TJ Hummer Intake Write-up (Buick Airbox)
#16 | |
I wonder what this would look like on an xj?
#17 |
I don't know about the intake, but dude...the camo flares rock. ![]()
Gravity Rat #149 But what do I know? I don't really even have a Jeep. I just make it up. |
#18 |
intentionally left blank
So how has this held up? I'm looking to something like this during the summer.
#19 |
Man... do you really ever ford deeper than 46 inches? I rarely slop water over my door sills at 32 inches, which leaves another 14 inches freeboard to the stock air horn.
#20 | |
And, it has held up very well. No leaks and it has stayed on perfectly. I have taken the top off of it a few times to lay back the hood. Unscrew the clamp and it's off...total of 5 seconds. I highly recommend this mod!!!
2000 WJ - I6, Auto, 2WD 2" BB, 18" JK wheels/32" tires, Converting to 4wd ---2WD TO 4WD CONVERSION--- 97 TJ 4" lift, 35" boggers, lockright front D30, 9k winch - SOLD 95 XJ 33" TSL's, 2" BB, SEVERE trimming - SOLD 2003 WJ LIMITED PART OUT!!!!!!!!! |
#21 | |
Very nicely done! |
#22 |
Please Tell Me Were Did You Get The Camo Fender Flares?
#23 |
I think he had a writeup where he explained how he sprayed them using cans of paint and either a real or fake leaf.
Black 2001 Wrangler SE, stats in profile |
#24 | |
#25 |
Just to revive a good thread, and ask how this mod can be done for a 2000 and up tj. What is that big boxy thing under the flange, and how can you make the hummer intake fit?
#26 |
Don't forget that when you do this you need to put your hand over the end of the intake tube and see if the engine stalls. If not you have more holes to plug.
-Ross 1998 Subaru Forester DD 2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy 1987 Coleman Columbia 3/4 ton+ tow rig wanted! |
#27 |
2000+ with the full black piece is basically the same. You just have to cut the top of the black piece off. Here's the link from the first page with pics of it: http://www.jeepforum.com/forum/f27/write-up-hummer-cold-air-intake-326040/
As an update, it's been almost a year and it's been perfect. Done some deep stuff, mainly mud and water. No problems sucking water. I haven't had to adjust anything or had any problems out of it. I have even had the cap off a couple times to fold the hood back to the windshield for extended periods under there. It's only like 30 seconds to unscrew the clamp and take it off...Still very happy ![]()
#28 |
Very cool!
Alabama Dan [ []|||||||[] ] 1988 Jeep Cherokee Laredo 4x4 Bone Stock 163,000 miles |
#29 |
cowl intake
here's mine: http://sports.webshots.com/album/85979787uFAozy
about $150 and its a breather from a hydraulic system, the filter is already in it and you can get either 3 or 10 micron and there is a K&N which also happens to fit - but you do need to weld or machine a flange to mount it with, other than that a simple install
2 Jeeps with subtle changes |
#30 | |
Is the fiter inside the flange? Looks good, but I think I would prefer it closer to the passanger side in that little "dip" area on the flange. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
