TJ Rubicon front axle C braces: Where can I buy prefabbed C brace? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ Rubicon front axle C braces: Where can I buy prefabbed C brace?
Dana 30/ Dana 44 Chromoly shaft Kits- ECGSFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201
Unread 10-24-2010, 04:00 PM   #16
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by btn View Post
When you say the rig was in 3 wheel drive, do you mean only one front tire was doing all of the pulling in the front end and that is what stressed the ball joint hole? In other words, if both front tires are being driven, the hole shouldn't see enough stress to oval out?
One front was pulling. We had a winch on the other side to help the dead tire up onto stuff. Gently of course, but where we play, 3 wheel drive will not get you over the trail.
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote
axle , c brace , prefabbed , rubicon
