Quantcast TJ Steering Problem--Wandering All Over the Road!! - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Steering Problem--Wandering All Over the Road!!
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 02-25-2009, 07:34 PM   #1
Snowman01TJ
I have a 2001 TJ with a 3 inch lift and 33x12.50 BFG AT KO's.
I installed the lift 5 years ago and had no problem. I would drive my Jeep 6 hours to Georgia @ 70mph twice a month for the first 2 years after installing the lift and tires and didnt have any problems. Now I would not drive it 1 hour to the beach because I fear I or my wife will not make it home.
I installed a MM 10,500 hydraulic winch 1 year ago. About 6 months ago I noticed the jeep would track or jump all over the road following the ruts or almost loose controll if a big truck passes in the opposite direction. I have changed the track bar, linkage ends, and steering box and no change. I have bypassed the winch and still have the problem.
Is it possible it could be before the steering box in the steering shaft?
Please help and thanks in advance for your input.
Snowman
[COLOR=navy]Blue Jeep Club Member #30[/COLOR]
[COLOR=DarkGreen]Hurricane Jeep Club Member #3[/COLOR]
2001 Wrangler Sport 4.0L
Teraflex 3T
Mickey Thompson Classic II
BFG AT KO 33X12.50
Snowman01TJ is offline   Reply With Quote
Old 02-25-2009, 08:10 PM   #2
fatmanontwowhee
fatmanontwowhee's Avatar
Have you checked your steerig stabilizer?
fatmanontwowhee is offline   Reply With Quote
Old 02-25-2009, 08:34 PM   #3
MoJeeper
Mine wanders all over to..It did it before, and after the lift..I've been told my alingment is off, which I've checked and rechecked,(its was fine) but nothing has made a diffrence. I haven't replaced my steering stabalizer yet, but thats my next option.
99 Green TJ SE
3" Full Traction Lift
4.88's, 33" MT's
My Jeep
MoJeeper is offline   Reply With Quote
Old 02-25-2009, 08:51 PM   #4
brunosplace
Web Wheelin'
brunosplace's Avatar
Check all front end components, including ball joints, tie rod ends, drag link, unit bearings (hubs) there is excessive play in something. I had similar trouble with mine. Thread about it here. Mine was finally cured when I replaced the axle with a hp30 from a 99 Cherokee. I don't believe the original axle was the actual problem, I think it was the unit bearings since the were the only thing that hadn't been replaced already, I just put the axle in since I got it for a steal.
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out
96 Jeep XJ Sport, parted out and scrapped
Tummy Tuck without a body lift. Finished!!
brunosplace is offline   Reply With Quote
Old 02-25-2009, 08:55 PM   #5
durango-bob
durango-bob's Avatar
Start with some diagnostics. Lay under the front of the Jeep and have someone turn the steering wheel back and forth so that you can see what moves and what doesn't. You are looking for the place or places that have movement on one side and none (or less) on the other side. Things like steering gear, drag link ends, tie rod ends, etc. Also, you said that you replaced your steering gear - was it a new one or a rebuilt one that the auto supply stores sell. I have not had good luck with the rebuilt steering gears. Most have had more play in them than the one I removed.
2000 Custom TJ for sale or trade - ready to hit the trails. Check out the profile and PM me for details.
durango-bob is offline   Reply With Quote
Old 02-26-2009, 06:47 AM   #6
unlblkrubi
I've just picked up the "Wander" also lately and it's bugging the hell out of me, can't find the reason either. I think the TRE at the pitman arm is my culprit.
Black '05 LJ Rubicon; 35" MT/R's, Shrockworks bumper & sliders, BDO, Or-Fab cage,RC disconnects and a winch
Yellow '11 JK Rubicon Unlimited
___________________________________________
Member "Rocket City Rock Crawlers" SFWDA, UFWDA
www.rocketcityrockcrawlers.com
unlblkrubi is offline   Reply With Quote
Old 02-26-2009, 06:57 AM   #7
jeepthrill85
A combination of the steering shaft u-joint at the column and alignment issues was my problem. Steering stabilizer should have nothing to do with it, a good stabilizer only masks the real problem.
