Quantcast TJ Skidplates - Control Arm Mount/Body Mount Skids ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Skidplates - Control Arm Mount/Body Mount Skids ?
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Old 04-26-2009, 01:46 PM   #1
SpaComponents
I'm trying to get my nearly stock '01 TJ armored-up and need to know if control arm mount bracket skids are considered necessary?
how about the body mount skids?
I figure you are bashing the rocks pretty hard to hit the body mounts, but the LCA brackets seem worth protecting?
SpaComponents is offline   Reply With Quote
Old 04-26-2009, 02:31 PM   #2
Pillswoj
I use the Skid Row bolt on Control Arm Mount skids, have seen too many with bent up mounts. Others will Argue that you should just go with weld ons for the mount skids.
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 04-26-2009, 05:34 PM   #3
Unlimited04
Unlimited04's Avatar
i've definitely made good use of my weld-on style control arm skids.
the body mount skids are useful as well...i've only hit my kilby body clamz once tho. better safe than sorry, especially when you see what rock vs body mount looks like.
Unlimited04 is offline   Reply With Quote
Old 06-07-2009, 09:05 PM   #4
LGriffith
Bringing it back since my body mounts are chewed up. Unlimited04, would you give me some pictures of your kilby body mount skids? Thanks, Looks like I need some before I have to get new mounts welded...
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 06-07-2009, 09:16 PM   #5
Unlimited04
^^you can see where I hit that one.
Old 06-07-2009, 09:20 PM   #6
RnEmOvr
Never Forget
RnEmOvr's Avatar
control arm skids are a must almost, they also help keep them from bending, i used to think body mount skids were pointless till i saw my body mounts one day.....
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 06-07-2009, 09:23 PM   #7
Unlimited04
those body mount skids are debris magnets tho. rocks like to collect in the dovetail lips. I avoid mud like the plague, but they would really collect mud bad.
Old 06-07-2009, 09:24 PM   #8
RnEmOvr
Never Forget
RnEmOvr's Avatar
every skid collects mud, you should see how much mud a fram can collect! i clean my frame out last month (hasnt been off road since nov of 07) and the mud was STILL WET!
www.cityprofile.com
Old 06-07-2009, 09:27 PM   #9
Unlimited04
eeeeeeeeewwwwwwwwwwwwwwww. thats why i avoid mud like the plague.
Old 06-07-2009, 09:40 PM   #10
LGriffith
Yeah, my body mounts are reaaally getting bad. Basically only on the passenger side, but all three are bent up. Thanks Unlimited, appreciated.
LGriffith LJ Build
Old 06-07-2009, 11:27 PM   #11
southtxdstroyer
i hate mud too but dammit its soooo much fun
clean up is a ***** but its the most important part of mudding
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant, 'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honor.
open your eyes www.infowars.com
southtxdstroyer is offline   Reply With Quote
Old 06-07-2009, 11:46 PM   #12
armyRN
armyRN's Avatar
At least get a set of weld-on LCA skids. Crawl under your Jeep and look at how thin the stock ones are, and look at how low they are. They're about the lowest thing on your Jeep other than the bottom of the diffs. You'll be hitting your LCA mounts before you hit your body mounts. It's cheap insurance.
armyRN is offline   Reply With Quote
Old 06-07-2009, 11:49 PM   #13
Wrangler_91
So as far as a control arm bracket, are they just basically a flat piece of steel with bent up lips welded on the CA bracket? How thick should they be. My goal this summer is to armor my jeep up as much as possible so I am protected as much as possible for wheelin during college when I will have no money for repairs.
Would 3/16 be heavy enough or should I go on and do 1/4?
Wrangler_91 is offline   Reply With Quote
Old 06-07-2009, 11:56 PM   #14
armyRN
armyRN's Avatar
I had some like these (obviously mine were for a TJ) welded on my Jeep http://www.northridge4x4.com/proddetail.php?prod=JKS-OGS115. I actually got them from Northridge and he welded them on for me at his shop. They're inexpensive, thick, and are already cut, bent, and ready for welding. When we put mine on, we had to tweak one of my LCA mouts with a big hammer before we could weld it on because it was already crooked.
Old 06-08-2009, 07:46 AM   #15
Unlimited04
3/16 is fine. heck the stock mounts are like 1/8" or less. flat won't work because it will interfere with the stock control arms, there needs to be a bend to get them away from the movement of the arms.
Glock Forum
