TJ radiator fan upgrade info.......2000-2006 TJ - Page 35 - JeepForum.com
 4Likes
post #511 of 643 Old 09-12-2011, 11:48 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Best4x4 View Post
Before I tried the Torq Flo Severe Duty clutch the belt was perfect with the 2793 and it never squealed.
same experience here...my new Gates belt was fine for about 1500 miles, but as the belt wore in, it started squeeling...with the 2793/Explorer fan
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #512 of 643 Old 09-12-2011, 11:53 AM
Zakman
A locked & armored LJ
Zakman's Avatar
Any belt issues running the 2793 and the 10 blade combo?
My Build Threads:
2005 LJ - "Squad 51"
2002 TJ - "Minion" - RIP - 06/02/16 @ JJUSA - Badlands
Zakman is online now
post #513 of 643 Old 09-12-2011, 12:33 PM
Best4x4
Besides the 10 blade fan not really aligning correctly (sits very far back from the fan shroud vs the 9 blade fan) the results were the same with the belt squeal.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #514 of 643 Old 09-12-2011, 12:35 PM
Best4x4
I really think the OEM belt is the best choice since it fit tighter vs the aftermarket ones. The Dayco belt I have is slightly longer. I'd like to get my hands on a Goodyear Gatorback belt, but I don't want it to die like the Dayco since it cost almost double!
Best4x4 is offline
post #515 of 643 Old 09-12-2011, 01:21 PM
bottlerocket91
Nice find! I'll have to do this soon. Thanks
bottlerocket91 is offline
post #516 of 643 Old 09-12-2011, 02:35 PM Thread Starter
chris142
I wonder if you guys that are having belt problems have a worn belt tensioner?
I've put about 3000 miles on mine with no issues. I'm running a Dayco belt but I prefer Gates.
chris142 is offline
post #517 of 643 Old 09-12-2011, 02:38 PM
Zakman
Zakman's Avatar
Chris - what is the exact set-up that you are running?
Fan (9 or 10 blade)?
Fan Clutch?
My Build Threads:
post #518 of 643 Old 09-12-2011, 02:59 PM Thread Starter
chris142
Fan Clutch?
10 blade fan from a 93 Explorer in the junkyard and the Hayden 2793 Explorer fan clutch.
chris142 is offline
post #519 of 643 Old 09-12-2011, 03:28 PM
Unlimited04
How many miles are on your tensioner?
I thought of the tensioner myself...80k and i need a 2 ft breaker bar to move the tensioner....I don't want to spend $60 on a replacement, spend the time doing it and still have the same issue. Gates and OEM belt both squeel, but if I turn on the A/C compressor...no squeel (but no power either, )
Useful Write-Ups:
Funny:
post #520 of 643 Old 09-12-2011, 03:40 PM
chmo
find anything? I drove over 800 miles this weekend, much of it in the mountains & turning over 3000rpms...the Explorer 9-blade + Hayden 2793 was giving bad squeeling, just like the Hayden 2791 clutch + stock 5-blade. It's burning the belt up. The "Severe Duty" just seems like too much resistance for those of us that run above 3000rpms often. I'm just going back to the stock clutch & 5-blade for now...the overheating/heat soaking at idle is getting to me - coolant temps were up to 234 at 13,800 ft this weekend...stock gauge showed a fuzz over 210...and it wasn't 50 ambient....not cool. I walked through the junkyard last weekend...I noticed a lot of vehicles had engine driven puller fans, and pusher electric fans in front of the A/C condenser. That may be another alternative.
nope ... was busy with my next project.
(will get rid of all these 42RLE shifting issues, high underhood temps, A/C and overheating problems and OPDA nightmares all together )
off topic ... will keep you updated in another thread
"The more I know, the more I realize how much I don't know"
chmo is offline
post #521 of 643 Old 09-13-2011, 06:10 PM
Best4x4
Well I was getting some nasty squeals at anything above 3500RPM's and my new Dayco belt was trashed so I went ahead and removed it and went to Auto Zone and got a free replacement. I got home and put the new belt on and still had some squealing of a slightly different nature. I went ahead and replaced my belt tensioner with a new Dayco unit. Before I had the belt back on I spun the water pump pulley around to check it and sure enough it's making a nice little noise. I have no slop in the pulley, but I'm 99% the water pump bearing is on it's way out.
I went ahead and installed the new tensioner and belt and it no longer is squealing, but when I turn the engine off and stick my head out of the Jeep I can hear the water pump making that weird noise as the engine stops.