'85 CJ7 Renegade
'92 YJ SOA on 33's
'03 Rubi Nth degree 4.5" LA 33's
'98 XJ 4" 31's
'08 Rubi unlimited Stock.....for now!
jeepthrill85 is offline   Reply With Quote
Old 02-26-2009, 07:45 AM   #8
wireman508
Check out the welds on your upper control arm brackets at the axle. Mine had broken loose 75% on the upper pasanger side and it was a death trap on the interstate untill 4WP's finaly found the problem after over $1200.00 worth of parts and labor changing out other parts.
Dennis
"97" TJ 4.0L, Auto, 4.10's, 33" Pro Comp Xtreme M/T, Auburn ECTED Rear Locker on D35 w/Alloy USA 30 Spline Axles, Teraflex SYE & CV Driveshaft, 4" Pro Comp Stage II Lift w/4 Link Rear Truss Conversion & MX-6 Shocks, Currie Currectlync Tie Rod/DL, Edge Trail Jammer
& MSD 6 Offroad Ignition and more to come!
wireman508 is offline   Reply With Quote
Old 02-26-2009, 07:53 AM   #9
MoJeeper
I'll take a mask over not finding anything.
99 Green TJ SE
4.88's, 33" MT's
My Jeep
Old 02-26-2009, 07:58 AM   #10
04WranglerX
Truth. A good steering setup shouldn't need a steering stabilizer. This isn't your problem.
04 Silver Wrangler X
Rubicon Express 4.5" SF, RE Monotubes
AA SYE, Tom Woods DS
35" Yokohama Geolanders on black rock krawlers
Dana 44 rear, ARB air locker, cromo shafts, Dana 30 front, 4.88's front and rear.
04WranglerX is offline   Reply With Quote
Old 02-26-2009, 08:01 AM   #11
Dravintoad
Check your alignment make sure it's still good.
Check your track bar and make sure there is no movement especially at the axle end.
Lift the front tires and wiggle them back and forth, up and down to check you ball joints and bearings.
As mentioned before have someone get inside the jeep and turn the steering wheel back and forth, this can help you figure out where the slack is.
Nothing to see here.
Move along.
Dravintoad is offline   Reply With Quote
Old 02-26-2009, 08:13 AM   #12
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Make sure your toe in is set perfectly.
TheBoogieman is offline   Reply With Quote
Old 02-26-2009, 08:19 AM   #13
jeepthrill85
You know it! I'm at almost 300k miles 4" lift with the original stabilizer, basically it's there for looks. Running worn 32's I've got no wandering issues, after I fixed the above mentioned stuff. Bigger tires= faster wear on steering components especially TRE's and hubs.
'85 CJ7 Renegade
'92 YJ SOA on 33's
'98 XJ 4" 31's
Old 02-26-2009, 08:19 AM   #14
TJMunky
maybe you need to also check your control arms and bushings. i have shot rear bushing in the rear and it wanders like you wouldnt believe and it was a lot worse before i replaced the front ones with some poly bushings. check those out as well.
NIGHTCREW (RIP 01/28/09 - 07/22/09) #135
SILVER JEEP CLUB #120
TJMunky is offline   Reply With Quote
Old 02-26-2009, 09:06 AM   #15
goodbri
Both I and my uncle had problems with this. We found out it was the tires. MTs, or any softer rubber tire grips cracks and groves in the road better and can cause your steering to "wander." Putting the winch on added weight to the front end, maybe it just increased the grip of the tires on the road.
Just a thought. Mine wanders a little bit with MTs but didnt with street or ATs.
2000 TJ 3"BDS Susp. - 32"x11.50" BFG KM2's - ORF Rock Rails - Rhino Lined - More to Come...
goodbri is offline   Reply With Quote
Glock Forum
