TJ Steering box leaking - JeepForum.com
post #1 of 21 Old 03-11-2007, 03:56 PM Thread Starter
raskull
raskull's Avatar
A friend of mine has a 97 TJ. His steering box is slowly leaking fluid.. do you think it would be best to find a seal kit and take it apart, or just get a new steering box? I have heard you can use a Durango steering box, is this true? Is there any other steering boxes we could use from a junkyard?
Where can a guy buy one online for a decent price? Quadratec wants almost $400.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #2 of 21 Old 03-11-2007, 04:08 PM
Conundrum
Conundrum's Avatar
Any auto parts store has the stock TJ box for under $200 possibly $150 I believe.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #3 of 21 Old 03-11-2007, 09:03 PM
jeep_chinto
try to find where its leaking from.. when i had mine leaking i was advised to replace it got a new one for a little over 100 bucks , was told if i tryed to rebuild it most likely in short time it would just start leaking again.
jeep_chinto is offline
post #4 of 21 Old 03-11-2007, 09:07 PM
Beaverwrangler
Ya the durango is the way to go.... direct bolt in and better for big tires.
Write up on durango swap
1999 TJ Sport FORD 9" with moser shafts 4.56gears SuperWinch EPi9000 RE 1.75" BB in rear 4wd customs 2.25" BB in front RE discos 1.25" JKS Bodylift Hippolined interior 255/85R16 (33.3x10.2) BFG MT's on 16x8 AR Victor wheels 12" sub in custom built rhino-lined speakerbox/trunk Kargomaster Congocage & Bushman rack
Beaverwrangler is offline
post #5 of 21 Old 03-11-2007, 09:39 PM
miguelitojeep97
mine has been leaking and after JV its way worse. I have heard everyones view on the Durango box and stock. I looked into this also and im not sure its worth that much moeny for a stock durango power steering box. I think your drag link and tie rod will give out before your box does. im no expert and am also curious how well the durango box really works over a stock TJ box. hopefully you can get some good feedback! good luck!
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #6 of 21 Old 03-11-2007, 09:44 PM
rocketman121
miguelitojeep97
so have you replaced your steering box yet
if so did you use the durango steering box or the stock one
-87 XJ 4.0 5spd, 2"BB, 31" BFG ATs on 15x8 Eagle 058s, trimmed and doorless
-01 TJ 4cyl auto FT 3" lift 33" Goodyear AT/S & BFG muds herculined tub
rocketman121 is offline
post #7 of 21 Old 03-11-2007, 09:45 PM
pasadena
pasadena's Avatar
weird, i just did mine today... replaced it with a stock one though, it was only 140 with warranty so i figured what the hell.....
smashed my thumb and have 2 blood blisters....hurt like crap
my steering shock stabilizer bolt stripped....
broke 3 pitman arm pillers before getting smart and busting the torch out...
tons of fun, talk about a day from hell...
but yeah let some pb blaster sit on all the bolts over night before wrenching <it helps with busted thumbs and broken bolts from rust> everything it pretty simple, have fun!
pasadena is offline
post #8 of 21 Old 03-11-2007, 10:00 PM
Mondo
Mondo's Avatar
175 bucks online and 4 hours of work including fluid refill. I am NOT a great mechanic and it installed easy. I also followed a STU Olsen write-up
[/COLOR]Closest thing to a mid-life crisis
Randy Neill
Mondo is offline
post #9 of 21 Old 03-11-2007, 10:44 PM
miguelitojeep97
no have not replaced mine yet. I just dont have any extra cash right now. eventually i will and will for sure when i get 35s.
post #10 of 21 Old 03-12-2007, 05:57 AM
Jonny Jeep
Jonny Jeep's Avatar
I opted to change the seals on mine when it was leaking. Easy enough to do and it hasn't leaked since. Got the seal kit from the dealership.
Jonny Jeep is online now
post #11 of 21 Old 03-12-2007, 06:17 AM
ludvball
The Durango box works well. There are two different Durango boxes. Here is a link to my findings when I performed my swap.
http://www.marylandjeepclub.org/phpB...hlight=durango
ludvball is offline
post #12 of 21 Old 03-12-2007, 09:24 AM
dhenigin
I'm having the same problem. Has anyone had a local mechanic replace it for you? If so, do you remember what they charged for labor? I've been reading about many people that have had trouble with the bolts (and or the nuts welded to the frame) breaking and honestly don't feel like dealing with that...
dhenigin is offline
post #13 of 21 Old 03-12-2007, 09:35 AM
ludvball
If you PB Blast everything real good a day or two before you start the project, you shouldn't have a problem.
ludvball is offline
post #14 of 21 Old 04-03-2013, 04:55 AM
Bilicki2007
Will this swap work on a manual tj?
Bilicki2007 is offline
post #15 of 21 Old 04-03-2013, 09:56 AM
BYuen
BYuen's Avatar
Durango swap works on any pre 2003 TJ.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
Steering box leaking from nut on top... firefighter315 YJ Wrangler Technical Forum 1 11-18-2008 01:22 AM
Steering box leaking xjgnar TJ Wrangler Technical Forum 5 10-30-2008 08:31 PM
Steering box leaking plz HELP!!!!!!! ericcanning TJ Wrangler Technical Forum 2 10-18-2007 04:22 PM
Steering box is leaking xnight TJ Wrangler Technical Forum 9 04-18-2006 10:49 PM
Leaking Steering Box :( Jasonoff TJ Wrangler Technical Forum 3 09-21-2004 03:51 PM
