TJ Skid Plate/Transmission removal-Help! - JeepForum.com
post #1 of 6 Old 09-11-2006, 06:19 PM Thread Starter
n1ml
I need to replace the rear cooling hose to the transmission. It's a 97 TJ 4.0. I tried removing the six BIG bolts on the skid plate and the whole transmission started to come down on me. I put a jack under the plate to support it. Is there a trick to getting that rear hose disconnected? I can barely see it. If the big skid plate was not there, my original idea, I could get to it. It looks like I can't remove it since the transmission is connected to it. I need some advice.
Thanks
n1ml is offline
post #2 of 6 Old 09-11-2006, 06:28 PM
Rocky529
Rocky529's Avatar
Support your transmission with a jack, and then you can remove the skid plate.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 6 Old 09-11-2006, 06:55 PM Thread Starter
n1ml
It looks like the transmission is connected to the skid plate with a motor mount type device. Will this just disassemble by itself or do I need to remove the four bolts that hold the mount to the skid plate?
n1ml is offline
post #4 of 6 Old 09-11-2006, 07:46 PM
gs2offroad
2013 WK
Remove the 4 nuts securing the transmission to the skid plate, support the transmission with a jack, then remove the 6 bolts securing the skid plate to the frame.
gs2offroad is offline
post #5 of 6 Old 09-11-2006, 08:38 PM Thread Starter
n1ml
Thanks. I was surprised when I released the 3 big bolts on the left and the transmission dropped. I noticed the motor mount/transmission mount. Guess i got a lot to do tomorrow evening. Is it acceptable to put a flexible rubber hose where the leak is in the transmission coolant line? Seems like it would be easier than replacing this hard to get at part.
n1ml is offline
post #6 of 6 Old 09-11-2006, 09:27 PM
Michael_K
Michael_K's Avatar
If anyone wants the visuals..
http://www.dailydriventj.com/tcase.shtml
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
Skid plate removal. AmsterDan TJ Wrangler Technical Forum 4 09-08-2008 11:16 AM
skid plate removal Steve and Will TJ Wrangler Technical Forum 7 01-29-2007 12:21 PM
Removal of skid plate on 06' LJ? whitecon TJ Wrangler Technical Forum 2 09-14-2006 04:11 PM
Skid plate removal. taxpayer TJ Wrangler Technical Forum 3 05-13-2005 03:14 PM
03 skid plate removal?? fastfive0 TJ Wrangler Technical Forum 2 09-26-2003 07:54 AM
