TJ radiator problems - JeepForum.com
post #1 of 11 Old 01-12-2014, 06:07 PM Thread Starter
daveg13try2
Anyone have a fix for the leaking radiator problem? I just installed radiator number 5 yesterday in my '99 with 156k. I've tried from radiator barn, the all metal version, and the plastic. They all leak at the top crimp. The latest one that I just replaced was bought at NAPA and I got a free warranty replacement. I've gotten 1.5 to 2 years out of them before they leak. Anyone try running a lower psi cap?
was daveg13 - can't log in as that user now???
daveg13try2 is offline
post #2 of 11 Old 01-12-2014, 06:17 PM
JBTJ
Now it's time to stop wasting your time and money and go with an OEM radiator.
Lower PSI cap won't help. Just a better quality radiator will.
JBTJ is offline
post #3 of 11 Old 01-12-2014, 06:28 PM Thread Starter
daveg13try2
OEM radiator failed at 50k. Problem is, everything that you buy now is chinese junk. Something is causing the crimps to fail. The guy at NAPA pointed out that the OEM cap is 18 psi. Lower pressure on the system might help, but will it affect cooling?
post #4 of 11 Old 01-12-2014, 06:30 PM Thread Starter
daveg13try2
I've gotten good at swapping out the rad. Not going to buy something else now when NAPA just down the road will give me a replacement for free.
post #5 of 11 Old 01-12-2014, 06:36 PM
JBTJ
That is an anomaly, the majority last more than twice that mileage. Normally when they fail is due to not enough coolant in the system. This causes super heated air to build up pressure and kaboom, you have a blow out. Using a cap of less than 18psi will not allow the system to work as designed. Stay away from the chinese junk that the auto parts stores sell and use what came in the JEEP to begin with. USA made!!!
JBTJ is offline
post #6 of 11 Old 01-12-2014, 07:13 PM Thread Starter
daveg13try2
Are OEM replacements made in USA? Purchased one lately? I find it hard to believe that they still are, if they ever were.
post #7 of 11 Old 01-12-2014, 07:15 PM
JBTJ
Well it was a couple years ago. Yes, I believe it was as it didn't say made in china.
JBTJ is offline
post #8 of 11 Old 01-13-2014, 11:00 AM
JStMarie
JStMarie's Avatar
Were you running a higher pressure cap? 18 PSI is standard. A higher pressure cap will put more pressure on ALL other parts of the system, possibly causing early failure.
I've run 2 OEM radiators in my '98 TJ. The first replaced around 120k miles, the 2nd is still in there at 220k miles. I replaced the radiator in my 2006 TJ at 97K. I run stock everything when it comes to the cooling system (195 thermostat, 18 PSI Cap, OEM water pump,"plastic" core radiator). 100K miles out of a radiator seems well within reason.
I wonder now how many people blame radiator failures on running substandard or "performance" cooling system parts like T-stats, caps and pumps from the local auto barn putting undue stress on their radiators.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #9 of 11 Old 01-13-2014, 11:51 AM
LukeADukes
X2 for keeping the cooling system specs close to stock. 195 t stat and 18 psi cap is what it's engineered for. Got my radiator from summit
Always look both ways before crossing the stream.
LukeADukes is offline
post #10 of 11 Old 01-13-2014, 02:22 PM
marka2k
2006 WK
My OEM lasted 130K when I replaced it I went with OEM, it did not leak when it was replaced but had limited flow.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #11 of 11 Old 01-13-2014, 06:12 PM
greene69
My stocker sruvived a rollover and being totaled. It still ran another 20k miles before leaking at a little over 100k . So i got a oem from webster radiator. It was more than a aftermarkert and has held up good for 3 years.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
