TJ LS1 engine Q&A - Page 2 - JeepForum.com
post #16 of 23 Old 06-06-2012, 04:43 PM Thread Starter
Staggito
Originally Posted by mhopton View Post
Question for the OP: why are you considering the LS1 when horse power is marginally better than the LM7, but the LM7, being a truck motor, has better torque numbers? The LM7 is much cheaper, from what I've seen.
i forgot to ask. does the LM7 make more torque because of the CAM/CRANK combination vice the LS1?
Bad *** JEEP!
Staggito is offline
post #17 of 23 Old 06-06-2012, 04:46 PM
chmo
my build ... well ... ahhemm
just ordered the hopefully last part: a engine harness from speartech ... my 11 year old donor harness is most likely brittle at some parts due to the desert heat and dust here.
I will have something like USD 6.5k in parts after selling my "old" 4.0 and my 42RLE with 45k miles on the clock. The parts already include such small things like radiator hoses, exhaust stuff, clamps and TC and transmission cable shifters and intake stuff.
The shop will take another USD 1.5k to put all together.
Appointment with the shop is set for end of July ... and I will start a build thread
"The more I know, the more I realize how much I don't know"
chmo is offline
post #18 of 23 Old 06-06-2012, 04:49 PM
chmo
it has the higher truck intake manifold as well ...
chmo is offline
post #19 of 23 Old 06-06-2012, 06:20 PM
mattamd_xp
The LM7 cam is exactly the same as the LS1 cam. The higher low-end torque of the truck motor is because the truck intake has longer runners.
99 Wrangler Project Detroit Mongrel 5.3/4l60e/Atlas HPD60/14B coilovers etc...
mattamd_xp is offline
post #20 of 23 Old 06-06-2012, 09:23 PM
rckchucker
Originally Posted by chmo View Post
If I were in the US I would go LM7 5.3 ... nearly same aftermarket power add ons and only 60 lbs heavier bc of iron block than LS1 (still 40 lbs lighter than 4.0!)
False. An LM7 is not 40 lbs lighter than a 4.0. I just finished putting a 5.3 in my Jeep. I put a long block 4.0 on a scale and long block LM7 on a scale and the 5.3 was about 160 lbs heavier. My Jeep gained about 150 lbs on the nose. The only thing that changed was the engine. I retained my AX15 and 241 transfer case. I seriously doubt that an L33 aluminum block 5.3 is lighter than a 4.0 as well.
rckchucker is offline
post #21 of 23 Old 06-06-2012, 09:31 PM
droz
1997 XJ Cherokee
not sure how accurate these weights are as I've never weighed either the 4.0 in my jeep or the LS1 from my car but according to novak site for XJ (been considering the 5.3 or LS1 swap for my jeep down the road) these are the weights they listed
You'll be replacing one of three factory engines. Their nominal estimated, accessory loaded weights are:
•2.5L I4, 340 lbs.
•4.0L I6, 515 lbs.
Engines you may replace these with may include:
•Chevy Small Block V8 (Gen. I & II), 550 lbs.
•GM Small Block V8 (Gen. III), 525 lbs.
•GM Small Block V8 (LS1), 407 lbs.
droz is offline
post #22 of 23 Old 06-06-2012, 11:06 PM
clintrivera
That doesn't make a lot of sense to me. An L33 Has an aluminum block, heads, and oil pan. Plastic intake manifold. Overall, not a really big engine.
The 4.0 has an iron block, head, steel oil pan, and a metal intake manifold.
I don't see how the L33 wouldn't be lighter?
clintrivera is offline
post #23 of 23 Old 06-06-2012, 11:30 PM
chaserLJ
Post number 24 of 25
chaserLJ is offline
engine help , engine swap , motor replacement , motor swap
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 12:23 PM
In midst of engine swap, how to deal with engine bay / firewall rust? Pics included. Alheim YJ Wrangler Technical Forum 8 04-16-2012 05:59 PM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 08:00 PM
YJ Engine Choices - 2004 OBD2 Coil Pack 4.0 Engine??? -jb- YJ Wrangler Technical Forum 4 02-08-2011 09:35 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
