TJ & LJ Body Difference - JeepForum.com
post #1 of 14 Old 06-14-2011, 07:01 PM Thread Starter
J_Impact
Hey Guys,
I checked out the TJ/LJ specifications area and all I could find was TJ wheelbase 93.4" with 155.4" length and LJ wheelbase 103.4" with 167-171.7" length.
What I am looking for is to find out WHERE the exact differences are in sizes in body and frame are between the two. Just visually looking at pictures of the body it appears that the LJ makes up with space between the door and rear wheel along with the rear wheel and the back edge of the Jeep.
I own a 2005 TJ and have access to a 2005 LJ frame just a couple of hours from me. I'm having some sick thoughts of placing my TJ body, engine, tranny and t-case on the LJ frame then stretching my tub...
Any links or ideas would greatly be appreciate!
J_Impact is offline
post #2 of 14 Old 06-14-2011, 09:30 PM
undercoverfab
Vendor
undercoverfab's Avatar
Originally Posted by J_Impact View Post
Hey Guys,
The LJ frame and body are 10" longer in front of the rear axle and 5" longer behind the rear axle.
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #3 of 14 Old 06-14-2011, 09:40 PM
Tinga
Hey Guys,
It would appear that the difference is where you stated.
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #4 of 14 Old 06-14-2011, 09:57 PM Thread Starter
J_Impact
Thank you for the exact numbers!
Maybe you can give me some more info...
Due to the extra 10"s in the front is there an extra body mount there?
PS I've been looking at your products. I like!
J_Impact is offline
post #5 of 14 Old 06-14-2011, 10:04 PM
undercoverfab
Vendor
No extra body mounts. The stretch takes place just behind the rear-most body mount below the door.
Matt Walton
(334) 446-3821
Check us out on
post #6 of 14 Old 06-14-2011, 10:15 PM Thread Starter
J_Impact
Ok thanks.
I'm liking the direction my plan is heading! I'll extend my tub behind the door 10" for sure... Just not sure if I want the other 5". A semi bobbed LJ... Interesting!
J_Impact is offline
post #7 of 14 Old 06-14-2011, 10:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
look up -sean-'s build on this forum, and his write-up on pirate4x4. he bobbed his LJ to TJ specs, such that a TJ soft top or hard top would fit like factory, but retained the LJ wheelbase. very nice fab work.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 14 Old 06-14-2011, 10:29 PM
Deacon
Deacon's Avatar
Yeah, I would LOVE to do that: put an LJ frame under my TJ for a "factory" stretch. Perfection.
Deacon is offline
post #9 of 14 Old 06-14-2011, 10:32 PM
undercoverfab
Vendor
Ok thanks.
There's an extra cross-member on the LJ frame about 5" in front of the rear cross-member that will need to be removed if you plan to leave out the 5" stretch behind the rear axle.
As Unlimited04 alluded to, you will have a tough time fitting a top should you decide to go with an overall length in between TJ and LJ.
Matt Walton
(334) 446-3821
Check us out on
post #10 of 14 Old 06-14-2011, 10:35 PM
undercoverfab
Vendor
Someone should develop and kit to stretch the TJ frame and body to fit the unlimited top. Cutting directions/templates and all the parts to complete the stretch. Of course, unless you plan to cut it twice that would mean a 15" increase in WB. That might be a bit much for anything less than 37-39" tires.
Matt Walton
(334) 446-3821
Check us out on
post #11 of 14 Old 06-14-2011, 11:34 PM
RogueSpear2023
There probably isn't enough market for this for some one to make a kit. I mean it's not like bare LJ frame are laying all over the place. Its just something the requires custom fab work.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #12 of 14 Old 06-15-2011, 06:26 AM
undercoverfab
Vendor
You're right about the market not being there for that type of kit... but what I meant was a kit to stretch the TJ frame AND tub. You wouldn't have to go buy anything else.
Matt Walton
(334) 446-3821
Check us out on
post #13 of 14 Old 06-15-2011, 10:14 AM
Luck881
Luck881's Avatar
Is that you George?
Ian
'05 TJ SE, 2.4L, 6 Spd, 2(+)" Procomp Lift, 33" GY Duratracs
'09 Ram QC SLT
Luck881 is offline
post #14 of 14 Old 06-15-2011, 06:53 PM Thread Starter
J_Impact
LOL Bored at work?
JeepForum stalker!
J_Impact is offline
Body lift difference - Auto/Manual Reverb YJ Wrangler Technical Forum 4 12-26-2009 06:27 PM
What's the difference between a Budget Boost and a Body Lift staquinas TJ Wrangler Technical Forum 26 08-06-2009 02:14 AM
throttle body difference in 04 to 05 and up? coorsmgood TJ Wrangler Technical Forum 1 05-07-2007 09:18 PM
Difference between body and suspension? digitalrob TJ Wrangler Technical Forum 24 11-16-2005 04:30 PM
Difference in Body Lift Mfg's SuperWade2 TJ Wrangler Technical Forum 2 08-25-2005 10:07 PM
