Tj Shaking at idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tj Shaking at idle
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-27-2015, 09:05 AM   #1
Ormston
Tj Shaking at idle
I have a 2005 TJ and it has developed a wicked shake at idle, I have done some work to it in the last week and I will list all below. this shake has developed either as a result of this work or is a new fun problem all together. Perhaps someone can shed some light?
Trans fluid change
transfer fluid change
sparkplug change to NGK v
Tranny mount.
new nutserts on skid plate
banks monster full exhaust .( from flowmaster)
I was thinking perhaps the engine mounts?
Ormston is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 09:34 AM   #2
danielbuck
I would inspect the engine mounts for sure.
Daniel Buck - [URL="http://www.danielbuck.net"]www.DanielBuck.net[/URL] - [URL="http://www.dnsfail.com"]www.DNSFAIL.com[/URL]
danielbuck is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 10:17 AM   #3
Mboelts
Mboelts's Avatar
If you still have the stock engine mounts my question is did you use a poly trans mount? That will cause vibs
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 10:29 AM   #4
Foggy16
I had a little bit of a shake at idle. More of a rough idle. Wasn't sure what it was until a couple of weeks later my fuel pump went out.
Foggy16 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 11:00 AM   #5
Ormston
It is a rubber transmission mount. but it started right after I replaced the mount. I was thinking the combo of new tranny mount and old motor mounts might be the cause.
Unread 03-27-2015, 11:06 AM   #6
airframer
I had a shake at idle once, it also had codes though, it ended up being a misfire, i had a fouled out spark plug. If it started immediately after u changed something i would assume it is because of that.
Everything in moderation
airframer is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 11:17 AM   #7
Ormston
I have no codes I checked yesterday . I figured a misfire but if it was a misfire it would have shown up . thanks for the thought
Unread 03-27-2015, 11:21 AM   #8
airframer
does the shake get worse as u accelerate?
Unread 03-27-2015, 11:22 AM   #9
Ormston
No it goes away as soon as you touch the throttle. runs smooth with normal power and acceleration
Unread 03-27-2015, 11:33 AM   #10
airframer
u you'd think if it where your motor mounts it would get worse as u accelerate.
Unread 03-27-2015, 04:32 PM   #11
NH05
My 05 had a significant shake at idle before I cleaned the carbon out of the throttle body- there is a great DIY here somewhere. Worth a shot before fixing problems you may not have...
NH05 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 01:58 AM   #12
Instigator
I am having a similar issue. 05 TJ 62k and it randomly sputters at idle no rpm movement have no idea what to do. Going to check for carbon build up tomorrow.
Instigator is offline   Reply With Quote Quick reply to this message
