TJ a no go please help - JeepForum.com
post #1 of 4 Old 04-02-2014, 10:35 AM Thread Starter
Chedda
I have a 98 TJ 2.5L 5 speed that will not run doesn't even fire. Before it would fire up and run until warm then lose all power till it stalls out completely. I have changed the cam sensor and tried 3 crank sensor as well as the PCM throttle position sensor MAP sensor as well as many other parts and still no luck I've seen in places that on the 5 speeds the Cam sensor doesn't use the paper gasket? It has kicked a code saying that its not reading the Crank sensor which is why I've tried three now also is most recently kicking a code saying the Ignition/ Distribution speed is high thank you for you're time and help
Chedda is offline
post #2 of 4 Old 04-02-2014, 11:12 AM
rda616
Check all of the ground wires. I would remove them and clean them. Also check for continuity from the crankshaft position sensor to the PCM. The wiring could be corroded or broken.
rda616 is offline
post #3 of 4 Old 04-02-2014, 11:15 AM
bigred33
Could also be the coil.
bigred33 is offline
post #4 of 4 Old 04-02-2014, 11:53 AM
IlliniJeeper
If you are getting a crank sensor error, check the harness as well. Could have a wire rubbed through.
'98 Jeep TJ Sport
IlliniJeeper is offline
cam position sensor , crank position sensor , pcm , won't start
