TJ owners: Will my JK wheels and tires fit a TJ. - Page 2 - JeepForum.com
 1Likes
post #16 of 34 Old 10-07-2012, 04:13 PM
Duck Doctor
The spacers will make your tires stick out further. You will need to purchase three pairs in order to accommodate your spare.
Duck Doctor is offline
post #17 of 34 Old 10-07-2012, 04:22 PM
GATJ
any idea how much further? the whole reason I'm going down from 14.50s is to keep the mud off the side of my jeep, and I think it looks nicer with the tires inside the flares...I figured this was the obvious answer, but damn it
edit: after some more research I think I've found that the adapters are about 1.25 inches thick, but the stock JK wheels have a deeper well which will almost negate any added thickness from the adapters.
GATJ is offline
post #18 of 34 Old 05-06-2013, 06:42 AM
mtdodson
Thanks for this thread guys, esp the pics! Did this over the weekend with 17s. Love the way it looks. I have an ARB bumper on the front, and the weight makes the front fenders sit a little closer than the pics I see with stock bumpers. So, I might consider a lift.
For the spare, I ended up raising the third brake light by an inch so it could clear the new spare. Ace Hardware sells chrome one inch spacers, and just replaced the stock bolts with some stainless ones that were an inch longer, which I also purchased at Ace. I believe Warrior Products sells a spacer kit, and I saw a thread where someone made spacers out of PVC. But I didn't have the time to wait for shipping nor the patience to cut and paint some PVC. Any of these three are good options.
(As much as this might sound like an Ace harward ad...I do not work at Ace.)
mtdodson is offline
post #19 of 34 Old 08-20-2013, 01:53 PM
5hBlueYJ
1987 YJ Wrangler
Just to clarify, are you guys saying that a JK wheel will fit on the spare tire posts on the back of a TJ/YJ or would modifications/adapters be necessary for the spare as well?
5hBlueYJ is offline
post #20 of 34 Old 08-20-2013, 02:11 PM
Necko2529
If it doesn't fit the hub it won't fit the spare mount, you're going to need an adapter for the spare as well.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #21 of 34 Old 09-02-2013, 09:15 AM
jascumbee
Just bought a 2000 wrangler a few weeks ago, and thanks to this thread I put the freedom edition JK wheels with 255/75r17 Nitto Trail Grapplers. Got the 5 adapters off eBay for $120, 5 rims ad lugs for $200 off Craigslist, and a lot of $$$ for the tres from the tire store...but I'm happy with the outcome! No lift...Only a little rubbing when I turn extremely sharp. Thanks for the tips!
jascumbee is offline
post #22 of 34 Old 09-02-2013, 10:03 AM
wtillinghast
This is my 2005 X with '13 Sahara wheels on it. No Lift
wtillinghast is offline
post #23 of 34 Old 09-03-2013, 08:25 AM
StupendousMan
You can fix that...
http://www.stu-offroad.com/steering/...teerstop-1.htm
StupendousMan is offline
post #24 of 34 Old 09-03-2013, 08:59 AM
jascumbee
Originally Posted by StupendousMan View Post
Awesome...I had heard you could...now I know! Thank you. Will get that taken care of this afternoon
post #25 of 34 Old 07-26-2015, 04:41 PM
ullearn
Just finished installing a set of 2015's JK 17" take offs on my 1997 TJ via wheel adapters and 2" budget boost for a grand total of $500
$200 - (5) used JK 17" wheels and tires
$150 - (5) wheel adapters
$150 - 2" budget boost with performance comp shocks
ullearn is offline
post #26 of 34 Old 07-26-2015, 05:42 PM
Ljcrawler05
You can, but it requires 2/2.25" wheel spacers depending on tire width. I'm running jk wheels on 33x12.5s and I made the mistake of purchasing 1.5" wheel spacers and they are ok, but definitely rub the lower control arms.
Ljcrawler05 is offline
post #27 of 34 Old 07-26-2015, 10:28 PM
Denzien
Denzien's Avatar
You could also replace the fenders, but that's pricey.
2006 LJ
2013 MINI Cooper S Convertible, Highgate Edition
2014 Honda Odyssey Touring
Denzien is offline
post #28 of 34 Old 08-10-2015, 12:31 PM
crobarcapn
Here is my 2003 TJ with 1.25" adapters and stock JK wheels(17") and tires(32"). I have no lift and there is no rubbing at all.
crobarcapn is offline
post #29 of 34 Old 08-10-2015, 12:32 PM
crobarcapn
I actually just took these wheels off and did a lift so I have all 5 wheels, all 5 tires (almost new) and all 5 adapters available for sale if anyone is interested. I am located in Laguna Hills, CA.
post #30 of 34 Old 08-26-2015, 09:45 PM
dougiefresh131
Will the JK take offs extend past Rubicon flares? Or will they fit inside the flares?
dougiefresh131 is offline
jk , wheel , fitment , tj
Upgraded Tires and Wheels; what to do with stock tires/wheels? rtilotta JK Wrangler Technical Forum 5 06-05-2007 07:08 PM
AEV Wheel owners! Check your wheels billycj7 JK Wrangler Technical Forum 6 06-04-2007 11:05 AM
Any Sahara owners with 17" wheels wish they had 18's? sdebol JK Wrangler Technical Forum 4 03-19-2007 01:17 PM
Selling tires? (Rubicon owners take a look) Blasphemy TJ Wrangler Technical Forum 4 01-25-2005 05:13 PM
Rubi Owners: Where do your wheels go? 04JeepTJ TJ Wrangler Technical Forum 27 12-23-2003 11:48 AM
