TJ starter HELP!!!!! - JeepForum.com
post #1 of 15 Old 12-01-2011, 09:12 PM Thread Starter
Jeeper_joe
Hey guys I have a 99 TJ Sahara 4.0l auto and when it's cold outside and I go to start it the starter engages, turns the motor for a split second then I'm guess by the sound shoots past the flywheel and winds up like a starter that's not enguaging and when u let of the ignition u can hear the starter winding down and then "chunk" hits the flywheel again. I have to repeat that several times before it will actually start the jeep. Warm weather or warmed up jeep from driving no problem starts great. What is going on??? I have tryed shimming the starter out quite a bit and nothing seems to help.
The sounds it's making when the starter drive teeth hit the flywheel after it slips loose and comes back into the flywheel are bad and I'm sure it's just a matter of time till things start breaking so I really need some help to fix this issue
Thanks for the help
98 TJ 4cyl, 4" lift ,35s, super 35-lock rite, smitty armed all the way around....SOLD
99 Sahara, 4" lift, 35s, 8.8, 4.56s, Detroit locker......SOLD
Looking for new project
Jeeper_joe is offline
post #2 of 15 Old 12-01-2011, 09:17 PM
Kermit97
1997 XJ Cherokee
Not sure if this is the same issue, but I'll pitch in. my 97 2.5l had a similar problem, turned out the starter was falling off the jeep. Not entirely sure if you have the torx head bolts on the starter like I did on mine, but Harbor Freight has a whole set of sockets just for it. Got mine for $5. I tightened the bolts down, and never had another problem like that...
Good luck dude, starter issues are a PITA.
97 TJ 2.5l-Flinstone floor panel mod--Sold
97 XJ Country- RC X-series 4.5, 33" Kevlars, Nates Slimline
Ronin Wheelers of New England
Kermit97 is offline
post #3 of 15 Old 12-01-2011, 09:28 PM Thread Starter
Jeeper_joe
Nope, the 4.0 has a different (better in my opinion) bolt set upand I've made sure it's all tight, thanks for the input though....
post #4 of 15 Old 12-03-2011, 06:50 PM
wushaw
Rockin jeep
wushaw's Avatar
The starter bendix is shot. Change the starter.
While your at it look at the flywheel teeth and make sure they are still in good shape.
wushaw is offline
post #5 of 15 Old 12-03-2011, 07:08 PM
merkchop
/\ /\ /\ /\ What he said. Sounds like your starter is going out on you, mine is in the beginning stages itself. Good thing is that starters are really easy to change out, just make sure you unhook the battery and don't blow yourself up
merkchop is offline
post #6 of 15 Old 12-05-2011, 08:52 PM Thread Starter
Jeeper_joe
Thank you guys.... Is it cheaper to rebuild the starter or not worth it?
post #7 of 15 Old 12-05-2011, 08:56 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I have a place in C Springs that rebuilds anything DC. Start calling around?... IMO
Knuckelhead is offline
post #8 of 15 Old 12-05-2011, 10:28 PM
Jeepster83
if you can it might help to take a picture or two of the starter gear and the ring gear on the TC.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #9 of 15 Old 12-06-2011, 01:05 AM
playflea
Just buy from autozone. Lifetime warranty. In the last year I've replaced it twice and free lol
playflea is offline
post #10 of 15 Old 12-06-2011, 06:11 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It would only be a lifetime warranty worth getting if they paid you to do the swap. But, if they did that, they would then sell starters worth owning.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #11 of 15 Old 12-07-2011, 06:36 PM Thread Starter
Jeeper_joe
Well looks like a new starter is in my immediate future thanks again guys
post #12 of 15 Old 12-07-2011, 07:33 PM
dcope17
I would want them to pay for my gas and time to exchange the starter... It takes longer to drive to the auto parts store than to change one.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #13 of 15 Old 12-07-2011, 07:54 PM
tjsean0308
D&B auto electric. They are on dean street in providence right by the Providence journal FWIW thats where I got my 135 Amp Alternator from too.
tjsean0308 is offline
post #14 of 15 Old 12-07-2011, 07:56 PM
tjsean0308
quote for truth, autozone part quality sucks.
post #15 of 15 Old 12-07-2011, 08:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You've obviously never watched me change out a starter.
I am Savvy
flywheel , slip , starter
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
Wrangler starter vs. Cherokee starter TallyZJ TJ Wrangler Technical Forum 2 02-09-2011 02:24 AM
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 09:33 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-18-2007 11:35 PM
Cold starter Vs. Hot starter issues Dugrite YJ Wrangler Technical Forum 6 07-27-2007 07:49 AM
