-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   TJ radiator fan upgrade info.......2000-2006 TJ (http://www.jeepforum.com/forum/f9/tj-radiator-fan-upgrade-info-2000-2006-tj-1237538/)
chris142 07-09-2011 04:19 PM
BTW:For those that have the spin on fan clutch only. 2000 through 2006 with the 4.0L.
There are Many threads when summer comes about 4.0L TJ's that run hot at slow speeds and idling. They run hot at slow speeds because the stock 5 blade fan does not move enough air to remove heat from the radiator.
Jeep used to offer a 7 blade fan and clutch upgrade but it's gone.
I work at a Radiator and AC shop and see it often. I began to look for another fan that would cool the radiator better w/o going to an electric fan. Usually electric fans cause more trouble.
I even went to the extent of drilling a hole in my fan clutch and bolting it solid. This helped alot but the gas milage and noise was unbearable. It would still heat up if idling even with the bolted fan clutch and AC on.
I reciently had an 86 Mustang in the shop and it had an 8 blade 18inch fan on the front of it's 5.0. So I went to PicAPart to find one.
Didn't find any Mustangs.
I did find a 1993 Ford Explorer with an 18 inch 10 blade fan. I unscrewed the fan and clutch from the Explorer, paid $8 and took the fan and clutch home.
The fan and clutch screwed right onto my 02 Jeep waterpump. Took all of 7 minutes and 5 of those minutes were spent removing the coolant over flow bottle. Once it's out of the way the stock fan and clutch slides right out and the Ford parts slide back in.
So there you have it. A 10 blade fan upgrade.
You must use the ford fan and it's clutch.
A new fan is $85 from Ford. They will ask you if you want a 10 or 9 blade fan.
ORiley gets $65 for a new Hayden fan clutch.
The auto parts stores do sell a new 9 blade fan for the Explorer for about $35. It is supposed to replace the 10 blade fan. I'm betting that the 9 blade fan is still an ugrade over the Jeep 5 blade fan.
Anyway on to the pics.
Stock jeep fan vs 93 Explorer fan.
http://usera.ImageCave.com/chris142/0703011442.jpg
The new fan is a perfect fit!
http://usera.ImageCave.com/chris142/0703011456.jpg
http://usera.ImageCave.com/chris142/0703011526.jpg
Idling it pulls enough air to keep a towel on my grill. It's amazingly quiet too. Much quieter than the stock Jeep fan. It also removes more heat from the AC condensor so the AC blows colder at slow speeds to.
http://usera.ImageCave.com/chris142/0709011432.jpg
There you have it.
My contribution of the day:D
JBTJ 07-09-2011 04:23 PM
Very nice and thank you, not that I need to, But I know what I'm doing tomorrow. :2thumbsup:
cyber1satan 07-09-2011 04:29 PM
Very nice find, Thanks for the info!
all3forus 07-09-2011 04:30 PM
Great job..Thanks for the info..
sduncan 07-09-2011 04:35 PM
HMMMMMMMM!!!!!! Nice find!!! I'll be pasing that along to my dad....he's still having a hard time keeping his motor cool in 100+ heat.
JBTJ 07-09-2011 04:37 PM
After checking the major auto parts stores here in Dallas, Auto Zone, NAPA and O'Reilly all they offer is the electric fan for a 93 explorer. :thumbdown:
chris142 07-09-2011 04:40 PM
Doorman part # 620-112.
Go to Azones site. Put in 93 explorer then fan blade.
JBTJ 07-09-2011 04:43 PM
Originally Posted by chris142 (Post 11831727)
Okay my bad, found the fan but which clutch? They show for both transmissions, heavy duty and non.
chris142 07-09-2011 04:43 PM
Dorman/Fan Blade
For your 1993 Ford Truck Explorer 2WD 4.0L MFI 6cyl
Price:$25.99
Part Number: 620-112
AVAILABILITY:STORE PICK UP AVAILABLENormally stocked at your local store.SHIP TO HOMEAVAILABLEShips within 2 business days.
chris142 07-09-2011 04:44 PM
Only show one clutch here.
Torqflo/Fan ClutchPrice:$59.99
Part Number: 922793
JBTJ 07-09-2011 04:47 PM
Part Number: 922793
Thanks a bunch, really. Was looking at O'reilly parts.
chris142 07-09-2011 04:50 PM
The Hayden # that ORiley sold me was# 2793
JBTJ 07-09-2011 04:51 PM
Standing in front does that big nut to remove the clutch turn right or left?
chris142 07-09-2011 04:52 PM
Regular right hand thread. Counter clockwise to remove if your standing at the front of the jeep.
Unlimited04 07-09-2011 04:54 PM
well crap, i just ordered a new fan clutch.
i'll get one of these next time i'm at the junkyard and see what happens.
The time now is 11:03 PM.
