TJ Lift Setups - JeepForum.com
post #1 of 25 Old 07-10-2012, 11:19 AM Thread Starter
BamaJeepman21
TJ Lift Setups
Here's a variety of TJ's with different lift setups. (still in the works)
Categories:
BB/Homebrew
2"-2.5"
3"-3.5"
4"-4.5"
5"-5.5"
6"+
Custom
Miscellaneous 1
Miscellaneous 2
Miscellaneous 3
Miscellaneous 4
Miscellaneous 5
Miscellaneous 6
Miscellaneous 7
Miscellaneous 8
Miscellaneous 9
Miscellaneous 10
These sections will be based on ADVERTISED HEIGHT not actual height.
Since there are so many different variables for TJ lift setups, if enough people submit pictures, I will try to have different sections for body lifts, fenders...etc.
HERE IS THE FORMAT THAT MUST BE FOLLOWED. IF YOU DO NOT FOLLOW THE FORMAT YOUR ENTRY WILL NOT BE POSTED.
Year:
Manufaturer:
Advertised Lift Height:
Actual Height:
Body lift:
Fenders/flares: (Stock, MetalCloak, Xenon, MCE...)
Shocks:
Tire size:
Wheel Size & Backspacing:
Notes:
Add a short description of anything extra you had to do, i.e. trimming. Include other details such as SYE, t-case drop, bumpstop extensions, any rubbing or other interference, outboarded shocks...
Post 2 (No more than 2) pictures of your Jeep. One on leveled ground and one flex shot. All photos MUST be attached. NO hotlinks.
Please PM me or Wheelin98TJ your entry, to be added to the thread.
-Jack
BamaJeepman21 is offline
post #2 of 25 Old 07-10-2012, 11:20 AM Thread Starter
BamaJeepman21
Budget Boost/Homebrew
Zone
Username:Andy1119
Year: 2006 LJ
Manufacturer: Zone BB
Advertised Lift Height: 1.75"
Actual Height: 1.75 front, 2" rear
Body lift: none
Fenders/flares: Stock
Shocks: Zone Nitro's (stiff but like em)
Tire size: Stock 30x9.5's for now
Wheel Size & Backspacing: Stock Ravine
Notes: (No transfer case drop) Rides like stock, or better!
JKS/RE
Username: mjmurphy926
Year: 2004
Manufaturer: (2" RE rear spacers, ACOS adjustable front spacers)
Advertised Lift Height: 2"
Actual Height: 2"
Body lift: 1" M.O.R.E.
Shocks: Skyjacker Hydro 7000 (F-7016, R-7018)
Tire size: 32x11.50-15
Wheel Size & Backspacing: 15x8 4" BS
Notes: I first installed a Rubicon Express 2" BB lift and 1" MORE BL. I later added a winch and swapped out the front spacers with ACOS spacers due to the extra weight making the front end sag. The ACOSs are adjusted to 3 1/4". The RE lift came with bumpstop extenders which I installed. No TC drop and no rubbing.
JKS/OME
Username: Best4x4
Year: 05 LJ 4Spd Auto
Manufaturer: JKS/OME/UCF
Advertised Lift Height: 2inch suspension and 1 1/2 increase at the skid
Actual Height: Need to measure after the UCF Skid Install
Body lift: None
Shocks: OME
Tire size: 32inch
Wheel Size & Backspacing: OEM Moab 16inch Rims
Notes: The 2inch BB was a breeze (put that on when my dad had the LJ), but with the addition of a winch/bumper I had to use the JKS ACOS setup to make the Jeep sit level. With the UCF "No Body Lift" Transfer Case Skid the only modification I had to make was to the 3rd cat hanger. I had to lower it an inch to keep the exhaust from being pushed up into the floor/aluminum heat shield. Other than that I have no clearance issues.
