TJ Heater control knob broken - JeepForum.com
post #1 of 8 Old 10-04-2010, 11:50 PM Thread Starter
kelso1337
So my heater control knob broke today. (Non-AC)
It just spins round and round. Goes to all positions but won't change the function from defrost.
Took it off to see the inside of the knob has a piece of cracked plastic. Guess I'll need a new one.
Stealership probably can get me one for a hefty price tag. Any other ideas?
For me, it appears everything looks fine. I haven't looked at anything leading to the heater. (IE vacuum)
Should it be as simple as to install a new switch and go right?
Thanks!
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline
post #2 of 8 Old 10-05-2010, 12:49 AM
asknight
cracked and flared plastic but no pieces missing? Loctite super glue can cure that.
asknight is offline
post #3 of 8 Old 10-05-2010, 06:13 AM
hdsport
2008 WK
Cheap OEM Knob
Had to get one for my 2000 TJ rebuild.
Here is where I found the best deal...$4.56 delivered to my door.
ConversionRadiators.com
Item ID:
SKU: 17903.20
Description: Omix-ada Climate Control Knob 99-06 TJ
Price: $4.56 (No tax, no shipping)
This item matched my set...can't tell that I even replaced it!!!!!
Let us know how you make out.
hdsport is offline
post #4 of 8 Old 10-05-2010, 07:23 AM
bairy
lol...
I pulled a volume knob off an old boom-box stereo and pushed it right on my friends jeep that was missing the knob.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #5 of 8 Old 10-05-2010, 07:30 AM
JBTJ
Yes, that is what I have done a few times plus wrap some thin gauge copper wire around it to secure even more.
JBTJ is offline
post #6 of 8 Old 10-05-2010, 08:08 AM
newracer
I was also able to glue mine back together. Also I switched it out with the temp control knob and glued the cracks in that one before it broke.
If you need another one I would recommend D A V E Y S J E E P S . C O M - Specializing in Jeeps & Jeep Parts
newracer is offline
post #7 of 8 Old 10-05-2010, 10:09 AM
Neil F.
Those breaking is fairly common. I got a replacement from the dealer. As I recall, it was not much. As indicated above, switch it with the temp knob. The temp knob does not have much resistance to it may not break again.
Neil F. is offline
post #8 of 8 Old 10-05-2010, 10:18 AM
YellowX
YellowX's Avatar
*smackshead* Damn... so simple...
Fred
JAFGJ
YellowX is offline
Heater control knob platinumjeep TJ Wrangler Technical Forum 10 01-23-2010 09:56 PM
Heater Control Cables Broken Woodyhfd TJ Wrangler Technical Forum 2 11-18-2006 05:32 PM
blower speed control broken for heater kaffeene YJ Wrangler Technical Forum 14 09-18-2006 04:51 PM
Heater Control Broken (?) YJ Newby YJ Wrangler Technical Forum 6 11-11-2005 03:03 AM
