TJ with the shakes - JeepForum.com
post #1 of 3 Old 09-30-2008, 06:36 AM Thread Starter
Dalke-cj
TJ with the shakes
I have a 04 tj wrangler x, with a 4.5" lift from rubicon express. it has 33" traxxes tire. At about 35 mph the front of the jeep shakes so bad that it comes out of gear. we have balanced the tire. has any one had or know how to fix the problem
Dalke-cj is offline
post #2 of 3 Old 09-30-2008, 06:44 AM
REDPILL
REDPILL's Avatar
Search "Death wobble". I don't know all of the causes but, Alignment, tires balanced, loose steering parts, all can be a cause.
JC
Originally Posted by JeepGirl04 View Post
when it doubt... pull it out
Matthew 6, 5-6 Read it, Follow it.
2004 unlimited Yellow
REDPILL is offline
post #3 of 3 Old 09-30-2008, 06:54 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Possible causes listed in order of likelihood:
1. Loose trackbar, worn trackbar bushings, or elongated trackbar mounting holes
2. Tires out of balance
3. Balljoints
4. Unit bearings
5. Tie rod ends
6. Steering box
7. Steering column
I'd start by having someone turn the steering wheel back and forth while you watch underneath for any slop in the steering and steering related parts.
Wheelin98TJ is offline
Yj shakes J-Rad YJ Wrangler Technical Forum 6 03-20-2008 07:55 PM
Shakes Feigle TJ Wrangler Technical Forum 5 03-15-2007 03:04 PM
Help with the shakes! younixguru YJ Wrangler Technical Forum 3 07-25-2006 12:03 AM
got the shakes tat2freke TJ Wrangler Technical Forum 5 11-29-2004 03:14 PM
the shakes Katch TJ Wrangler Technical Forum 8 11-18-2003 09:55 AM
