TJ rear dana44 and Rubicon dana44 difference - JeepForum.com
post #1 of 11 Old 05-29-2006, 05:41 AM Thread Starter
jappe
What are differences between these two. I order superior dana44 kit
with 33 splines and detroit locker. It seems to fit both axle housing.
But other parts. I have TJ style dana44 housing.
Is there differences and what they are?
Just do it
jappe is offline
post #2 of 11 Old 05-29-2006, 06:00 AM
cincytj
cincytj's Avatar
you should call them before you order, I believe the stock TJ d44 has 30 spline axles and the Rubi has 33 spline. If you are ordering a carrier too then you will get the 33 spline so it wont matter.
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #3 of 11 Old 05-29-2006, 07:03 AM
otisdog
2008 WK
What you are getting is the Super 44 kit and will fit your housing. It also would fit a Rubi 44 but would need extra shims to set up. The housings are machined a little different. Basically a Rubi locker will not fit a regular TJ 44 housing without machining the housing - but non-Rubi lockers etc will fit the Rubi housing with extra shims.
Both have 30 spline axles and the 33 splines are an upgrade. You must have a 33spline locker and the axle bearings,seals etc to make them work. The Super 44 kit is similar to the Super 35 kit.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #4 of 11 Old 05-29-2006, 08:16 AM
robncar
robncar's Avatar
Right on the money, otisdog! I just went through this myself last week. Although I have a 2005 SPORT with Dana 44, it turns out it's a RUBICON 44!!! I learned this when the gear shop called (I'd supplied the parts) and told me I'd need two more shims. It seems that on a Dana 44 option you can get a Rubicon axle from DC in a non Rubicon TJ.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #5 of 11 Old 05-29-2006, 08:22 AM
foreman1063
foreman1063's Avatar
Robncar, I had the same issue when I re geared my 04 D44. The shop told me I had a Rubi 44 housing in my sport which required extra shims. Guess they ran out of regular 44 housings.
foreman1063 is offline
post #6 of 11 Old 05-29-2006, 10:24 AM
nhlbill
nhlbill's Avatar
2015 JK Wrangler
Yep that is true for 04-06 Sports. The D44 housing is the same housing as the Rubi D44 housing. I too ran into this issue when trying to buy some additional shims so that I was sure I had enough to do my swap. I took out one of mine and took it down to 4WP and compared them to the ones they were trying to sell me and they were way larger than the ones 4WP had. So we compared a Rubi kit and the shims were the same size.
There is a 1/4" thick shim on the sides of the carrier to make up the difference (it looks weird for sure).
If your taking out a Rubi locker (which I have never seen BTW) and putting in a Detroit, you may need those carrier spacers and I don't know if they come in a normal master install kit....I would check into that FWIW
Gone but not forgotten:
05 TJ Sport
RK 5.5" Long Arm, 1" Daystar BL
M.O.R.E. Bombproof 1" MML
AA SYE, RE CV Driveshaft
4.56's, ARB Super 30 Front, Detroit D44 w/Alloys Rear
35" BFG MT's
RK X-Factor steering, Currie Anti-Rock,
Nth oil pan skid, Rock Crusher Diff covers
Line X
OBA (Viair 450c System)
Trail Gear Rockers
Custom rear bumper/swing out
nhlbill is offline
post #7 of 11 Old 05-29-2006, 11:18 AM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
The Rubi shims won't come in a normal shim kit you need to ask for them specifically. IMO the Rubi housing is a much better design for setting up. You don't need to remove the carrier bearings to change shim arrangements. Randy's Ring and pinion carry the Rubi shims in assorted thicknesses.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #8 of 11 Old 05-29-2006, 02:09 PM
TheDuke05
TheDuke05's Avatar
Is this only for Sports or all 04-06 D44's? I have a Rocky Mountain Edition (X with D44) and will be regearing soon.
"You don't have to flaunt your sucess, but you don't have to apologize for it, either"-- Gene Stallings
Sold my Jeep earlier this year. Kinda miss it but I love my Infiniti.
TheDuke05 is offline
post #9 of 11 Old 05-29-2006, 02:29 PM
nhlbill
nhlbill's Avatar
2015 JK Wrangler
I think it probably applies to all 04-06 D44 housings, but I have a Sport so I know my 05 Sport has the same housing. You will know by taking off your cover and seeing the wide spacers/shims. There is probably another way of telling by the axle tag or some other manner of identification, but I'm not 100% sure. It might have even been 03-06. HTH
05 TJ Sport
35" BFG MT's
Line X
Trail Gear Rockers
nhlbill is offline
post #10 of 11 Old 05-29-2006, 11:24 PM Thread Starter
jappe
Ok Rubicon needs extra shims.
One more question. Is there diffrence with gears, when use Detroit Locker?
Is ring and pinion same in Rubicon and normal rear d44 with Detroit Locker?
Just do it
jappe is offline
post #11 of 11 Old 05-30-2006, 12:25 AM
Airbug
does this mean i can buy the rubicon locker from jeepsareus and stick it into my 2004 D44 housing? I kinda want the rubicon locker because it has a limited slip when it's not locked.
Airbug is offline
TJ and Rubicon TJ rear dana44 difference jappe TJ Wrangler Technical Forum 5 01-02-2006 04:34 AM
Question-rubicon dana 44 rear-4.10 fit standard tj rear dana44 rytrac TJ Wrangler Technical Forum 3 09-04-2005 01:44 AM
Where to get a Dana44 82CJ7 TJ Wrangler Technical Forum 3 02-23-2005 09:43 PM
Rear Dana44 with 3.07 gears !!! pascal TJ Wrangler Technical Forum 3 05-28-2003 07:29 AM
