TJ Rear End/Differential Help (sahara edition) - JeepForum.com
post #1 of 2 Old 03-07-2011, 03:40 PM Thread Starter
rddj91
okay, i did it good guys! jumped both feet in and had to stop quickly!!
well noticed grinding popping in my rear end, got brave pulled the cover off and started inspecting. didnt notice anything at first. I took the main caps off (left and right) and set them down. rolled my creeper back and moved them. i do not remember which is left or right and what needs to go up or down. i figure these are one of those "one right way" to do things, so i need a little help distinguishing between the 2... apparently it is the d44 with track-lock, i think. i read the numbers off the cover to the guy selling me parts and he said that.
also i figured out i ruined my spider gears and have never seen the inside of a rear axle so any tips and tricks would be greatly appreciated for installing new spiders in a jeep tj sahara..
rddj91 is offline
post #2 of 2 Old 03-07-2011, 04:57 PM
steviej35
Junior Member
steviej35's Avatar
Had the same problem with mine as well. Rebuilding a Trac loc was a hard decision to make. Kit to rebuild it cost alot of cash....ended up buying a open carrier and a lockrite to replace it for $200 vs the trac loc rebuild kit from 4wd for like $300 plus shipping
steviej35 is offline
axle , differential , rear end
Sahara Edition Jenia YJ Wrangler Technical Forum 8 05-29-2009 04:20 AM
Rear Differential question on Sahara and X driley JK Wrangler Technical Forum 3 11-20-2006 11:18 AM
Sahara Edition? bruker TJ Wrangler Technical Forum 16 09-10-2006 08:03 PM
Sahara Edition JK JurassicMan JK Wrangler Technical Forum 19 07-29-2006 07:44 PM
What is the Sahara Edition? Negative6 TJ Wrangler Technical Forum 4 02-01-2005 08:16 PM
