TJ rocks side to side - JeepForum.com
post #1 of 5 Old 08-14-2011, 11:23 AM Thread Starter
PCBrown
I have an 05 TJ w/ stock suspension, 31x10.5 and offset rims. At around 50mph, the jeep starts to sway side to side and if you approach near 70 it gets more pronounced and scary. For some reason, it is more noticeable with 2 people in the jeep. It is not the death wobble, steering is true, no shimmy. I have had it aligned, tires balanced. This is my 3rd TJ and I have not experienced this with any other. Has anybody had this problem?
PCBrown is offline
post #2 of 5 Old 08-14-2011, 11:49 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
How are your shocks?Are your front & rear sway bars connected and tight?
GOLENJEEPTJ is offline
post #3 of 5 Old 08-14-2011, 01:15 PM Thread Starter
PCBrown
Thanks for your response GOLENJEEPTJ. Shocks seem fine. I have not inspected the sway bars and really don't know what I'd be looking for. I recently bought this jeep, last one I had was a 98 and never had this issue.
PCBrown is offline
post #4 of 5 Old 08-14-2011, 01:20 PM
LJameson
Check your bushings and everything in the suspension for play. Also, what kind of tires are on it?
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #5 of 5 Old 08-14-2011, 01:22 PM
TheDodson
Check out your sway bars and also check out your track bar bushings, control arm bushings too!
This is my jeep. There are many like it, but this one is mine.
TheDodson is offline
front shackle and axle movement when turning wheels side to side shabakand YJ Wrangler Technical Forum 5 11-08-2010 11:22 PM
Driver Side Side Marker and Turn Signal Corroded JeepnBlake TJ Wrangler Technical Forum 3 11-29-2009 10:27 AM
Jeep not level - Side-to-Side - New 4" Lift Installed mezer TJ Wrangler Technical Forum 12 03-19-2009 09:06 PM
60+mph and body only rocks side to side, but steering is perfect... fromme TJ Wrangler Technical Forum 6 09-17-2007 12:07 PM
pass side still sits 1/2 lower than drivers side even after new springs alex71 TJ Wrangler Technical Forum 3 03-31-2006 02:46 PM