Homebrew
Username: Photog2000
Year: 2000
Manufaturer: All jeep parts 5.9L V8 ZJ springs up front/ 4.0L TJ front springs in rear
Advertised Lift Height: 3"
Actual Height: 2.75 front/ 3.25 rear
Body lift: None
Fenders/flares: (Stock, MetalCloak, Xenon, MCE...) Stock unmodified
Shocks: Rough Country 4" hydro
Tire size:35X12.50X15
Wheel Size & Backspacing: 15X8 3.75 BS
Notes: I had to add a I added a 2" spacer in the front after the winch and bumper install to level it out quite nicely. Tires rub the sway bar at full lock a little bit. All four will rub the flares when you twist it up to its max flex. I figure they will clearance themselves untill I get tube fenders on. T-case had to be dropped about 7/8" for vibes.
-Jack
post #3 of 25 Old 07-10-2012, 11:20 AM Thread Starter
BamaJeepman21
2"-2.5"
BDS
Username: pcwolf
Year: 2006 TJ Rubicon
Manufacturer: BDS
Actual Height: 2"
Body lift: 1/2" Rokmen
Shocks: BDS
Tire size: 245/R75-16 (31")
Wheel Size & Backspacing: Stock Moab 16" 5.5"
Notes: Had nothing else to do. Stock bumpstops appear adequate to lift (compression cup to axle pad less than exposed shock piston shaft)
Rough Country
Username: Rjsimms
Year: 2005 TJ
Manufaturer: RC
Advertised Lift Height: 2.5
Actual Height: 2.5
Body lift: 1
Fenders/flares: Xenon Flat style
Shocks: RC 2.2 Rides rough
Tire size: 33X 12.5 X 15
Wheel Size & Backspacing: 15 X 8, 3.5
Notes: Has Rock track TC with a UCF Aluminum tuck TC skid. Tom Woods rear drive shaft. Also, have 1.5 inch spacer in front to level out with bumper and winch.
Old Man Emu
Username: erickpl
Year: 1997
Manufacturer: OME
Advertised Lift Height: 2.5"
Actual Height: 2.25" (lots of armor)
Body lift: JKS 1.25"
Shocks: OME HD
Tire size: 33x12.5 TrXuS MT's
Wheel Size & Backspacing: 15x8" Canyons. 5.5" BS stock, but added SpiderTrax spacers.
Notes: Added SpiderTrax spacers to avoid tire rubbing, but still get a rough ride at full turn. Not sure if rubbing or autolocker getting goofy at full turn. Also added .75" spring spacers up front to level Jeep after bumpers and winch installed. No SYE was needed, but will be added when bellyup is done. Have also added some JKS adjustable control arms.
BDS
Username: Kodiak17
Year: 1998
Manufacturer: BDS
Actual Height: 2.75"
Body lift: No
Shocks: BDS 5500 series
Tire size: 32x11.50x15
Wheel Size & Backspacing: 15x8 5.25"
Notes: Tires rub at full turn. Can stuff the fender. More lift than advertised.
-Jack
post #4 of 25 Old 07-10-2012, 11:21 AM Thread Starter
BamaJeepman21
3"-3.5"
Rough Country
Username: sc00bz
Year: 1997 TJ
Manufaturer: Rough Country
Advertised Lift Height: 3.25"
Actual Height: 3.75" Front, 3.5" Rear
Body lift: N/A
Shocks: Rough Country 2.2
Tire size: 33x12.50r15
Wheel Size & Backspacing: 15x8, 3.75"
Notes: I had to adjust my steering stops or I rubbed at full crank. Bumpstops were needed & added. Size was determined by flexing sans springs with a floor jack.
The extra .5" in front was more than likely a result of having the 6 cylinder springs up front rather than the 4 cylinder as well as the factory springs and shots were shot. This will compensate for a winch later on. The extra .25" in the rear was probably a result of shot factory suspension as well. I have not tried running a smaller t-case drop than came with the kit as I installed it at the same time and had no vibes.
