TJ radiator fan upgrade info.......2000-2006 TJ - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ radiator fan upgrade info.......2000-2006 TJ
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-11-2011, 07:27 PM   #106
Gary2
Originally Posted by chris142 View Post
The 86 Mustang uses the same fan blade as the 93 Explorer and both are reverse rotation. I have not had a 97-99 Jeep in my shop in a while. Are the WP on those reverse rotation too?
I could be wrong but I thought I read that someplace . After while it starts to run together at this age
O5 Rubi TJ, 3" BDS, Currie Currectlync, Rokmen BL , Savvy arms , Bilstein 5100, 33" Cooper STTs
Gary2 is offline   Reply With Quote
Unread 07-11-2011, 08:29 PM   #107
Hendrix
Hendrix's Avatar
Here you go guys I did it. We will see how it works. So far I can run with my AC on. I could not before with my rigged electric fan. So, this may not be the best comparison but I am happy so far.
Here are the new parts. This is for the 97-99
Dorman 620-112 9 blade 93 Ford Explorer
Imperial HD fan Clutch 215146 or 2733 is the base number that crosses to different brands. 86 Ford Mustang
The whole install took less than an hour to change out. I took it around the block with the AC on high. The temp got to about a needle width past the 210 mark. I am guessing that to be 212-215. I shut down the AC and the gauge came down just under the 210 mark with an outside temp of 99. The noise is hardly noticable. My Jeep is a real slug with the AC on so I cannot report with the power side of the instal,l but it did not feel anymore sluggish.
Hendrix is offline   Reply With Quote
Unread 07-11-2011, 08:32 PM   #108
chris142
See how it does. Your fan is too far into the shroud. You need about 1/2 of the fan sticking out of the shroud.
chris142 is offline   Reply With Quote
Unread 07-11-2011, 08:33 PM   #109
Hendrix
Hendrix's Avatar
Guess that is what the spacer is for that came with the fan.
I will run it tomorrow and check back then.
Unread 07-11-2011, 08:54 PM   #110
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
yea...looks a bit too close to the radiator...
Unlimited04 is offline   Reply With Quote
Unread 07-11-2011, 09:14 PM   #111
mrblaine
mrblaine's Avatar
You also need to poke around and see if you can source a larger fan blade. Max spacing is the shroud no more than 1" from the tips of the blades and it looks like you are slightly past that. A 1" larger fan would get you more air movement.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 07-11-2011, 09:19 PM   #112
MigueloP
Nice, keep us posted about the temp
MigueloP is offline   Reply With Quote
Unread 07-11-2011, 09:49 PM   #113
bombero590
So whats the verdict on the fan for a 98...I am very interested in doing this to my 98 Sahara...Does the fact that the fan is smaller than the shroud make that much of a big deal...
bombero590 is offline   Reply With Quote
Unread 07-11-2011, 09:52 PM   #114
chris142
Somebody needs to measure the older TJ fan. Is it a 19 inch fan? If so I was looking @ Astro vans when I grabbed my explorer fan. The Astro uses an 11 blade fan that looks to be a 19 inch fan.
Unread 07-11-2011, 11:07 PM   #115
ftgiles
Back From The Ashes
Yes, it's a big deal. The fan should be inside the shroud at least 3/4" and no more than half the width of the fan blade.
The shroud is the magic that makes it all work. Poor shroud design equals overheating even with a big fan that moves lots of air.
ftgiles is offline   Reply With Quote
Unread 07-11-2011, 11:22 PM   #116
sduncan
sduncan's Avatar
^^^I agree. Make this a Sticky.
I'd like to say thanks to Chris for putting this info out. It already appears that its going to give a lot of folks a viable option for getting more air through the radiator than anything that was available before without breaking the bank. The best part is that from first reviews, it actually seems to work and is a great improvement for those with cooling issues.
Thanks again!!:cheers 2:
Damn!!! all these posts in the time it took to type this!!!!
'98 TJ, 5.7 HEMI, 545RFE, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,Savvy 1.25 BL,35in MTRs w/Pro Comp 15x10 alloys, Warn 9.5 cti w/Amsteel rope, Gen Rite G3 Alumium front fenders and rear flares, Premier Power welder 195 amp,Savvy Rockers,Prothane bumps,LED tail lites, Rampage top
Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so...rsion-1277803/
YouTube video..http://www.youtube.com/watch?v=iaDRq...&feature=g-upl
sduncan is offline   Reply With Quote
Unread 07-11-2011, 11:43 PM   #117
sduncan
sduncan's Avatar
I looked up a fan for a 96 Astro van with a 4.3 motor. Its an eleven blade fan with a 20 in diameter.
Unread 07-11-2011, 11:58 PM   #118
kapnkaos2004tj
Did this Monday night after getting the parts (15 min. job). Dorman 9 blade fan 620-112 at advance auto for $26.99 and the torqflo clutch 922793 at autozone for $59.99 – couldn’t get both at either place so twice the running (go figure). No overheating problems with my 2004 RME 4.0 but I saw the word “quieter” and said to myself “that’ll work”. It was easy getting the mopar fan off because of its weird spacing but putting the new dorman in was trickier & I really did not want to gouge up the radiator fins so I took the 4 bolts out of the shroud. Gave me enough wiggle room with the shroud still in place but able to be moved around. Result: fan is way quieter and sucks enough air in from the front to hold a towel in place like chris142 already mentioned. This got me to thinking about you guys saying it’s louder or doesn’t hold the towel – you may want to check & see if you mounted the fan backwards as it seems like it’s possible to do that – I don’t want to take mine off to check if true but my new fan did have “front” engraved on it and that’s the side I put the clutch on. By the way, my new clutch came with 4 M6-1.00 x 16 screws with lock washers – just make sure you don’t over torque them – watch the lock washer flatten out and tighten just til the bolt is firmly snug. Thanks for the inspiration chris142.
it's a jeep - if i have to explain it you don't deserve one
kapnkaos2004tj is offline   Reply With Quote
Unread 07-12-2011, 12:14 AM   #119
kapnkaos2004tj
my oem fan seems to measure 18" exactly at its widest point - that is for he 4.0 - if you meant the 4-banger, nevermind.
Unread 07-12-2011, 06:21 AM   #120
JBTJ
I got the exact same parts and mine is noisier than stock when I step into the gas hard. Sounds like a Mac truck starting off. I may go find a Ford fan and see how that sounds. Check out my pics on page 4 and see if that's how yours is. I think I put "front" towards the radiator. Maybe that's my problem.
JBTJ is offline   Reply With Quote
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
