TJ radiator fan upgrade info.......2000-2006 TJ - Page 29 - JeepForum.com
 7Likes
post #421 of 659 Old 08-05-2011, 09:59 PM
fish4life
i've only seen my jeep creep past 210 a little bit when running hard up a steep hill. It did so even on steep highway hills at 60mph, so i figured it wasn't my fan. I gave my system a complete flush and new thermostat and it helped somewhat, though it will still creep a little past 210 ocassionaly, 215 perhaps. Not enough to be worried about it. It would probably go back to below 210 if i replace the crap Radiator Barn rad with an O.E.M one.
However, for kicks and giggles, i tried the towel test just now. This is a stock 5 blade metal fan and stock 14 year old fan clutch.
fish4life is offline
post #422 of 659 Old 08-06-2011, 06:09 PM
dbbd1
dbbd1's Avatar
Nice! Thanks for doing that test. I am sticking with stock for now too.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #423 of 659 Old 08-06-2011, 06:37 PM Thread Starter
chris142
Ya your fan and clutch seem to be working well. My stock fan wouldn't do that even after I drilled a hole through the clutch and bolted the clutch solid.
chris142 is offline
post #424 of 659 Old 08-06-2011, 06:53 PM
sduncan
sduncan's Avatar
In looking at your pic one thing you might want to check into is sealing the area between the top of the radiator and the grill. You're losing a lot of air flow through that gap that should be passing through the radiator core. Every little bit helps......
'98 TJ, 5.7 HEMI,
sduncan is offline
post #425 of 659 Old 08-07-2011, 01:10 AM
fish4life
the radiator is in exactly the same spot that the original oem one was. I think you are mistaking the effect of the gap between the radiator and fan shroud for the gap between radiator and grille.
post #426 of 659 Old 08-07-2011, 07:03 PM
sduncan
sduncan's Avatar
Nope...I am referring to the gap between the front edge of the top radiator tank and the top rear edge of the grill. The shroud and mounting of the radiator itself are not what I am talking about.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #427 of 659 Old 08-08-2011, 11:21 PM
fish4life
Well then you are mistaken if you think there is something there worty of attention. The position on the two in relation to each other is the same as every other rad/grille combo I have seen on any other tj ... And nobody has attempted to improve it in any way, neither shall I
post #428 of 659 Old 08-09-2011, 07:26 AM
jr03
There is a foam seal that is oem that seals the ac condensor and radiator, my after market condensor doesn't set up as high and I have a gap that I filled with foam pipe insulation. It might not make a lot of difference, but mine was sealed from the factory.
jr03 is offline
post #429 of 659 Old 08-09-2011, 08:41 AM
Best4x4
My 05 looks nothing like that.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #430 of 659 Old 08-09-2011, 06:55 PM Thread Starter
chris142
Yup mine had that also. It's long gone. I should replace it
chris142 is offline
post #431 of 659 Old 08-09-2011, 08:08 PM
sduncan
sduncan's Avatar
Bingo.....
'98 TJ, 5.7 HEMI,
sduncan is offline
post #432 of 659 Old 08-09-2011, 08:30 PM
Tjosh97
Does this fan upgrade work on 2.5L 4-Cylinders?
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline
post #433 of 659 Old 08-09-2011, 08:52 PM
Tjosh97
Originally Posted by Hendrix View Post
Just picked up the 86 mustang hd clutch and explorer 9 blade fan to test out. Everything bolts up great on my 97 TJ. Hope it works well.
Do you think it will work on the 2.5L?
Tjosh97 is offline
post #434 of 659 Old 08-09-2011, 08:54 PM
Tjosh97
92-2737 Early model TJ "Heavy Duty" (no Severe Duty listed)
Will this work on a 2.5L?
Tjosh97 is offline
post #435 of 659 Old 08-09-2011, 09:14 PM
Tjosh97
Originally Posted by chris142 View Post
no. The 4cyl uses a much smaller fan and shroud. The 18inch fan won't fit in the shroud.
The shroud is bigger on a 4cyl.
Tjosh97 is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
