Quantcast TJ Seat Heaters - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Seat Heaters
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-01-2008, 04:49 PM   #1
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
TJ Seat Heaters
It took way longer than I had expected. Mainly because I took the Passenger seat apart and then realized I didn't have to.
the hardest part was unclipping the factory seat cover off of the foam.
Overall it was an easy install.
It came with 2 2way switches High and Low
Pretty much all you see is the two groups of wires that run the heaters that goes from the dash to the centerconsole and then to the seats. They are black so they match my floor.
any questions feel free to ask.
I also painted the underside of the seats because they wern't from the factory.
My girlfriend bought these. There are many many many kits out there. This one has a 3 year warrenty and claims to be waterproof.
http://www.sportsimportsltd.com/pedecafiunhe.html
they claim they are waterproof.
They have the bottom and the back.
Look like this.
I didn't take any photos of the install into the seat because I thought it was so simple.
How I did it.
1. Take out Passenger seat
2. Remove the back clip on the bottom seat part. It's a long plastic clip that fits over the metal frame.
3. Pull up the upper secion cover. In my seat it had 2 metal bars to hold it in place. I pulled it up until there was a horizontal metal bar.
4. After that, I used the supplied Duct Tape to hold them on the vertical piece of the seat.
5. Pull the upper cover over the heater and put the clips back
6. Slide the lower one in as far as you can and I taped it only in the back. It wasn't going anywhere. There are 2 more metal bars that keep it going side to side and another on in the front. I used the supplied tape to hold the back down.
7. Pull the cover back over.
8. Pull the dash apart. On my 03 I used the blank square next to the 4 blank factory switch locations. I drilled 2 holes in the square. The directions said 5/8" bit but it was much larger. I went with the directions and didn't measure the switch itself. I didn't feel like going back to the store to get another bit so I just used the bit I bought and the dremel to make it larger. I used a wood bit and took it slower. Wood bit price 3.99 Regular bit 18.99
9. after all that I attached the wire to my aux fuse block I had put in a while back. both of the heaters are on the same fuse and I didn't use the supplied inline fuse that they supplied since I used the fuse in my fuse block. I also ran a ground wire for the system.
10. After running all the wires I put the passenger seat back in to check the wiring before I finnished up the wiring.
11. for the driver side use steps 1-7.
I had taken the passenger seat apart about 10 bolts out and then realized I didn't have to take any out. Overall it took about 45 min per seat including taking it out and putting it back. The hardes part was getting the clip back.
The directions were there. I skimmed them, but I knew how I wanted them. For someone who had no idea on how to do it, they would be helpful.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 01-01-2008, 04:55 PM   #2
JeepRocks86
The main wire taped together. Drilled and screwed the clip to the floor
switches. Left to right. Reverse, Front KC, blank, Air compressor, Driver heater Passenger Heater
My Build Thread.
For Sale:
Old 12-05-2008, 12:41 PM   #3
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
How does it work for ya?
hm. how is it you have no ashtray, and two power outlets? wtf. i want that.
ಠ_ಠ
LoneJeeper is offline   Reply With Quote
Glock Forum
