Congratulations to -SEAN-!!
-sean-
Thanks for the opprotunity, here is my submission for the August poll.
Username: -sean-
Specs:
2004 Jeep Wrangler Unlimited (LJ).* Project Long Red One:
Project: Long Red One - JeepForum.com
Tub sectioned to TJ spec. Project L-TJ:
Project L-TJ: Sectioning ( Bobbing ) an LJ tub to TJ spec's. - Pirate4x4.Com Bulletin Board
Comp cut rear.
Campbell Ent. glass hood (modified). AutoFab hood pins and extensive under hood accessory relocation.
Currie front and rear bumpers. (modified)
4.0 and automatic transmission.
NP231 w/ Advanced Adapter SYE and Novak shifter.
Tom Woods rear drive shaft.
Rear D44: Trussed, Crusher cover, ARB, Yukon 4:88 gears, Alloy USA axles.
Front high pinion D30: Trussed, Crusher cover, ARB, Yukon 4:88 gears, Alloy USA inner and outer shafts and billet seals.*
One Ton over knuckle steering.
37" Goodyear MT/R's.*
ProComp aluminum wheels, 15x8.
Front suspension is three link, long arm using OME 2.5 springs.
Rear suspension is double triangulated long arm using 106AA springs. Outboarded shocks.
Doetsch Pre-Runner shocks.
Currie bump stops front and rear. (modified)
Custom "belly-up" skid and cross member.*
Currie Anti-Rock.
1" BL w/ 1" M.O.R.E motor mounts.
Front and rear L.E.D. lights.
Mile-Marker 12,000 lb. winch w/ HD hook and fairlead.*
RCI fuel cell.
RedTop Optima in BTF mount (modified).
Uniden CB radio, Firestick antenna.
The Source C02 tank.
Empi RaceLine seats (3)
U-Pol Raptor tub liner.
PolyPerformance Racing steering wheel w/ quik disconect.
Current Projects:
Front D60 and 6" stretch.
Full Hydro steering.
Rear 14 bolt.
Airshocks.
40's
Pics:
