Quantcast TJ project finally gets started - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ project finally gets started
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-17-2008, 04:24 PM   #1
frosty4x
Project Whatever finally gets up and rolling this weekend
After 6 years out of the wheelin world I bought a cherry 05 TJ and spent the next 9 months saving my clams to get it rollin and on its way to what I wanted.
Following are the pix from day one until this weekends finish of part 1 of the build.
Day 1
Tires deliverd
wrenching on it
Back in its spot
Mods for part 1 were
RE 3.5" SF, 1" Currie BL, 1" MML, Currie AntiRock, 1.5" seat risers, 35" BFG's on 15x8 Mikey Classic II's
[URL="http://WWW.tinbenders.org"]http://WWW.tinbenders.org[/URL]
2005 RockyMountain TJ
3.5" RE SA, 1" Currie BL, 1" MML, 35x12.50 BFG MT T/A KM2, Currie AntiRock and a some other stuff
frosty4x is offline   Reply With Quote
Old 11-17-2008, 04:29 PM   #2
RVA_TJ06
Looks great. Can't wait to get my 35"s
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Old 11-17-2008, 04:39 PM   #3
Chewie4299
What axles/gears do you have? How do the 35"s feel with them? Did you need to install the TC drop or SYE/CV DS?
I ask because I'm starting with my 06 Wrangler X with D30/35 combo and 3.07s(i believe) and my first stage is going to be similar to yours save for 33"s instead of 35"s.
Chewie4299 is offline   Reply With Quote
Old 11-17-2008, 04:47 PM   #4
frosty4x
Its on a D30/D44 combo with 3.73's and it has NO problem haulin booty
I did the BL/MML with the hopes of not dropping the T-case but I do have some vibes so I'll drop it later today until I can afford an Atlas or Stak case and D-line. Should be fine once I do the TCD.
Also, As soon as I can I'll gear and lock these axles but I am on the prowel for either a D44 front or a set of 60's to cut and fit into the TJ.
IF I go 60's I'll end up sitting on 38's as a rule but thats a fair piece down the trail I'm sure.
MS
Old 11-18-2008, 09:17 AM   #5
frosty4x
Did the case drop and all vibes are gone
Had to clearance the shifter console but that was no big deal.
Just used google trackting and my rock sliders show to be "out for delivery"
MS
Glock Forum
