TJ Rear bucket seats? - Page 2 - JeepForum.com
post #16 of 19 Old 09-05-2008, 07:42 AM Thread Starter
Marauder_Pilot
Marauder_Pilot's Avatar
Originally Posted by busterandnitro View Post
Try this: Ask the person riding in the back seat to hold whatever cargo you want to take with you. If they don't want to, tell them to get out. haha
See, I would, but I don't feel like being an ******* to my friends.
Marauder_Pilot is offline
post #17 of 19 Old 09-05-2008, 10:40 AM
xjandyj
i cut up a rear seat for my yj,,,got the seat for 20 bucks on craigslist and then it was just work,,,im sure if you wanted it to be perfect you could bring it to an upholstery shop...tj seat modding should be the same,,,now i just use the single seat,but still have the original one in case i need 4 seats total
http://www.jeepforum.com/forum/f12/yj-rear-seat-mod-3-seater-yj-527420/
xjandyj is offline
post #18 of 19 Old 11-17-2008, 10:50 PM
NORCALROOTS
Hey,
I've looked exhaustively for an off-the-shelf solution to replace the rear bench seat of my 1997 TJ with a single bucket seat but haven't found anything. I've been hunting for TJ seats on Craigslist and finally found a set in Santa Cruz, CA. The seller was awesome and I bought the pair for $75. My intention is to bolt the better of the two seats down to the driver's side of the vehicle. I had originally intended on mounting the seat in the center but wanted to take advantage of the shoulder strap and maximize storage so I opted for the off-set seat placement.
In order to create the strongest anchor point, I intend on dropping the gas tank and bolting 1/4" steel rails on the underside of the vehicle to displace as much of the weight over the sheet metal of rear floor. I'm doing this more because I've been told this is the "safe" thing to do but I'm unclear how a bolted seat would pull through the seat metal. I'm assuming the thinking is that during an accident a person would create enough friction to pull the seat out but if they have their seat belt on, how would they move in a direction to pull the seat out? Either way, I'll err on the side of caution and use the re-enforced railings.
My guess is this will be a very involving all-day project (8+ hours). Since I'll have the gas tank dropped, I intend on replacing/fixing the fuel sending unit (the current unit does not relay correct fuel level).
My biggest concern is that there is no room between the fuel tank and the underside of the rear floor to allow for the 1/4" steel rails and bolts. If anyone has implemented this mod or can shed some light on the spacing below the gas tank, I would greatly appreciate your feedback.
I'll plan on taking photos along the way and posting a write-up post-project.
NORCALROOTS is offline
post #19 of 19 Old 11-18-2008, 11:58 AM
BlueFlame
BlueFlame's Avatar
Originally Posted by NORCALROOTS View Post
Hey,
In order to create the strongest anchor point, I intend on dropping the gas tank and bolting 1/4" steel rails on the underside of the vehicle to displace as much of the weight over the sheet metal of rear floor. I'm doing this more because I've been told this is the "safe" thing to do but I'm unclear how a bolted seat would pull through the seat metal. I'm assuming the thinking is that during an accident a person would create enough friction to pull the seat out but if they have their seat belt on, how would they move in a direction to pull the seat out? Either way, I'll err on the side of caution and use the re-enforced railings..
I can imagine. Seen it.
Imagine the jeep hitting a tree at 50 mph. It stops instantly. The rear seat just bolted through the tin floor - bolt heads pull right out- instantly, and the seat (and occupant if so equipped) continue heading for the windshield...
Adding some flat plate under the floor is smart - as large an area as possible.
Let me show you something by way of example - in the pic below - notice the Warn M8000 next to the cop on the right?
It was secured in the truck bed. A receiver like this one http://g-ec2.images-amazon.com/images/I/4149CG9DDEL.jpg was bolted to the rear fender well, with a piece of 3/16 steel about 4x8 for a backing plate. The multi mount winch was stored on that, with a hitch pin to secure it. A very safe installation. In the accident, the winch and mount ejected through the roof, over the cab, hit the semi and bounced back to where you see it in the photo. It took a 4x8 section of the fenderwell with it!
Such are the forces unleashed during accidents.
(In case anyone wonders, that old Yota belonged to my father. He survived, but only by the grace of God and some incredible gifted first responders, a helicopter ride, and a well equipped hospital. But he's never been the same...)
BlueFlame is offline
tj w/ rear oem bucket seats chrisschumm TJ Wrangler Technical Forum 44 05-28-2013 10:45 AM
Anyone ever put bucket seats in the rear of their TJ? jeepfreak4x4 TJ Wrangler Technical Forum 4 06-28-2009 10:16 AM
REAR Bucket seats in a Wrangler!!! natemclean93 Wrangler General Discussion 0 05-26-2009 08:48 PM
Bucket Seats w/ Harness in Rear? 4desertfam TJ Wrangler Technical Forum 7 05-21-2009 07:33 PM
Rear Bucket Seats lucky00 TJ Wrangler Technical Forum 12 05-20-2007 09:24 PM
