TJ radiator fan upgrade info.......2000-2006 TJ - Page 27 - JeepForum.com
 4Likes
post #391 of 643 Old 07-21-2011, 03:14 PM
Timmac
Originally Posted by ftgiles View Post
The biggest improvements that will make your a/c system more efficient is to insulate your top and tint your windows.
The less heat that you're trying to remove from the interior is that much less heat that you're dumping out in front of your radiator.
Many people insulate their tops here in Phoenix and report great results in their a/c performance.
People with soft tops just use rigid wall foam insulation stuffed between their roll bar and top. Guys with hard tops do a variety of different things to get better sound proofing and insulation.
And here's a profssional solution with some data about the subject.
http://www.insul-liner.com/
Wow Thanks, was thinking of making my own but those look great, will have to put that on my shopping list, but still think Jeeps normal operating temps are to high, will still put a small pusher in front and switch at dash to use during the hottest months, cooler running motors, auto trans, a/c last longer..
Heck my 13,000lb motorhome runs cooler than my Jeep..
Timmac is offline
post #392 of 643 Old 07-21-2011, 03:14 PM
ftgiles
Originally Posted by JBTJ View Post
Now see there you go. Too bad it’s for hard tops. I tried the fan mod to help the AC system which it did not. Even though after adding some refrigerant to the system cause it was a bit low and now blows 37degree air out. The inside of the cab just will not cool down. I do have a soft top and that is the problem. There is just no way the factory AC can cool down all of the radiant heat that is trapped inside. Wish there were some thing that looked good and worked to insulate the top.
A buddy of mine has his Bimini top on all the time. He puts the foam on top of the Bimini and then puts his soft top on over that. Then in the fall he just takes the soft top and foam off and the Bimini is still sitting there from last spring. You'd never know the foam was there. Also, it quiets down the ruffling soft top on the hi-way.
ftgiles is online now
post #393 of 643 Old 07-22-2011, 05:50 AM
grunt0341
Originally Posted by chris142 View Post
Only show one clutch here.
Torqflo/Fan ClutchPrice:$59.99
Part Number: 922793
I just bought a 2002 wrangler and read this thread and thought this would be good preventive maintainence. Do you have to replace the clutch or can you use the one from the TJ?
Thanks
grunt0341 is offline
post #394 of 643 Old 07-22-2011, 09:52 AM
J03_TJ
I went without A/C all last summer and it sucked. Finally got the condenser replaced and the system charged. It is so nice to have cold air blowing on me in the summer heat. I can only imagine it would get colder if I had the top on.
J03_TJ is offline
post #395 of 643 Old 07-22-2011, 10:49 AM
Talljeeper
I am very pleased with the 9 blade/hd clutch upgrade. Not only does it fit better in the shroud, I absolutely hated the metal one. It looked crappy and just screamed "im gonna cut your fingers off b!$%&".
Talljeeper is offline
post #396 of 643 Old 07-22-2011, 12:13 PM
Best4x4
Well my friend tried the standard duty fan clutch with the 9 blade fan and he said it was like the stock setup as far as cooling. I didn't go anywhere today so he came by to borrow my setup again while he removed his clutch so he could swap it out for the severe duty one on his way home from work.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #397 of 643 Old 07-22-2011, 06:46 PM Thread Starter
chris142
Thanks
Need the Ford Clutch too.
chris142 is offline
post #398 of 643 Old 07-24-2011, 02:57 AM
PonyExp305
Thanks..Cool Idea,,
.... ___ ....................... _______
. /,[___], ..................../__/_,[___],
1---L-OIIIIIIO- ...........1--------L-OIIIIIIIO-
()_) ()_) ---- )_)........()_)--- ) ()_) ---- )_)
PonyExp305 is offline
post #399 of 643 Old 07-24-2011, 10:22 AM
NotURMailman
NotURMailman's Avatar
I'm waiting for someone to find a 3 wire, non-computer controlled fan clutch that will fit the TJ. Or find a decent pin out of the current electric fan clutches.
The early three wire clutches simply had a ground, a low on, and a hi on wire.
I'm certain I could figure out how to operate one of the newer electric clutches with two on/off temperature switches if I had a good pin out and signal requirement specs.
The more efficient fan blade is great, hats off to the OP!
But, I would still really like an electric fan clutch for two reasons; the higher end models have two different operating speeds (measured in % of shaft speed, not RPMs), and the ability to disable the fan for deep water crossings.
I'm sure I could find one to fit the TJ, the issue is finding all of the information needed to design a control system.
Electric fans simply do not move as much air as mechanical fans and their highly stressed electric motors tend to fail. So the obvious answer is a mechanical fan that is engaged electrically. Electric fan clutches have a much lower failure rate than electric fan motors.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #400 of 643 Old 07-25-2011, 09:25 PM
fish4life
As far as I know, most of those types of clutches are also tied to the computer module as well, in order to monitor open/closed loop situations and the temps ... I think making one for the TJ would be very tricky....
fish4life is offline
post #401 of 643 Old 07-25-2011, 09:30 PM Thread Starter
chris142
The newer Dodge trucks with the Cummins Diesel use an electronically controlled fan clutch. Some engineer goofed because the wires keep getting pulled into the blades and shredded.
chris142 is offline
post #402 of 643 Old 07-25-2011, 09:51 PM
fish4life
he designed it on a friday
post #403 of 643 Old 07-25-2011, 10:05 PM
freeskier93
Wranglers determine open/closed loop based off the temp coolant sensor, it would be no different than wiring an electric fan to an external controller that piggybacks off the coolant temp sensor.
freeskier93 is online now
post #404 of 643 Old 07-26-2011, 07:22 AM
TheSlowDown
The cost looks prohibitive for an electric clutch conversion... $120+ (low end) for the electric clutch itself. But then you need the control box as well. Something like a DC Control box - but custom for this application. Such a small batch item could easily cost $200 - $???. Then there is the appropriately matched fan as well - guessing anywhere between $40 and $100 for that.
Low end is $360, high end... maybe $700+. Those Dodge Ram electric clutches are $200 a pop.
Doesn't really seem worth it.
TheSlowDown is offline
post #405 of 643 Old 07-26-2011, 07:26 PM
fish4life
yeah, and e=mc^2 is pretty darn simple too. Now use it and go build a nuclear warhead.
There is more to it than just determining open/closed loop ....
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
