TJ Rear Brake Adjustment Problems Solved, Once & For All!! - Page 2 - JeepForum.com
post #16 of 36 Old 05-09-2010, 01:20 AM
wushaw
Rockin jeep
wushaw's Avatar
Interesting....never had that problem, brakes always worked as advertised, never had to adjuse them either. Glad you found your problem.
wushaw is offline
post #17 of 36 Old 07-17-2010, 10:09 PM
baldeagle1
I realize this is an older thread. But, I am putting together a D35 with 4:10s. Hav also a 8.8 but not the funds to put it together at moment. Anyway, I understand the overtravel spring needs to be turned around. My quest is what would that have to do with how it works? Looks to me like it would do the same thing either way. help me to understand please? Please dont take this as me being a smart a##. Just tring to fiqure it out. Thanks so much
baldeagle1 is offline
post #18 of 36 Old 07-18-2010, 10:11 AM Thread Starter
Beavx
Beavx's Avatar
when it is installed the way the illustration shows, there is no room for movement. If you install it incorrectly, it will have too much play allowing the adjuster lever to move away from the gear thus coming out of adjustment.
Hope that helps. Good luck with the build.
Daily Driver:
1997 TJ, Stock, 1" BL, Western Plow
15" American Racing Steelies, 31x10.5 Hancook RF10's
Previously owned '87 YJ, 4" Rough Country,
33x12 BFG AT/KO's, Hummer Recovery Vehicle
Beavx is offline
post #19 of 36 Old 08-08-2010, 03:22 PM
nitecop
Note if your springs are worn when you flip it around correctly it makes almost no difference as I found out today.
A new adjustor kit with cable and spring and I'm as good as new.
I had this peoblem for years and it is very easy to over look. mine is fixed now.
Thanks to the OP
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #20 of 36 Old 08-08-2010, 05:30 PM
vanillathrilla
Thanks for the tips. I've been wanting to fix mine since I got it. It's terrible!
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #21 of 36 Old 07-30-2012, 06:36 PM
cowboys666
I know this is an older thread,gonna revive it...gonna see if it works for me,been having this problem for awhile.
cowboys666 is offline
post #22 of 36 Old 07-31-2012, 12:43 PM
ImaginaryFriend
ImaginaryFriend's Avatar
Since you revived the thread, I'll post up a pic that shows what I believe the OP was trying to explain.
Note the position of the spring, spring plate, and adjuster lever.
ImaginaryFriend is offline
post #23 of 36 Old 07-31-2012, 01:21 PM
Diverdown87
Since you are going to have your 35 apart why not do the junkyard disc swap??? You can get all the parts off a ZJ for dirt cheap. Even if you use the calipers as a core for new ones you will never really have to worry about adjusting or dealing with drum brakes again...
No real performance gain more of a luxury item.
My idea of help from the man above is a sniper on the roof.
Diverdown87 is offline
post #24 of 36 Old 08-07-2012, 03:58 AM
aussieTJ-06
had the SAME PROBLEM! got new drums new shoes new springs/kit all bendix F*ck still wouldnt work
BUT when i read "if you can put em on by hand your way out".............. YOU WERE RIGHT! im no fool but after adjusting the star heaps (with my mechanic mates helpin) i decided to pull it all apart again have a good look and yep i was going the wrong way apparently jeeps love being arse about!
but after a good spin and a tweak im back in the game thanks dude!
aussieTJ-06 is offline
post #25 of 36 Old 10-22-2012, 08:19 PM
dobeluvr
thankx for the picture, I was doing the brakes tonight, and the cable was broke on that piece. The captured spring assembly was just lying on the bottom, so I had no idea where to put it. The other end was easy, lol, it was still under the springs at the top. (both sides were the same, so whoever did the brakes in the past had them backwards).
dobeluvr is offline
post #26 of 36 Old 10-22-2012, 08:42 PM
DevilDogDoc
After almost 3 years of messing with the drums on mine, adjusting all the time this is how I solved my issues.
Thanks again Blaine!!!
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #27 of 36 Old 12-13-2013, 01:18 PM
CO_crawler
Originally Posted by ImaginaryFriend View Post
So are you saying this is set up incorrectly?
(not my picture)
I don't see anything in the FSM that says how to set it up one way or another.
Is this the right way to set up the hook? Cheers then, CO
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #28 of 36 Old 12-13-2013, 05:43 PM
ImaginaryFriend
The correct position is show in my picture above.
post #29 of 36 Old 02-22-2014, 03:26 PM
Gordon-0
Since this thread pops up at the top of google when searching for brake problems, I think I am going to revive it to clarify and re-iterate some information, as well as post a bit about a problem I recently had.
How to install the adjuster
The adjuster needs to be installed with the end of the spring out, and the plate flush against the outside of the adjuster like this
that's a bit blurry, but in order to accomplish that you need to slide the "hook" of the adjuster into the spring here
like this
you should end up with something like this
then simply place the assembly over this pin and spring as normal
Now on the the problems.
I ordered the complete hardware kit from RockAuto, and installed it, but after driving around a while, there was a grindy noise that wouldn't go away.
I figured it was brake drum adjustment, but no matter how i adjusted them, it never stopped.
Only once i saw this thread did the problem become apparent.
old adjuster plate vs new one
oops
****, this ain't good
pn is 5062
this part will have to be either ground down to work, or simply use your old one, if it is in good shape.
I called RockAuto and they are sending me new drums.
Gordon-0 is offline
post #30 of 36 Old 02-22-2014, 06:12 PM
redvett94
Your problem is you relied on generic info from the Haynes or Chiltons manuals. Get the OEM Factory manual for correct info.
2000 Sport.
redvett94 is offline
adjustment , brakes , parking brake , rear brake
Drum Brake Adjustment Problems? Ferenckzy YJ Wrangler Technical Forum 3 03-22-2010 02:58 PM
parking brake adjustment - Rear Discs mr_federalist TJ Wrangler Technical Forum 7 10-30-2008 08:45 PM
Drum Brake Adjustment Problems mkuzmukerau TJ Wrangler Technical Forum 11 06-01-2005 09:07 PM
Rear Brake Adjustment et326 YJ Wrangler Technical Forum 7 12-22-2004 11:44 AM
Rear Brake adjustment Sidewalkman YJ Wrangler Technical Forum 1 09-10-2003 02:08 PM
