TJ Rubicon rumbling rear end noise at 50mph - JeepForum.com
post #1 of 6 Old 07-01-2010, 09:30 AM Thread Starter
Ghostwatcherz
Need some help on this one. I am looking to buy a used 2004 Rubicon.
Lifted with 6in lift, 35inch tires and a few other mods. While driving, when I get to about 45mph through 60mph, the rear end has a terrible vibration that sounds like "vruum, vruum, vruum..."
It sounds like a drive line problem, because when I take my foot off the gas, it stops instantly. So I knew it wasnt the tires or axles. It ONLY happens when you are driving with the gas pedal depressed.
My concern is, the jeep is quiet at 55mph when I take my foot off the gas, but making loud noises every other second, like a rotational noise (loud) when the gas is applied.
Any ideas??
Ghostwatcherz is offline
post #2 of 6 Old 07-01-2010, 09:36 AM
rob78
Check your driveline angles. I'm betting the PO didn't and now you've got vibes. Depending on how long it's been going on you may need new ujoints.
I'm assuming this is a 6" long arm lift? If its a short arm, I'd run not walk away.
And no offense, but I will not buy a used lifted Jeep. You just don't know what kind of knucklehead did the work (disregard if you know the knucklehead to is experienced with Jeep suspension and drivelines).
rob78 is offline
post #3 of 6 Old 07-01-2010, 09:43 AM Thread Starter
Ghostwatcherz
How (by visually looking) can I tell the diff between a long arm and short?? I think the guy did it professionally, it was his third Jeep and he has a rock crawler now, this was actually his wifes jeep, and they did go off roading, but nothing major. Is this something any major shop can check out, or should I bring to a jeep facility? (I work at a Ford dealer, but have NO mechanical experience myself.. haha) (
post #4 of 6 Old 07-01-2010, 05:09 PM
pumpman55
are ya still using the factory tc skid. that pulsating harmonic is common with the auto trans
pumpman55 is offline
post #5 of 6 Old 07-01-2010, 05:46 PM Thread Starter
Ghostwatcherz
Not sure what I am using, as I mentioned earlier, I just got it and have no idea what the previous owner did. It is exactly a pulsating harmonic! Thats the best way to describe it... Now how do I fix it??? haha
post #6 of 6 Old 07-03-2010, 08:25 AM Thread Starter
Ghostwatcherz
Ok, I spoke with a few Tech's and most seem to think it is probably not the U-Joints, but maybe a Diff problem... Now the fun starts.
tj , wrangler , rubicon , noise , rear end , driveline , accelerating
Rumbling noise from back of Jeep Cards89YJ YJ Wrangler Technical Forum 11 02-17-2010 09:07 PM
Low rumbling noise at end of braking/beginning of acceleration 06BlackRubicon TJ Wrangler Technical Forum 6 12-29-2008 03:45 AM
Transfer Case "Rumbling" Noise fire239 TJ Wrangler Technical Forum 16 11-25-2008 08:56 AM
06 stock Rubicon ..noise..rear right wheel area Bobbydeuce TJ Wrangler Technical Forum 1 04-08-2008 01:00 PM
clanking/rumbling noise from 1998 TJ stewski695 TJ Wrangler Technical Forum 6 04-02-2005 09:53 PM
