/looks like... what control arms look like etc... maybe like a picture looking up from under a jeep with stuff labeled? When I first got my jeep i literally didn't know what anything was or what it did so that would have been very helpful
[CENTER][B][SIZE="4"][COLOR="Black"][URL="http://groups.jeepforum.com/Black_Jeep_Society"]Black Jeep Society[/URL] Member 185[/COLOR][/SIZE][/B][/CENTER] |
#78 |
this needs to be a stickie.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#79 | |
![]() This would be super helpful. What'd also be really awesome is if we had a long list of actual *specifics* - I know when I was researching which bulbs to use for the Dash/HVAC/courtesy lights I had to go through something like 60 pages of threads and even then it was unclear. We need a Jeep TJ Cheatsheet. |
#80 | |
How about a gear list to take when wheelin? I have seen small lists in some threads but that isnt really what the thread is about and they are definitely not comprehensive.
I know there is one in the Charles Wells guide books but I can't find any of mine. And I have been searching the forum for some time with no luck. Maybe someone can type up the list in the Wells book or if I ever find mine I can... It is in my nature to always feel like I am forgetting something anytime I go an a trip, especially wheelin. A checklist would be nice. Example of incomplete list: Quote:
#81 |
One summer I compiled this list that I use when preping my gear before I head out. The medical section is a minimal list at best (and to be honest I don't have all the items listed to take with me yet but that's going to change). It's not all inclusive but the list has served me well thus far.
The first part is a list for me to do before I hit the trail followed by a section I use to check the Jeep before I head on the trip so I'm sure things aren't overlooked. (Some of the items (CB, Winch, etc) are items I don't have yet but will have eventually and want to be sure to check once I do) Upon Arrival • Air down tires • Clutch override (10A fuse in Power Distribution Center #28) • Check fuel level • Disconnect sway bar • Check that gear is tied down Vehicle Checkover Mileage _____________ • Check engine oil • Check transmission oil • Check transfer case fluid • Check brake fluid • Check radiator coolant • Check front differential fluid • Check rear differential fluid • Check power steering fluid • Check windshield wiper fluid • Check lights • Check air filter • Check wipers • Check breathers • Check fan belts • Check hoses • Check seat belts • Check shocks • Check tire air pressure • Check for tire wear or damage • Check spare tire air pressure & condition • Check and tighten lug nuts • Check brake pads & shoes • Check for frame cracks • Check for loose bolts or nuts throughout Jeep • Check for rear main seal leak • Check for proper heater operation • Check CB operation • Check winch operation & condition • Clean & Rain-X windshield & mirrors • Tighten drive shaft u-bolts • Grease all fittings (u-joints, steering, disconnects, suspension) • Check for registration, inspection, & insurance • Check Hi-Lift operation • Check hand throttle operation • Check battery tie downs Notes __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ ______________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ ________________________________ Tools • Multimeter • Wire cutters • Wire strippers • Soldering iron • Wire crimpers • Complete Socket Set (SAE and Metric) (1/4", 3/8", 1/2") • Breaker bar • Torque wrench • Torx sockets • Spark plug socket • 36mm 6pt socket • Allen Wrenches • Combination wrenches (SAE and Metric) • Adjustable wrenches (small, large) • Flat screwdrivers (small, medium ,large) • Phillips screwdrivers (small, medium ,large) • Pliers • Needle Nose Pliers • Vise Grips • Snap ring pliers • Channel-lock Pliers • Pry bars • Rubber Mallets • Claw Hammer • Sledge (3lb, 5lb) • Dead blow hammer • Ball-peens • Punches • Center Punch • Chisels • Files • Wire Brush • Pipe wrenches • Utility knife • Pocket Knife / Multi-Tool • Gasket scraper • MAPP gas & tip • Pickle fork • Saw • Magnet • Safety glasses • Jumper cables • Funnel • Grease Gun • Bottle jack • Jack Stands • Tow Bar & Attachment Points • Lug Wrench • Lug Key • Air Pressure Gauge • Valve stem remover • Siphon hose • Small flashlight • Large flashlight • Fire extinguisher • Generator • Air compressor • Air tools • Air Hoses • Hack saw • Hack saw blades Extras • Ratchet Straps • Gas Can (Empty) • WD-40 • Brake Cleaner (2+) • Throttle Body Cleaner • White Lithium Grease • Dielectric Grease • Anti-Seize • Loctite (Blue & Red) • Duct Tape • Clear Tape • Masking Tape • JB-Weld Metal epoxy • Epoxy • Super glue • Zip-Ties • String • Rope • Bungee cords • Tire repair kits & plugs • Hose repair tape • Cotter pins • O-Rings • Valve stems • Lug Nuts • Extra Valve stem cores • Nuts & bolts assorted standard and metric sizes • Spare wire of various gauges • Electrical tape • Crimp ends • Solder • Relays • Batteries (AAA, AA, C, D, 9V) • Wood blocks • C-Clamps (Various