TJ radiator fan upgrade info.......2000-2006 TJ - Page 34 - JeepForum.com
 4Likes
post #496 of 643 Old 09-03-2011, 12:08 PM
LesterM
Would this set up work for a 2000 without ac and a manual tranny?
2000 Wrangler.
LesterM is offline
post #497 of 643 Old 09-03-2011, 12:12 PM
ColoradoCole
Yes, im currently running it
ColoradoCole is offline
post #498 of 643 Old 09-03-2011, 03:12 PM
Dirtrag
Fan set-up
Originally Posted by ColoradoCole View Post
I just checked Oreilly and they sell both the 9 and 10 blade, the 10 blade comes with a severe duty clutch as well.
What were the part numbers?
Dirtrag is offline
post #499 of 643 Old 09-03-2011, 03:28 PM
Dirtrag
Vise grips vrs. ?
Originally Posted by BYuen View Post
One side of the channel lock grips on the surface of the pulley where the belt rides and the other goes right on the other side behind the pulley.
Use a chain wrench on the pulley. Just make sure the grip is correct for the direction of removal.
Dirtrag is offline
post #500 of 643 Old 09-03-2011, 03:32 PM
Gary2
I understand that the 7 blade fan is not manufactured any more. I don't really care if it is new I would just like to know what numbers are on it or a quick way to identify it so I can grab it if it is the real McCoy. I know a few of you have posted they have one , can anyone post what numbers are on it or a way to quicly identify it . I have seen a few 7 blades for sale for a Wrangler over time but don't know if it is the right one .
Gary2 is offline
post #501 of 643 Old 09-03-2011, 04:24 PM
ColoradoCole
I will go back by there tonight and get the part numbers for the blades and clutch
post #502 of 643 Old 09-03-2011, 06:49 PM
Border Dave
Got Sand?
Border Dave's Avatar
You need to go back and read the thread. It's in here.
Border Dave is offline
post #503 of 643 Old 09-04-2011, 05:32 AM
Gary2
NAAA thats OK. I just finished reading 38 pages which is why I asked I must of missed it but I will take that as a sign to leave what I have well enough alone thanks for the advice .
Gary2 is offline
post #504 of 643 Old 09-05-2011, 12:29 PM
Xtremegameroom
Just picked up the fan and clutch from Vatozone
Time to pull out the Efan :/
Xtremegameroom is offline
post #505 of 643 Old 09-06-2011, 11:30 AM
Xtremegameroom
Originally Posted by overkill View Post
I completed this mod today myself. Due to my aftermarket aluminum radiator, I had to removed the shroud to make the install. My initial impression is that it definitely moves alot of air at idle. OAT today was 98 degrees, 85 percent humidity. After idling for 25 minutes, temp indicated 212 degrees. Increasing idle to 1500 rpms, temp indicated 200 within 2 minutes. Noise is definitely quieter.
So....if temps are a constant issue, why not drop to a lower temp thermostat?
I have an aluminum radiator as well... Are you not using a shroud at all?
How is it working for you?
post #506 of 643 Old 09-06-2011, 12:13 PM
wage
Chris,
Now that have done the upgrade for awhile..any issues??
wage is offline
post #507 of 643 Old 09-12-2011, 10:25 AM
luckydusty
Why did you upgrade with an engine powered fan and not electric? Cooling system is my next upgrade so this is research..
luckydusty is offline
post #508 of 643 Old 09-12-2011, 11:24 AM Thread Starter
chris142
Originally Posted by wage View Post
Chris,
Mines still working well.
Most of the guys with Electric fans on TJ's don't like them.They do not move as much air as an engine driven fan does and overheating @ slow speeds becomes a problem.
chris142 is offline
post #509 of 643 Old 09-12-2011, 11:31 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by chmo View Post
the only chance I have for the next week is tomorrow ... and regarding the heat, I can picture that! Thanks for the hint. I think I am going to pull a original pulley and use that as a "template" while asking the wise junkyard wizards for a smaller one.
find anything? I drove over 800 miles this weekend, much of it in the mountains & turning over 3000rpms...the Explorer 9-blade + Hayden 2793 was giving bad squeeling, just like the Hayden 2791 clutch + stock 5-blade. It's burning the belt up. The "Severe Duty" just seems like too much resistance for those of us that run above 3000rpms often. I'm just going back to the stock clutch & 5-blade for now...the overheating/heat soaking at idle is getting to me - coolant temps were up to 234 at 13,800 ft this weekend...stock gauge showed a fuzz over 210...and it wasn't 50 ambient....not cool. I walked through the junkyard last weekend...I noticed a lot of vehicles had engine driven puller fans, and pusher electric fans in front of the A/C condenser. That may be another alternative.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #510 of 643 Old 09-12-2011, 11:41 AM
Best4x4
Yeah after running the Torq Flo Severe Duty fan clutch it pretty much has toasted my new belt. I went with the 2791 and the 5 blade for a test and I think it's only squealing because my belt is messed up from the Torq Flo. It's even squealing with the stock clutch and fan now so I know for sure my belt is toast. I'm going to put my OEM spare back on and see if I can exchange my Dayco belt at Auto Zone with another one since it has a warranty.
Before I tried the Torq Flo Severe Duty clutch the belt was perfect with the 2793 and it never squealed.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
