TJ radiator fan upgrade info.......2000-2006 TJ - Page 5 - JeepForum.com
 4Likes
post #61 of 643 Old 07-10-2011, 02:53 PM
MigueloP
Can we use the fan with the oem 97 fancluch?
MigueloP is offline
post #62 of 643 Old 07-10-2011, 02:57 PM
JBTJ
No, clutch isn't good enough.
JBTJ is offline
post #63 of 643 Old 07-10-2011, 03:18 PM
chmo
now THIS is cool
was scratching my head for three weeks now how to get tranny cooler, ac condenser and rad cooler. We had several 118*F days here with high humidity... and my factory temp gauge was slightly above its normal position ... but not climbing further.
Most annoying was the drag on the engine when the stock fan clutch with the stock 5 blade fan was fully engaged. Even the idle RPM went up to 1200 in N and 1000 in D several times with my hotter engine. (would go down after a longer 50 mph drive with 4 TC locked and ~1800 rpm ... with the engine temps going back to normal)
I was even thinking about an additional washer fluid bottle, switch and nozzle in front of rad combo for these extreme "moments" ... will go with the 9 Blade Ford Fan ASAP
THANX !
chmo is offline
post #64 of 643 Old 07-10-2011, 03:24 PM
herbiehind
why does this not work for say a 99 wrangler? is it left hand thread and not right ? i would like a better fan for my 99 early edition .
herbiehind is offline
post #65 of 643 Old 07-10-2011, 03:35 PM
Benderff
Benderff's Avatar
Originally Posted by Knuckelhead View Post
For the 2000+ 4.0L water pump, it's RH thread...
Originally Posted by lil-jmart13 View Post
why wont this work for a 97?
water pumps are different. fan clutch mount is different.
Benderff is offline
post #66 of 643 Old 07-10-2011, 03:36 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
got a 10 blade + fan clutch from the junkyard installed.
no comment on cooling yet, i'll reserve judgement for my next trip to the mountains. so far, idling with A/C on i'm not seeing a major improvement.
one thing I did notice is all the Explorer plastic fans in the junkyard had stress fractures in between the blades.
this one I got had the least amount of cracking...but others were very bad with complete cracks all the way across the surface between each blade. so watch out for that if you go the junkyard route.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #67 of 643 Old 07-10-2011, 03:42 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I am going to see if I can research this for us 97-99 TJ owners. Maybe the Mustang clutch mentioned above will work. I would head out to the JY tomorrow, but its supposed to be 99 tomorrow. Over heating has always been an issue for me at slow speeds and runnig the AC is a Even at hwy speeds with my dumb electric fan.
I really want to do this mod rather than going back to an OEM unit.
Thanks for the awesome find!
K.C.C.O.
Carpe Diem
Hendrix is offline
post #68 of 643 Old 07-10-2011, 03:43 PM
MigueloP
is there any hd clutch for the 97 to use with the fan?
MigueloP is offline
post #69 of 643 Old 07-10-2011, 03:45 PM
JBTJ
I'm sorry I do not know. Chris142 came up with this mod and he works in a radiator shop, so maybe he can help when he logs on.
JBTJ is offline
post #70 of 643 Old 07-10-2011, 04:04 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
At some point, we will need to work up some part numbers for the various fan clutches. Hayden lists at least 3 different versions based on your temperate zone with regular, heavy duty, and severe duty being the options I've found so far.
I'm looking for a severe duty to swap in place of the OEM 7 blade and matching clutch as a comparison and it won't be from a salvage yard.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #71 of 643 Old 07-10-2011, 04:14 PM
Unlimited04
Over the next few weeks I'll be comparing this Explorer fan & clutch with the Autozone/Hayden Severe Duty with the stock 5-blade. Autozone's PN: 922791. They must have PN that will work with 7-blade...maybe a 1998 Dodge Ram truck 5.2/5.9L or a full size van?
Useful Write-Ups:
Funny:
post #72 of 643 Old 07-10-2011, 05:19 PM Thread Starter
chris142
They all do that! The metal that the plastic is molded to goes very deep. It does not seem to hurt the fans. I have seen them much worse and never seen one come apart.
Did you use the old fan clutch or buy a new one? Over time fan clutches lose their efficiency and any 20 yr old fan clutch is due to be replaced.
chris142 is offline
post #73 of 643 Old 07-10-2011, 05:34 PM
Unlimited04
i reused the Explorer fan clutch.
Useful Write-Ups:
Funny:
post #74 of 643 Old 07-10-2011, 05:57 PM Thread Starter
chris142
Does it seem to move air like it should? If it doesn't you will need to buy a new clutch.
chris142 is offline
post #75 of 643 Old 07-10-2011, 06:02 PM
JBTJ
The one thing I did notice Chris is that it does not suck a towel up the grill quite like yours is showing. Hmm!
JBTJ is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