Sizes) • Repair manual • Wiring diagram Spare Parts • Spare Key for vehicle (Left in Jeep on-trail) • Engine Oil (6 qts) • Differential Fluid • Transmission fluid • Transfer Case Fluid • Coolant or Water • Brake Fluid • Power steering fluid • Extra grease cartridge • Spare fuses • Serpentine belt • Spare ZJ tie rod & drag link • Spare differential covers (front & rear) • Spare axle shafts (front & rear) • Spare spider gears (front & rear) • Spare u-joints for drive shaft & axles • Spare u-joint bolts, straps, u-bolts • Spare control arms • Radiator leak stop • Gas tank & Radiator repair • RTV • Spare Hoses / Tubing Recovery • Recovery Straps (2+) • D-rings • Chain • Leather Gloves • Flares • Hi-Lift • Shovel • Ax • Hatchet Winch • Tree saver • Snatch block • Cable Weight Personal Items • Water (1 Gallon/Person) • Cooler with beverages • Bottle opener • Ice and ice chest or cooler • Food - Bring Twice amount needed • Snacks (trail mix, beef jerky, fruits, dry/canned food, etc.) • Anti-microbial hand cleaner • Grease hand cleaner • Trash bags • Paper towels • Tarp • Strike Anywhere Matches • Lighter • Sun block • Chapstick • Toilet paper • Glasses • Extra Contacts • Contact Solution • Contact Case • Full change of clothes • Shoes • Boots • Rain Jacket • Sunglasses • Hat • Towels • Rags • Blanket • Mechanix Gloves • Camera • Camera cards • Binoculars • Cell Phone • Cell Phone Charger • iPod • iPod Charger • CDs • Driver's License • Cash • Credit Cards • Maps (Local Area & Park) • GPS • Weather Forecast • Directions To and From • Local gas stations, parts stores, etc. • Compass • Walkie-Talkies (1 per Jeep) Medical (First Aid Kit) • Band-Aids (assorted sizes) • 4x4 gauze • Ace bandage • Triangular Bandage / re-rolls • adhesive tape • Antibiotic cream • antiseptic wipes • Anti-diarrhea medication • Tylenol • Ibuprofen • Aloe • Burn gel • Snake Bite kit • Hydrocortisone cream (1%) • Benadryl for mild allergic reactions • Bee sting kit • Bug repellant • Disposable Gloves • Instant Cold pack • Instant Hot pack • Scissors and Tweezers • First-aid manual • Safety pins • Thermometer Winter • Jacket • Hoodie • Winter Hat • Winter Gloves • Mittens • Scarf • Boots • Extra Socks Camping • Tent • Sleeping bag • Folding chairs • Backpack/sacks • Tarps • Stove or grill and fuel • Cooking pans • Paper plates • Paper towels • Trash bags • Zip-Lock Bags • Propane Lanterns • Stereo
Villanova Wildcat! 2005 Wrangler Sport, 4.0L, 6spd 2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15 HP D30: Aussie Locker, D44: Eaton Elocker |
#82 |
Excellent list. Some of those thing are a little overkill, and wouldn't recommend taking up precious cargo space with extreme "just-in-cases". If you're pulling a small utility trailer, then by all means, carry as much as you can. I would recommend that everyone use this list as a guideline, as it's the most complete I've ever seen online.
2000 4dr XJ 2WD, 4.0L auto Gone, but not forgotten- 1998 TJ Sport Nightcrew #162 "i'd want a bottle of 12 year old scotch and a 24 pack of rubbers. i'll go places with a hard-on that most people wont go with a mechanized infantry batallion." |
#83 | |
If you don't change your today, your tomorrow will be the same as yesterday. Make the commitment to change your life forever! |
#84 | |
Savvy Off-Road: http://www.savvyoffroad.com |
#85 |
You can fit all that in your jeep?!
#86 |
#87 |
Thanks for all the comments on the list. I can fit it all along with a large cooler and keep it below the tubline. Most of it gets tossed into a few toolbags. Just separate the stuff into the different bags in an order that makes sense to you so that you can go to one bag and know whats in there.
It is a lot of weight though so recently I've been going over the list with the other Jeeps coming on the trip and dividing it amoungst us. We all carry the basics (ratchets, sockets, hammer, screwdrivers, etc) because its always better to have a few around but the more specialized stuff there's tyically no need to bring more than one. Also, always bring your own spares (fluid, shafts, etc) because you don't want to be the person using someone elses that they may need later in the day. Of course if you need a shaft and don't have one, I'll let you borrow one of mine but if I break mine, you better believe I'm taking it back ![]()
#88 |
What hard tops fit my TJ??
http://www.jeepforum.com/forum/f9/tj-hardtops-difference-between-97-02-03-06-a-841036/
Shake & Bake with SHAKEnBLAKE - "Build Thread" www.ohio4x4.com 98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
#89 |
more useful stuff to add:
http://www.jeepforum.com/forum/f9/assistance-identifying-hp-d30-875455/ http://www.jeepforum.com/forum/f9/i-want-run-35s-my-tj-751873/ http://www.jeepforum.com/forum/f9/longarm-basics-879206/ http://www.jeepforum.com/forum/f9/low-lift-high-travel-101-a-869124/ Backspacing/Offset Conversion: ![]() From: https://www.rsracing.com/tech-wheel.html
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 10-26-2009 at 10:37 AM.. |
#90 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
