TJ Steering Problem - JeepForum.com
post #1 of 5 Old 12-09-2007, 06:01 PM Thread Starter
the_cable_guy
TJ Steering Problem
Just installed lift and steering has not been the same. Just driving around town feels fine but when on the highway its kinda scary to drive. Steering feels very sensitive, and when when you hit a bump it feels like its pulling the jeep left or right. Its going in for an allignment later this week should this fix my problem. Also after I put the lift on I took it to a garage and had them check all bolts fo tightness.
Here is a pick of the steering, do all the angles look fine.
2003 Jeep TJ Rocky Mountain, 4" Rough Country Lift wit 1" Body Lift SI12000 Mile Marker Winch
the_cable_guy is offline
post #2 of 5 Old 12-09-2007, 06:19 PM
robncar
robncar's Avatar
Can't really tell from the picture as to steering angle relationships. The trackbar mounts should be parallel to the draglink mounts. If they are not, bumpsteer will likely result. Did you install a drop pitman arm with your lift? If so, and did not also drop the trackbar and equal amount, bumpsteer may result. The alignment on the TJ is rather simple, since it's only toe and then setting the steering wheel straight. You can easily do the alignment yourself:
http://www.stu-offroad.com/steering/align/align-1.htm
http://www.4x4xplor.com/alignment.html
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 5 Old 12-09-2007, 06:25 PM
ediot
Drop pitman arm can give you bump steer which will give you the but also the allignment can cause the problem.
ediot is offline
post #4 of 5 Old 12-09-2007, 06:53 PM
kenabbott
I have read that you should not put a drop pitman arm on a TJ, that it will cause bump steer. Did you install new tires with the lift. When I lifted mine the alignment was the problem I had anlong with the steering stabilizer was loose. With the 33's I have some issues when the are not balanced.
Ken
'06 X with 3.73's, 2" BB, 1" body lift, 33" Pro Comp Xtreme Mud Terrians, Protofab front bumper with PIAA lights, Olympic rear bumper with tire swing, rock sliders, Durabak liner, XRC8 Winch
kenabbott is offline
post #5 of 5 Old 12-09-2007, 09:58 PM
FireMedicZ
Sounds like you have too little caster now. Did you change your front pinion angle any? if so your caster is off now. Take it to an alignment shop and see if your in spec.
FireMedicZ is offline
Steering problem, is this too much? tjwrangler99 TJ Wrangler Technical Forum 47 09-14-2009 08:43 PM
Steering Problem JeepPirate TJ Wrangler Technical Forum 1 12-08-2007 01:02 PM
steering problem Rmen TJ Wrangler Technical Forum 1 04-24-2007 04:51 PM
Steering Problem micfly83 YJ Wrangler Technical Forum 4 01-24-2005 06:39 AM
steering problem pascal TJ Wrangler Technical Forum 1 06-07-2004 01:28 AM
