TJ sidemarkers - JeepForum.com
post #1 of 3 Old 05-06-2009, 06:58 AM Thread Starter
petersteele
TJ sidemarkers
Awhile back i scraped the side in the front (off road) and later when i was washing it i noticed it knocked the sidemarker piece out. So anyway i ordered a new one and put it in last night, put the lightbulb back inside it etc,...then when I checked it i noticed it wont flash with the turn signal. Same thing with the other side that i havent touched.
Are they supposed to flash?
2004 Electric Lime Green 4.0 Sport/ 1990 Black Mustang 5.0 coupe
petersteele is offline
post #2 of 3 Old 05-06-2009, 07:08 AM
Mike in IL
Yes, on our 04 TJ the blinker and side marker flash together. I just walked out and checked. Maybe a bad ground, since both sides are not flashing, or two bad bulbs. Use a tester and see if you have current to both. Is the blinker flashing? If not, maybe you blew a fuse.
Mike in IL is offline
post #3 of 3 Old 05-06-2009, 07:10 AM Thread Starter
petersteele
Ok thanks for checking yours, i cant get ahold of the only guy i know around here with a TJ. The blinkers are all on and working on both front markers and in the taillights.....hmmm maybe i blew the fuse
Anyone removed their sidemarkers yet? OffCamberTJ JK Wrangler Technical Forum 8 02-27-2007 02:08 PM
Did you install rear sidemarkers with your round LED tails? SteelBlueTJ TJ Wrangler Technical Forum 6 03-02-2006 12:22 PM
