TJ rear disc brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ rear disc brakes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW!! HMF 50"-52" light bar mounting brackets!! Year End Clearance Sale! Save 20%
Unread 12-18-2014, 06:00 PM   #1
durangoroadboss
TJ rear disc brakes
Hi Folks - has anyone installed disc brakes on a rear TJ factory 44 and had interference issues with the calipers? I am wondering if my rear wheels (Hutchinson Rock Monster 15" bead locks) will clear the calipers. Any ideas on the minimum required inside wheel diameter? Or which kits might give me the most room? Thanks.
Richard
durangoroadboss is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 06:22 PM   #2
88hatchy
Ther is no reason to switch to rear disk brakes.
1997 TJ - Current project: Simple build --> LCG, 35s
1988 Civic Hatch - Runs 12's, gets 30 mpg
88hatchy is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 06:29 PM   #3
willis36
willis36's Avatar
There are many reasons to switch to rear discs, how important those reasons are is up to you.
willis36 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 07:00 PM   #4
88hatchy
I'll wait for Jerry to chime in.
Unread 12-18-2014, 09:17 PM   #5
mrblaine
Wizard of Brakes
mrblaine's Avatar
No need. There are lots of valid reasons to swap to rear discs, better braking however, isn't one of them.
Maintenance is easier.
Parking brake typically works better because there isn't a primary and secondary shoe.
No adjustment ever needed.
Working on them is far easier even the parking brake aspect.
Parts are actually cheaper in some instances.
Pedal height is no longer based on how well the rear brakes are adjusted and remains constant throughout the life of the frictions.
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote Quick reply to this message
Unread 12-18-2014, 09:31 PM   #6
willis36
willis36's Avatar
Those are all the reasons I was thinking, and why I will one day pony up for a disc conversion.
Unread 12-18-2014, 10:34 PM   #7
geroux
They clean themselves better too.
Rear disk was one of the several reasons I bought a Rubi. I love not having to deal with drum brakes again (except my wife's SUV).
Just a thought, wonder if a Rubi's disk setup could be found at a junkyard and bolted on? Cheaper than a "new" upgrade kit?
I have 15" wheels on my stock rear disks.
geroux is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 11:16 PM   #8
durangoroadboss
Hi guys, thanks. My 1999 TJ has 35s and I use it mostly off road. I have noticed a real problem stopping when rock crawling down very steep inclines - I pretty much have to push the brake pedal as hard as I can to get the jeep to stop on steep rocks. The emergency brake never seems to hold the Jeep very well either (I've adjusted it a few times). I've owned the Jeep since new, and front and rear brakes are in good condition - the Jeep only has 16000 miles - almost all off road. Maybe I'll look into the stock rear discs. Any other suggestions? Thanks.
Richard
Unread 12-18-2014, 11:30 PM   #9
J03_TJ
J03_TJ's Avatar
Originally Posted by mrblaine
No need. There are lots of valid reasons to swap to rear discs, better braking however, isn't one of them. Maintenance is easier. Parking brake typically works better because there isn't a primary and secondary shoe. No adjustment ever needed. Working on them is far easier even the parking brake aspect. Parts are actually cheaper in some instances. Pedal height is no longer based on how well the rear brakes are adjusted and remains constant throughout the life of the frictions.
So you'd be the guy to ask, what advantage(s) would drums have over disks?
J03_TJ is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 12:55 AM   #10
btn
One thing is that drums are self-energizing, unlike disks. I'm not sure if it's as a rule, but they can be lighter, and they don't cause drag when the breaks aren't applied as disks can.
2000 TJ, 4.0L, 4" short arm suspension lift, 35" tires, Rear D44 and front HP30 both with ARBs and chromo shafts, NV3550.
btn is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 01:05 AM   #11
ian_red-zj
Originally Posted by durangoroadboss
Hi guys, thanks. My 1999 TJ has 35s and I use it mostly off road. I have noticed a real problem stopping when rock crawling down very steep inclines - I pretty much have to push the brake pedal as hard as I can to get the jeep to stop on steep rocks. The emergency brake never seems to hold the Jeep very well either (I've adjusted it a few times). I've owned the Jeep since new, and front and rear brakes are in good condition - the Jeep only has 16000 miles - almost all off road. Maybe I'll look into the stock rear discs. Any other suggestions? Thanks. Richard
Have you tried bleeding them? And going downhill most of the inertia is transferred to the front, so maybe you just need bigger brakes with those 35s
ian_red-zj is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 02:24 AM   #12
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
And no brake fade after a water crossing...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 07:27 AM   #13
biffgnar
biffgnar's Avatar
You aren't going to find any Rubicon axles in a JY to pull the brakes from. Explorer discs though can be converted over.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 12-19-2014, 07:29 AM   #14
biffgnar
biffgnar's Avatar
Richard
Not uncommon with 35s. Rear discs aren't going to help. You need upgraded brakes overall. Look at Vanco Big Brake kits. Not cheap, but being able to stop well is important.
Unread 12-19-2014, 08:16 AM   #15
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes, but I'm not sure that is a benefit or a detriment. It is just the nature of drum brakes.
The reason discs are so prevalent is they are almost always lighter in the same application. If either is dragging, something is wrong and needs fixed.
I am Savvy