I'm pretty sure the Torq Flo Severe Duty fan clutch is what caused the water pump bearing to start going out since that was the setup that slipped the most at above 3,500RPM's. I've got a free $20.00 credit at Auto Zone so I was going to get a replacement water pump from them, but I was also looking at a water pump from FlowKooler which is said to help with low RPM cooling, but it sounds to me like it would stress out the rest of the cooling system like coolant hoses and the radiator itself.
On a side note if you replace the belt tensioner the Dayco model has a bolt that sits very very close to the timing cover. It does not touch, but it's to close for my liking!!!! I tried to re-use the OEM bolt, but the design is different and I couldn't get the pulley to tighten up properly. I'm going to run into town tomorrow and replace the bolt with a button head bolt which hopefully won't stick out like the one that came with the Dayco belt tensioner.
9-14-11 Update:
Well I swapped out the bolt & washer on the Dayco Belt Tensioner with a hex button head bolt today so no more concern about it rubbing a hole in my timing cover! It sits nice and out of the way now vs before. I also purchased a GMB Water Pump from Advanced for $31.00 after a $25.00 online discount. The pump has an all metal impeller and it looks more like an earlier 97-99 design without the plastic impeller.
I'm not going to tear into replacing the old pump until it gets worse. I might even change out the thermostat housing with a high flow model for $20.00 and replace the thermostat while I'm working on the cooling system.
Best4x4 is offline
post #522 of 643 Old 09-14-2011, 08:44 PM Thread Starter
chris142
Still running the original with 128K on it now. But just cause mine is ok at 128K does not mean yours is good @ 80k.
chris142 is offline
post #523 of 643 Old 09-14-2011, 09:42 PM
TheDragonfly
Derale makes a 6 blade steel fan in 17" and 18" and heavy duty fan clutches and their stuff is made in the USA. Pricey, but Might be worth testing considering their line of cooling products.
http://www.polyperformance.com/shop/...n-p-17273.html
http://www.polyperformance.com/shop/...h-p-17283.html
"It is dangerous to be right when the government is wrong." Voltaire
TheDragonfly is offline
post #524 of 643 Old 09-24-2011, 07:44 AM
rangerb3
I'm considering moving to an eFan on my '02 4.0L....I have a brand new Hayden 2793 HD clutch, new Dorman 620-112, 9 blade fan. I've got about $90 bucks in the complete setup and I'll take $50 + shipping for it! I can send it as a complete unit if anyone is interested. I probably have 50 miles on the setup...it will come complete and ready to bolt up to your rig providing that yours uses the single nut water pump design!
Sorry, I'm out of the US right now and won't be back for about 5 weeks....
Best Regards,
Rangerb3
'02 TJ-X
4" Full Traxxion w/Black Diamond Shocks, BFG AT 33x10, Smittybilt SRC Fr/Rr bumpers, Vortex 12K winch, 3/8" Syn line, Thumb Throttle, Factory Cruise(DIY), Banks Cat-back, AEM Brute Force, Donaldson P550299 HiCapacity Oil Filter w/magnets, Fat Bob's 1.25" Composite Seat Riser Kit, DDM 55w HID's w/Morimoto Projector Upgrades, GenRight 5-piece Louvers, 160A Alternator, Taurus Elect Fan, LED Tailights, LED 3rd Break Light, LED Dome & Interior Lights, Dome cut-out switch, LED Spot & Flood lighting, Polk 5-1/2" Front & 6-1/2" Audio Bar Speakers
Defiintion of a Helicopter:
10,000 rotating parts continuosly trying to pull themselves apart while beating the air into submission! You gotta love 'em!!! :-}
rangerb3 is offline
post #525 of 643 Old 10-31-2011, 06:46 PM
Smallblockmjt
When this thread started out, I ordered the new 10 blade fan and Hayden clutch but with the 112 degree temps that we had here in Arizona, it was way too hot to be working under the hood of my TJ. Well, today was a pleasant 86 degrees so I accomplished a few things that I wanted to do as replacing the fan and clutch. Worked out real nice and clean without any problems. The "towel test" on the front grill verified that every thing is working as planned. I really didn't have any overheating problems prior as my 4.0L ran at a constant 210 degees. Hopefully it doesn't get any hotter now but we'll see what happens when our Arizona weather goes back up to 115. Great job on the first write up !
Michael T.
"This ain't no dress rehearsal ! "
Smallblockmjt is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