BDS/Rough Country
Username: EugeneTheTJ
Year: 2003
Manufaturer: BDS front/RC rear
Advertised Lift Height: 3" front, 2.5" rear
Actual Height: close to that
Fenders/flares: stock
Shocks: Skyjacker Hydro front, OME N67 rear
Tire size: 35x12.5 MTR/K
Notes: Bumpstop extensions
Flat
Flexed (connected)
-Jack
post #5 of 25 Old 07-10-2012, 11:21 AM Thread Starter
BamaJeepman21
4"-4.5"
Savvy/Currie
Username: c69ss396
Year: 2001
Manufaturer: currie/savvy
Advertised Lift Height: 4in
Actual Height: 4.5
Body lift: no
Shocks: fox/savvy
Tire size: 33/12.5
Wheel Size & Backspacing: ar23 15x10
Rubicon Express
Username: roadrunner2348
Year: 2002
Manufaturer: Rubicon Express
Advertised Lift Height: 4.5"
Actual Height: about 4.5"
Body lift: None
Shocks: RE Monotube
Tire size: 33x12.5 r15
Wheel Size & Backspacing: 15" BS: 3 5/16
Notes: SYE & Driveshaft
Nth Degree
Year: 2002
Manufaturer: Nth Degree 4.5" Short-ArmGyro Joint
Actual Height: 4"
Body lift: None
Fenders/flares: Bushwacker Pocket Style
Shocks: Old Man Emu Nitrocharger
Tire size: 33x12.5
Wheel Size & Backspacing: 15" BS: 3.75"
Notes: SYE & Driveshaft, Had to modify exhaust to clear front upper control arm mount, and welding for the shock relocators.
Currie/Rubicon Express
Username: jeepinjeffrey
Year: 2003
Manufaturer: Currie/ Rubicon Express
Actual Height: 4.5-5"
Body lift: 0"
Fenders/flares: Bushwhacker Flat style Fender Flares
Shocks: 4.5" Rubicon Express Extreme-Duty Mono-Tube Shock Kit
Tire size: 305/70 r 16 = 33X12.50 r16
Wheel Size & Backspacing: ION 174 16X8" 4.25" Backspacing
Notes: I had to add adjustable control arms Front and rear and I went with Currie control arms and their double adjustable rear uppers. I also have JKS adjustable trackbars front and rear and have an Advanced Adapters SYE and CV Shaft. I also added hockey puck front bump stop extensions.
-Jack
post #6 of 25 Old 07-10-2012, 11:22 AM Thread Starter
BamaJeepman21
5"-5.5"
Need pics.
-Jack
post #7 of 25 Old 07-10-2012, 11:23 AM Thread Starter
BamaJeepman21
6"+
Need pics.
-Jack
post #8 of 25 Old 07-10-2012, 11:23 AM Thread Starter
BamaJeepman21
Custom
Username:-sean-
Year: 2004 LJ/TJ
Manufaturer: Custom links with OME springs.
Advertised Lift Height: 0-2"
Actual Height: 1" rear/ 2" front
Body lift: none
Fenders/flares: Campbell Hood (modified)
Shocks: doetsch tech
Tire size: 37"
Wheel Size & Backspacing: 15x8 (4"bs)
Notes:This is a completely customized suspension, virtually everything has been modified to some degree to get it tuned correctly.
rear: double tri long arm, custom bump stops, outboard shocks,
front: three link long arm. Custom bump stops, steering and trac-bar.
Username: bradentaala
Year: 2000 TJ
Manufaturer: GenRight double triangulated; GenRight 3 link
Advertised Lift Height: variable
Actual Height: 4" rear/ 4" front
Fenders/flares: TNT customs high lines; custom hood
Shocks: 14" Fox 2.0"
Tire size: 39.50"
Wheel Size & Backspacing: 17" & 4.25" bs
Notes: Wheelbase 104", 6 inch stretch in the front with keeping stock steering box location, 4.5" stretch in the rear, still dialing in the coils so i'm sitting a little higher than i'm planning (front coming down 1.5" and rear coming down 1".
-Jack
post #9 of 25 Old 07-10-2012, 11:21 PM Thread Starter
BamaJeepman21
From other thread. No specs.
