TJ radiator fan upgrade info.......2000-2006 TJ - Page 28 - JeepForum.com
 4Likes
post #406 of 643 Old 07-26-2011, 10:13 PM
freeskier93
Originally Posted by fish4life
yeah, and e=mc^2 is pretty darn simple too. Now use it and go build a nuclear warhead.
There is more to it than just determining open/closed loop ....
I'm not sure why you are thinking it's so complicated. The operation of the fan clutch needs nothing more than an input of temperature. You could literally wire an electric clutch just like an electric fan.
freeskier93 is offline
post #407 of 643 Old 07-26-2011, 10:18 PM
Necko2529
Hold on now guys... from fans and clutches to nuclear warheads.... where have I been last couple of days.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #408 of 643 Old 07-29-2011, 03:14 PM
hamsterwheelTJ
I read/skimmed most of this thread & didn't see this answered. I got a fan/clutch from the junkyard & after I got it home realized it was from a '95 or '96 explorer. Manufacture date is 7/95. It also has 12 blades. Anybody know if this will work?
Originally Posted by fang_x View Post
the flux capacitor is only powered by the front drive shaft, this allows tjs to out run Indians on the desert flats without accidentally going through time.
altho sometimes when you install a lift kit, it is possible to reallocate the flux capacitor to a more suitable location, such as in the glove box. Or alternatively you can buy a skid guard for it
hamsterwheelTJ is offline
post #409 of 643 Old 07-29-2011, 03:45 PM
Best4x4
If it's an 18 inch fan and it has the proper clutch for a 12 blade fan I'd say slap it on there and see what you're results are. I'm very happy with my 9 blade fan and Hayden 2793 clutch.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #410 of 643 Old 08-01-2011, 09:26 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I'd typed up a whole big write up of my thoughts after running Explorer fan + 2793 vs stock 5-blade + 2791 in all sorts of different driving conditions....but the damn forum kicked me off, and I lost everything.
anyway bottom line is the 2791 wasn't any different than the stock clutch. the explorer fan + 2793 worked better above 1300rpms, but worse when idling. i'll try to get the energy to retype everything again
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #411 of 643 Old 08-01-2011, 10:21 AM
Robert J. yates
Your Jeep wants to run at 220*... get used to it. BTDT... and found that the stock fan and clutch in perfect working condition worked best.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #412 of 643 Old 08-01-2011, 11:12 AM
Unlimited04
thats just the thing....my stock clutch and fan don't keep up with the A/C on. Holding 220-225 climbing a pass, pulling a 2000lb trailer with the A/C on I would understand. But on a hot day (90-100), when the A/C is on in heavy traffic going under 20mph...temps go past 220...and will keep climbing to 260+, if I don't turn off the A/C when I see it get to 225-230. It's only an issue when I run A/C for long periods of time idling on a hot day. luckily I don't do that often at all, especially with the soft top, but it still sucks that the Jeep ain't right.
when I'm wheeling, i'm usually above 1300rpms...since torque converter stall is ~2000rpms. so wheeling, it stays nice and cool cause the fan's moving. With the Explorer fan and 2793 clutch...runs 198-202 all day long, and the tranny runs around 160
Useful Write-Ups:
Funny:
post #413 of 643 Old 08-01-2011, 03:14 PM
Best4x4
Still very happy with my 9 blade fan and Hayden 2793 fan clutch. I've been all over the place, in traffic, cruising, and sitting at idle and my temps are cooler across the entire range of driving. I did find an online retailer that sells the 10 blade replacement fan blade for 23.00. I might give it a shot for that cheap and see if there truly is a difference between a 9 and 10 blade fan.
Best4x4 is offline
post #414 of 643 Old 08-01-2011, 03:43 PM
lope
lope's Avatar
Unlimited04, I wonder if there could be an issue with your A/C compressor? Pulling hard and overworking the engine or something.
lope is offline
post #415 of 643 Old 08-01-2011, 05:01 PM
pumpman55
unlimited04 those trans temps sound real good. are you getting your temps from the output or input of trans?
pumpman55 is offline
post #416 of 643 Old 08-01-2011, 05:16 PM
Unlimited04
i doubt it...personally, i think the 2 mini-cats play a roll in heat soaking the engine compartment.
my temp gauge is on the hot side output line of the tranny. i don't see much sense in monitoring the cold line...
Useful Write-Ups:
Funny:
post #417 of 643 Old 08-01-2011, 09:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
When you find a good transmission guy, he will tell you to monitor the trans temp by placing the sender in the oil pan.
I've had this very discussion with two of the premium trans builders in this part of the world and both say the same thing. The only thing you care about is how hot the trans is or isn't.
The good news is I had to go rescue a rig today on the trailer and the temps are a bit on the toasty side. The trans in the tow rig got up to 180.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #418 of 643 Old 08-01-2011, 10:23 PM
lope
lope's Avatar
You're probably right. It's just that from what I've read of your overheating troubles, it seems you've tried everything else.
Mine's running hotter than I'd like as well on the mail route. In town, where my stops are one right after another, it gets up to 215 to 220 with the A/C on but more like 212 when I'm moving pretty good. If I have to sit at idle for very long I don't even think about leaving the A/C on. Did that one day for about 10 min or so and it got up almost in the red. I immediately turned the heater on full, started driving and it cooled right down fortunately.
I'm just using the factory temp gauge, (seems I read you're going by the scangaugeII or something) so I'm not sure if my temps are right on or not.
lope is offline
post #419 of 643 Old 08-04-2011, 12:33 PM
780406jeeper
I accidentally picked up an extra brand new Four Seasons 10-blade fan from ebay that I am not able to return. If anyone is interested in it, pm me. Thanks,
Kevin
'78 Cherokee Chief: 360/TH400/NOS QT, '04 Grand Cherokee: 4.7/545RFE/242HD w/SYE, JK Rubi front axle, 4.56 gears, Protofab rear bumper/tire carrier
780406jeeper is offline
post #420 of 643 Old 08-04-2011, 12:57 PM
NotURMailman
Originally Posted by fish4life View Post
As far as I know, most of those types of clutches are also tied to the computer module as well, in order to monitor open/closed loop situations and the temps ... I think making one for the TJ would be very tricky....
You guys are thinking too hard! The early model fan clutches simply had one or two 12v+ inputs, one for high and one for low (or just one for on) and a ground, and then one or two computer signal outputs.
You would ignore the ouput wires completely. You would chassis ground the ground. You would use appropriate temperature switches or one temp switch and a relay tied into the AC compressor activation circuit (or a combo of the two) to feed the two inputs.
The only differences are that some have an ignition switched hot and the control circuits are switched ground circuits. But that only changes things slightly.
I just haven't felt like doing the research. You would first have to find a clutch with appropriate dimmensions. Then you would have to make sure it wasn't a failure prone model (some of the early electrics were). And then you would have to get a hold of the schematics for the system.
None of this is to say that it would work any better that the factory set up. i just think it would be nice to have the air moving capabilities of a engine driven fan and be able to dissengage it for water crossings.
I really don't think there's really anything major wrong with the design of the cooling system. I think the most of the people that are having over heating issues have a hidden problem. Not a small number of them are probably due to people who fill their radiators with tap water and never clean out the cooling fins of their radiators. But, what do I know?
BTW - This thread has been painful to follow!
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
