TJ Hood pin installation & write-up. - Page 3 - JeepForum.com
post #31 of 35 Old 06-07-2012, 11:03 PM
-sean-
-sean-'s Avatar
1944 CJ2
Originally Posted by EagleTwoThree View Post
Sean,
Looks like yours are mounted further from center line. Could you post a straight on pic so we could see the difference?
There is a little better pic in the link below. Keep in mind it's a glass hood so the mounting will be different. There will also be pics of a different set on a cut steel hood that may help you out.
-sean- is offline
post #32 of 35 Old 06-07-2012, 11:32 PM
EagleTwoThree
Cool, thanks. I had checked your profile pics, but not the links in your sig.
EagleTwoThree is offline
post #33 of 35 Old 07-06-2014, 04:55 PM
kdilly
Howdy, I'm reviving this thread.
Does your hood close and open perfectly? When I installed mine, it seems that the hood of the jeep is sloped so that the pin is sticking straight up but when the hood closes, the holes in the black things don't line up correctly.
Because of this, I have to leave the pins loose so that I can line them up each time I open and close the hood
kdilly is offline
post #34 of 35 Old 07-07-2014, 10:16 AM
pwmac
I think the bolts were supposed to be installed at an angle such that they are perpendicular to the hood surface. This means that after drilling at an angle you would need a beveled washer to hold the pin to the to flat core support in a solid manner.
And finishing touch would also have a lynch pin tether so it could not be misplaced. And the best install use heat shrink over the wire cable to prevent scratching the paint.
PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #35 of 35 Old 07-07-2014, 04:46 PM
Danno6102
Howdy, I'm reviving this thread. Does your hood close and open perfectly? When I installed mine, it seems that the hood of the jeep is sloped so that the pin is sticking straight up but when the hood closes, the holes in the black things don't line up correctly. Because of this, I have to leave the pins loose so that I can line them up each time I open and close the hood
Just cut the rubber boss way down on the bottom of the bumpers so the pin goes in easier. Mine aren't perpendicular & they've been fine for a couple years.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
hood , install , installation , pin , tj
Tow/recovery hook installation write-up Mean Max YJ Wrangler Technical Forum 28 01-20-2011 12:18 PM
Currie Anti Rock Installation Write Up? WILLY348 TJ Wrangler Technical Forum 6 01-13-2010 08:21 PM
Axle, Gears, and Lockers Installation write up gearheadjlm TJ Wrangler Technical Forum 10 09-27-2007 08:12 AM
RE BB installation write up hoosier724 TJ Wrangler Technical Forum 4 12-16-2004 03:22 PM
MY write-up on TJ flares installation on a YJ JayJEEPguy YJ Wrangler Technical Forum 0 08-04-2004 07:49 AM