Stock with 31's:
3" BDS with 33x10.5x15:
Tera S4T w/ LT305X70R16 MTRs:
2001 tj with a 6" Fabtech Long Arm Kit and 35x12.5x15 Trxus Mt's:
-Jack
post #10 of 25 Old 07-10-2012, 11:22 PM Thread Starter
BamaJeepman21
2" BB with 33's:
99 Sahara, 3" BDS Lift, 1" Body Lift, 2" spacers, 35X12.50 BFG Muds:
2004 LJ, 2" spacers rear, 3" Rusty's springs up front, Bridgestone Desert Dueler HT 33/12.5/15's on stock Ravines with 1-1/4" wheel spacers.
Stock, but with 265/75R16 BFG AT's:
-Jack
post #11 of 25 Old 07-10-2012, 11:23 PM Thread Starter
BamaJeepman21
With 2" OME (heavy duty springs) and 1.25" JKS BL and 255/85R16 Trxus MT's:
Currently with RE 3.5" SF and 33x12.50R15 BFG MT's and MT Alcoa's:
3" Black Diamond lift DT3000's 31" BFG KM's on rock crawlers:
97 TJ Sahara, RE 4.5 SF , 1" PA BL 35x12.50 BFG MT:
-Jack
post #12 of 25 Old 07-10-2012, 11:24 PM Thread Starter
BamaJeepman21
3" rusty's springs up front, 2" spacers rear, JKS 1-1/4" body lift, 35/12.5/15's on home painted ravines with 1-1/4" spacers:
RE 3.5", JKS 1.25" BL, 35" Cooper STTs on Eagle Alloy 057:
RE 2" Budget boost, 255/85/16 BFG MT (33.3"x10.2") on AR victor 16x8:
1.25" JKS BL, 30" tires:
-Jack
post #13 of 25 Old 07-10-2012, 11:24 PM Thread Starter
BamaJeepman21
2" BDS coil lift, 1.25" JKS BL, 30" tires:
RE 5.5" Extreme LA with 2" spacer, 1" BL, 38x12.5x15 TSL:
RE 4.5 with 1" bl, 35 MTR's:
03 Sahara, 3" BDS/JKS lift, Currie 1" BL:
-Jack
post #14 of 25 Old 07-10-2012, 11:25 PM Thread Starter
BamaJeepman21
2004 TJ Rocky Mountain Edition
Front Suspension: Grand Cherokee Coils, 2 inch spacers, skyjacker shocks ad
Rear Suspension: OEM TJ front coils, Skyjacker shocks and trackbar bracket.
32" BFG Ats on 15x8 Pacer Black Steel Wheels with 4: BS
RE 4.5" SF w/3.5" springs, JKS 1.25" BL, 33x12.50R15, Crager Soft 8 4"backspacing:
2" REBB, 235/75R15:
2" REBB, 33x12.50R15:
-Jack
post #15 of 25 Old 07-10-2012, 11:25 PM Thread Starter
BamaJeepman21
4.5" RE lift, 1" spacer in front, 1" body lift, 35" Maxxis Big Horns on 15x8 rock crawlers:
1999 Tj Sahara Edition 2.5" OME lift w/ 1.25" JKS Body lift and 33x12.5x15" BFG AT's on AR Mojave w/ Teflon:
Stock suspension, 31X10.5 Difinity MT's:
2.25" coil spacers, 1.25" JKS BL/MML, 33X12.5 Mickey Thompson Baja Radial MTX's on 15x8 wheels:
-Jack
what are your setups? ? AmmitOsiris Wrangler General Discussion 43 11-28-2011 10:57 AM
steering setups on soa lift? kyle7 YJ Wrangler Technical Forum 8 02-07-2010 06:49 PM
For anyone looking into mid-arm or custom arm setups..... Imped TJ Wrangler Technical Forum 5 10-16-2009 11:48 PM
steering setups ccarnel TJ Wrangler Technical Forum 5 02-13-2006 03:58 PM
