Quantcast TJ- How to adjust E Brake? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TJ- How to adjust E Brake?
Old 10-31-2008, 07:03 AM   #1
hikerpaddler
My emergency brake, in the uppermost position, no longer reliably holds the vehicle when it's parked on inclines. How do I adjust the damn thing? Braking, rear and front, functions fine, even in abrupt stops, it's just the emergency brake that's presenting a problem.
hikerpaddler is offline   Reply With Quote
Old 10-31-2008, 10:08 AM   #2
Wif
If the rear shoes are snugged up tight(ish) to the drums then you will need to take up the slack in the cable. There's an adjuster on the cable under the Jeep.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Old 10-31-2008, 10:20 AM   #3
Luckyduck
I would check the rear pads and make sure they are tight like WIF said. The adjustment under the jeep is easy just a regular flat wrench will work.
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/
Luckyduck is offline   Reply With Quote
Old 10-31-2008, 12:11 PM   #4
Sparty
which way do you turn?
(yes, I'm lazy, and haven't gone out to check yet)
Jeep Pics
www.msu.edu/~kerrrand/Jeep.htm
Sparty is offline   Reply With Quote
Old 10-31-2008, 12:21 PM   #5
Luckyduck
You turn the way that tightens it. It is a simple bolt with a nut on it. tighten the nut and it will draw in the e-brake
CentralMass4wd.com
1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/showthread.php?p=5168554#post5168554
my build http://www.jeepforum.com/forum/showthread.php?t=550786
Old 10-31-2008, 12:22 PM   #6
wrangler2007
I have the same issue...no engagement it seems like till the VERY top of where the e-brake will go...
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 10-31-2008, 06:56 PM   #7
bugdewde
Do not adjust the cables..... that adjustment is for stretched/worn cables. Probably not gonna happen to your Jeep..
You should tighten the brake shoes up against the brake drum.... that makes the parking brake engage like it should.
Normal use of the brakes eat up the brake shoe material. They must be adjusted occasionally when the auto adjusters don't work.
See this thread for a break down of how it's done:
http://www.jeepforum.com/forum/f9/tightening-emergency-brake-624499/
Dwight
'05 Patriot Blue Unlimited Rubi
Rubicon Express 4.5" Super Flex with 1" BB and JKS 1.25" BL
Summit Mud Dawgs 315/75-16
bugdewde is offline   Reply With Quote
Old 10-31-2008, 07:07 PM   #8
rickw450
What if you have disk brakes in the rear, I'm not aware of an adjustment for a caliper.
Rick,
rickw450 is offline   Reply With Quote
Old 10-31-2008, 07:14 PM   #9
bugdewde
It's exactly the same....... the disc brake parking brake is a drum style parking brake. The drum is actually the hub of the disc brake.
Dwight
Glock Forum
