Tj seat swap? - JeepForum.com
post #1 of 2 Old 07-14-2010, 11:13 AM Thread Starter
Spoons896
Tj seat swap?
Ok so i have been searching for info on what seats can fit in tjs and can only find info on cj/yjs i am wonder if anyone knows what seat can fit in a tj. and i was giving a set of geo tracker seats, has anyone tried putting these seats in?
thanks
Spoons896 is offline
post #2 of 2 Old 07-14-2010, 12:20 PM
cpleasant
cpleasant's Avatar
ZJ Grand Cherokee seats are a direct fit if you use the seat riser from the TJ seats. You will lose the horizontal and raise/lower power functions, but the power recline is easy to hook up and heat (if you do a little wiring work) should work as well.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
tj , wrangler , seat , swap , yj , geo tracker
Swap back seat w/ boat seat kodyharrell YJ Wrangler Technical Forum 9 04-01-2013 06:23 AM
seat swap? 92jeep92 YJ Wrangler Technical Forum 2 12-03-2009 08:48 PM
seat swap help tato1111 YJ Wrangler Technical Forum 4 05-11-2009 05:14 PM
Direct bolt in Seat Swap, 87-89 seat risers different than 90-95 hillside250 YJ Wrangler Technical Forum 8 04-03-2009 03:33 PM
Seat swap Brandon_YJ YJ Wrangler Technical Forum 20 01-29-2009 08:43 AM
