tj heater/ac problems - JeepForum.com
post #1 of 8 Old 02-26-2014, 02:44 AM Thread Starter
Bturner7
I have tried researching, but I have had no luck. My heater and air conditioner is not working. When I turn it on I can hear it kick on, but nothing comes through the vents. Does anyone know what this could be? I was told that it could be the resistor, but I don't have the money to spend on a hunch. I was hoping that someone else may have had this problem. Thanks!
Bturner7 is offline
post #2 of 8 Old 02-26-2014, 05:51 AM
JBTJ
Check the knob on the fan switch. Sometimes they crack and just spin on the shaft. Makes you think it's turning on, but isn't.
JBTJ is offline
post #3 of 8 Old 02-26-2014, 07:55 AM
JStMarie
JStMarie's Avatar
Sorry, gotta call you out on this one. I literally searched for "Heater/AC not working" and got 108 threads that speak on the topic.
Anywhoo... JBJT is right, oftentimes it is the switch itself, mechanically. This is a good first place to look. If this looks fine then it's time to open up your console and look at the wiring going to the switch, look for melting or shorts. If the switch looks fine from a wiring perspective then you can look to the blower motor itself, perhaps pull it out clean it and test it by bypassing some voltage to it and see if she spins. All these things you can do without spending a penny.
BTW, since you said the fan does not blow on any setting, even the highest, then it is something other than the resistor pack, as the highest setting does not use the resistor pack it bypasses it through the high speed blower motor relay.
Good Luck.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #4 of 8 Old 02-26-2014, 11:48 AM Thread Starter
Bturner7
Thanks for the responses. When I said I researched I meant that I didn't see any with that exact problem. Lol. I will try that out and see if it works. Thanks again
Bturner7 is offline
post #5 of 8 Old 02-26-2014, 11:51 AM
JBTJ
It is a common problem, so it shouldn't be too hard to figure out what is wrong. Let us know what you find out.
JBTJ is offline
post #6 of 8 Old 02-26-2014, 08:02 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
The way the circuit is on your ’97 (very different than ’99 & later), if you don’t have any speed I would go to the blower motor. See if putting 12v & ground wires directly to the motor gets it working. If yes then carefully check the connector to it. If all is good there go to the mode selector slider switch. Check the flat 5 wire connector there. If not melted or signs of excessive heat check the red/dark green wire for power (from fuse 8 in the block behind the glove box) with the key on & with it still plugged in see if the tan wire gets power when the slider is in all positions except off (powers the resistor & speed switch). If not, the mode switch is bad.
Rubi4MyMrs is offline
post #7 of 8 Old 03-14-2014, 08:33 AM Thread Starter
Bturner7
Ok guys...sorry it took so long to post the results! I just got around to working on it today. I tested the blower motor by running power directly to it...nothing. I replaced the motor and I could hear it running like a champ, but air was barely coming from the vents. I did some research and found out that you have to reverse the green and black wires on the blower motor (some kind of defect and I don't know why they would reverse it). Well I got in to test it and turned it to full blast. It hasn't worked in so long that it looked like the dust bowl could have started from my jeep. If that doesn't tell you that it worked...it did! Lol. I also cleaned mud and grass out of the housing and off the blower motor resistor afterwards for good measure.
The only problem I am having now is the defrost doesn't really blow. Now I'm back to where I was two years ago. At least I have heat and air though. If anyone has a suggestion I would be glad to hear it! Thanks to everyone on the forum for their advice!
Bturner7 is offline
post #8 of 8 Old 03-14-2014, 09:54 AM
JStMarie
JStMarie's Avatar
Likely the blend door is detached/broken so you are stuck on the last setting you used. I found a writeup I bookmarked for future use when I happened to come across it. There may be better ones.
http://www.wranglerforum.com/f210/ac...nts-15844.html
Lots of folks will talk about vacuum actuated, mechanical motor, etc... but the earliest models (I think just 97 and 98) are simple slide actuators attached with a mechanical arm via a cable. It's the attachment of the mechanical arm that typically breaks, or sometimes the cable itself becomes detached. You'll need to climb under there and look. If you are 5' nothing and weigh less than 100lbs then grab a sammich and a few tools and climb on in. Otherwise I recommend removing your seat to get under there.
Good luck.
JSt.Marie
JStMarie is offline
ac , fan , heater , tj , wrangler
