TJ power steering box - JeepForum.com
post #1 of 8 Old 03-10-2013, 08:22 AM Thread Starter
BFD35
Hi Guys,
I'm new to this forum. I just picked up a TJ with a 2" lift and 33"BFG's. There is a dead spot in the steering for 11-1 o'clock. I got under it and had a buddy turn the wheel back and forth in the dead spot. The steering column shaft is moving going in to the box, but the pitman arm isn't moving coming out. It seems to me the gears are worn and the box needs to be replaced. I tried adjusting the allen screw on the top, but all that did was make the steering tighter and the Jeep drift across the lane. I just want to make sure this is the problem before I start putting new parts on.
Thanks
BFD35 is offline
post #2 of 8 Old 03-10-2013, 10:08 AM
BYuen
BYuen's Avatar
Yep it's your steering gear. Mine was like that. I replaced it with a quality reman gear from PSC and now have zero play.
BYuen is offline
post #3 of 8 Old 03-10-2013, 08:47 PM
durango-bob
2006 WK
You can also buy a steering gear box that is designed for a '99 Durango 4x4. It is a direct bolt in to your Jeep and has a larger piston in it which helps make it easier to turn larger tires.
durango-bob is offline
post #4 of 8 Old 03-10-2013, 09:11 PM
99_TJ_Wyoming
for a temporary fix you can tighten up the steering gear, on top of the gear there is a locking nut and an adjustment screw, loosen the nut, tighten the screw, when snug back it off about 1/8 to a 1/4 turn and tighten down the nut, it isnt a permanent fix but it will help, the steering gear will continue to wear out, but it will increase the drivability until you can get a gear box for it.
99_TJ_Wyoming is offline
post #5 of 8 Old 03-10-2013, 09:54 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Knuckelhead is offline
post #6 of 8 Old 10-02-2013, 05:20 PM
captbo
durango swap
I have a 97 TJ will the direct swap mean my lines and Pitman arm can all be used, ! Thanks
captbo is offline
post #7 of 8 Old 10-02-2013, 06:26 PM
blubaru2002
Yes it's a direct swap. You want the steering gear box from a 1998 Durango with the "318" motor I think iirc. I can't remember if it's the snow plow edition or not. Look it up on pirate.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #8 of 8 Old 10-06-2013, 07:35 PM
captbo
ell e pressure line out of the pump would not break free of the nut so I twisted the metal part beyond repair another $75. Dang !
captbo is offline
