TJ radiator fan upgrade info.......2000-2006 TJ - Page 2 - JeepForum.com
 4Likes
post #16 of 643 Old 07-09-2011, 05:58 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by JBTJ View Post
Standing in front does that big nut to remove the clutch turn right or left?
For the 2000+ 4.0L water pump, it's RH thread...
Knuckelhead is offline
post #17 of 643 Old 07-09-2011, 06:05 PM
JBTJ
So you didn't remove the shroud, just the overflow tank correct? My sons just left to go get the parts.
JBTJ is offline
post #18 of 643 Old 07-09-2011, 06:06 PM
Speed-Freek
So this wont work on my 97'? Different thread direction??
Speed-Freek is offline
post #19 of 643 Old 07-09-2011, 06:07 PM
mikebyn
nice nice
2006 Tj: 2" BB, 1" BL, 33's
Build Thread:
http://www.jeepforum.com/forum/f22/2006-tj-dd-shooting-35s-37s-1258213/#post12088091
mikebyn is offline
post #20 of 643 Old 07-09-2011, 06:09 PM
willis36
willis36's Avatar
97 models have a bolt on fan vs thread on like the newer models
willis36 is offline
post #21 of 643 Old 07-09-2011, 06:11 PM Thread Starter
chris142
I never touched my fan shroud. It's tight but the fans will slide in and out with the right angle of the dangle. You may need to grab 4 small bolts to bolt the ford fan onto the ford fan clutch. You cant use the jeep bolts.
Ford bolts are a very common 6x1mm I believe. They use a 10mm socket to tighten and remove them.
chris142 is offline
post #22 of 643 Old 07-09-2011, 06:12 PM
Speed-Freek
Well then......I guess that settles that, lol.
post #23 of 643 Old 07-09-2011, 06:13 PM Thread Starter
chris142
I don't have a bolt on fan clutch to try out. I bet that you could drill holes in the metal backing on the Ford fan and bolt it to your Jeep fan clutch........Assuming that the jeep fan clutch has enough guts to turn 10 blades.
chris142 is offline
post #24 of 643 Old 07-09-2011, 06:14 PM
Knuckelhead
AFSOC Retired
Both have the bolt-on fan, it's the fan clutch that mounts different...
post #25 of 643 Old 07-09-2011, 06:14 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
So are there any cheap options for the 97's that anyone knows of?
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #26 of 643 Old 07-09-2011, 06:17 PM
gremlinsteve
drop the newer style water pump on it...
gremlinsteve is offline
post #27 of 643 Old 07-09-2011, 06:17 PM
willis36
willis36's Avatar
thats what i meant, but thanks for the correction
willis36 is offline
post #28 of 643 Old 07-09-2011, 06:18 PM
Knuckelhead
AFSOC Retired
The OEM fan clutch (for the 5 blade) wont turn that fan efficiently...
post #29 of 643 Old 07-09-2011, 06:20 PM
Knuckelhead
AFSOC Retired
That wont fit to the earlier engine...
post #30 of 643 Old 07-09-2011, 06:29 PM
dwbrown
2014 JK Wrangler
I may have to do this...
USAF
dwbrown is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 12:40 PM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 04:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 03:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 09:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 09:50 PM
