TJ Performance Upgrade? - JeepForum.com
post #1 of 11 Old 07-10-2010, 09:43 AM Thread Starter
crackerneckdog
I've got a '99 TJ 4.0 with the following mods:
-AEM air intake with throttle body spacer
-Banks cat back exhaust & header
-DUI firepower ignition kit with screamin demon coil
-Jet Stage 1 performance module
It runs much better now, winds up more smoothly. What are recommendations for further enhancing engine performance without breaking the bank?
crackerneckdog is offline
post #2 of 11 Old 07-10-2010, 10:18 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You have to break the bank if you want any noticeable power!Welcome to JF!
GOLENJEEPTJ is offline
post #3 of 11 Old 07-10-2010, 10:24 AM
TheBoogieman
Living Zombie!
TheBoogieman's Avatar
Stroke it.
TheBoogieman is offline
post #4 of 11 Old 07-10-2010, 10:31 AM
Outatime05
(Post deleted by author.)
Outatime05 is offline
post #5 of 11 Old 07-10-2010, 10:38 AM
DanZ51
DanZ51's Avatar
Food for thought......
Jeep Strokers • Homepage
http://jeep4.0performance.4mg.com/tech_specs.html
"I will always be an American Soldier"
DanZ51 is offline
post #6 of 11 Old 07-11-2010, 10:25 AM
heslep1
torque is all you need
heslep1 is offline
post #7 of 11 Old 07-11-2010, 12:51 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you're the victim of believing the typical corporate BS. you've wasted over $1000 on crap. yup, sorry to tell you.
Should have put that toward a $2800 4.7L Golen Stroker, and we wouldn't be having this discussion.
Unlimited04 is offline
post #8 of 11 Old 07-11-2010, 02:10 PM
emev0l
A Golen Stroker is your next step, everything you've done so far helped just a little bit, but the good news is it will all help a lot more after you swap a stroker in.
It looks like your running 3.07 gears with 31" tires with a 5 speed manual trans.
If you plan on sticking with 31's then it wouldn't hurt to throw in some 4.10 gears.
You can also have your throttle body bored out to 63mm but it wont do very much unless you stroke the motor.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #9 of 11 Old 07-11-2010, 02:12 PM
emev0l
Should have put that toward a $2300 4.7L Golen Stroker, and we wouldn't be having this discussion.
Where are you finding a $2,300 4.7L Golen Stroker?
Do you mean a 4.7L Titan stroker for $2,495.00?
It's actually $2,845.00 with the $350 core deposit.
emev0l is offline
post #10 of 11 Old 07-11-2010, 04:51 PM
Unlimited04
post #11 of 11 Old 07-11-2010, 05:09 PM
BlueFlame
BlueFlame's Avatar
An axle gearing change would have been a Far better investment.
BlueFlame is offline
tj , wrangler , performance , upgrade , tbs , throttle body , spacer , exhaust , cat back , ignition kit
2.5L performance upgrade...... turf-pro YJ Wrangler Technical Forum 26 11-05-2015 12:01 AM
Gauge Help After CRT Performance Upgrade T.Maxwell YJ Wrangler Technical Forum 3 09-18-2009 02:42 PM
Upgrade your TJ online with performance parts Fear Wrangler General Discussion 3 08-23-2009 08:47 AM
Edge performance upgrade and Penetrol.(56k no) scrubed TJ Wrangler Technical Forum 8 05-29-2006 04:27 PM
2.5l performance upgrade shadows_lair TJ Wrangler Technical Forum 8 01-06-2005 12:50 PM
